Múltiple elección
Me estoy rompiendo la cabeza con esto,
Tengo el siguiente código, que tengo que modificar para que en vez de introducir un sólo número de documento me active el poder meter varios. *** programa que calcula por posición el flujo de documentos **** *---- Selection Screen ------------------------------------------------- parameters: vbeln like vbuk-vbeln memory id aun obligatory, posnr like vbap-posnr memory id pid. *---- Variables -------------------------------------------------------- data: w_comwa like vbco6, it_doc like vbfa occurs 0 with header line, it_txt like dd07v occurs 0 with header line, begin of it_type occurs 0, vbtyp like vbuk-vbtyp, text like dd07v-ddtext, end of it_type. *----------------------------------------------------------------------- start-of-selection. w_comwa-mandt = sy-mandt. w_comwa-vbeln = vbeln. w_comwa-posnr = posnr. call function 'RV_ORDER_FLOW_INFORMATION' exporting comwa = w_comwa tables vbfa_tab = it_doc exceptions no_vbfa = 1 no_vbuk_found = 2 others = 3. case sy-subrc. when 1. write: / 'No VBFA found.'. when 2. write: / 'No VBUK found. Check selection criteria...'. when 3. write: / 'Unknown Error!'. when 0. perform write_docs. endcase. *----------------------------------------------------------------------- form write_docs. call function 'GET_DOMAIN_VALUES' exporting domname = 'VBTYP' tables values_tab = it_txt exceptions no_values_found = 1 others = 2. case sy-subrc. when 1. write: / 'Warning: No texts found for Sales Docs types!'. when 2. write: / 'Warning: Cannot retrieve SD types descriptions!'. when 0. perform sort_texts. endcase. write: / 'Order Flow Information:'. loop at it_doc. write: / it_doc-stufe, it_doc-vbelv, it_doc-posnv. perform write_type using it_doc-vbtyp_v. write: it_doc-vbeln, it_doc-posnn. perform write_type using it_doc-vbtyp_n. write: it_doc-matnr, it_doc-rfmng unit it_doc-meins, it_doc-meins. endloop. endform. *----------------------------------------------------------------------- form sort_texts. loop at it_txt. it_type-vbtyp = it_txt-domvalue_l. it_type-text = it_txt-ddtext. append it_type. clear it_type. endloop. sort it_type. endform. *----------------------------------------------------------------------- form write_type using value(p_vbtyp) like vbuk-vbtyp. data w_txt(30) type c. read table it_type with key vbtyp = p_vbtyp binary search. case sy-subrc. when 0. w_txt = it_type-text. when others. w_txt = '?'. endcase. write w_txt intensified off. endform. *----------------------------------------------------------------------- |
SELECT-OPTIONS vbeln for vbuk-vbeln memory id aun obligatory.
No olvides declar la tabla. Saludos. |
Si declaro la tabla, y añado esa instrucción me dice que el campo vbeln ya ha sido definido ...
sustituir parameter- select options
-Cuando te da el mensaje te indica donde es el segundo lugar que esta definido ?? -La idea es sustituir el parameter por select options. Si es otra cosa distinta, despues comentalo. Suerte, Ester.- |
Si sustituyo el parameters por el select-options, me llega al final a decir que la tabla VBUK no la encuentra.
Quería decir Aunque la defina en tables, me salta al error 2, cuando si dejo el parameters si llega.
start-of-selection. w_comwa-mandt = sy-mandt. w_comwa-vbeln = vbeln. w_comwa-posnr = posnr. call function 'RV_ORDER_FLOW_INFORMATION' exporting comwa = w_comwa tables vbfa_tab = it_doc exceptions no_vbfa = 1 no_vbuk_found = 2 others = 3. case sy-subrc. when 1. write: / 'No VBFA found.'. when 2. write: / 'No VBUK found. Check selection criteria...'. when 3. write: / 'Unknown Error!'. when 0. perform write_docs. endcase. |
Problema con nombre de parametro
No tengo aca SAP para probar. Yo al select-option: lo nombraria p_vbeln y definiria la tabla vbuk. Tambien fijate que el select option no se usa igual que un parametro, que es un solo valor. Espero que esto se sirva. Suerte.Ester.- |
Gracias esterg por tus comentarios.
Dices que lo ponga así?? Así el problema que tengo es que siempre me coge el caso 2. when 2. write: / 'No VBUK found. Check selection criteria...'. tables: vbuk,vbap. select-options: p_vbeln for vbuk-vbeln memory id aun obligatory. parameters: posnr like vbap-posnr memory id pid. ** *---- Variables -------------------------------------------------------- data: w_comwa like vbco6, it_doc like vbfa occurs 0 with header line, it_txt like dd07v occurs 0 with header line, begin of it_type occurs 0, vbtyp like vbuk-vbtyp, text like dd07v-ddtext, end of it_type. *----------------------------------------------------------------------- start-of-selection. w_comwa-mandt = sy-mandt. w_comwa-vbeln = p_vbeln. w_comwa-posnr = posnr. call function 'RV_ORDER_FLOW_INFORMATION' exporting comwa = w_comwa tables vbfa_tab = it_doc exceptions no_vbfa = 1 no_vbuk_found = 2 others = 3. case sy-subrc. when 1. write: / 'No VBFA found.'. when 2. write: / 'No VBUK found. Check selection criteria...'. when 3. write: / 'Unknown Error!'. when 0. perform write_docs. endcase. *----------------------------------------------------------------------- form write_docs. call function 'GET_DOMAIN_VALUES' exporting domname = 'VBTYP' tables values_tab = it_txt exceptions no_values_found = 1 others = 2. case sy-subrc. when 1. write: / 'Warning: No texts found for Sales Docs types!'. when 2. write: / 'Warning: Cannot retrieve SD types descriptions!'. when 0. perform sort_texts. endcase. write: / 'Order Flow Information:'. loop at it_doc. write: / it_doc-stufe, it_doc-vbelv, it_doc-posnv. perform write_type using it_doc-vbtyp_v. write: it_doc-vbeln, it_doc-posnn. perform write_type using it_doc-vbtyp_n. write: it_doc-matnr, it_doc-rfmng unit it_doc-meins, it_doc-meins. endloop. endform. *----------------------------------------------------------------------- form sort_texts. loop at it_txt. it_type-vbtyp = it_txt-domvalue_l. it_type-text = it_txt-ddtext. append it_type. clear it_type. endloop. sort it_type. endform. *----------------------------------------------------------------------- form write_type using value(p_vbtyp) like vbuk-vbtyp. data w_txt(30) type c. read table it_type with key vbtyp = p_vbtyp binary search. case sy-subrc. when 0. w_txt = it_type-text. when others. w_txt = '?'. endcase. write w_txt intensified off. endform. |
Es porque al asignar w_comwa-vbeln = vbeln. le estas asignando la cabecera del rango vbeln al campo w_comwa-vbeln. La funcion quer estas usando (RV_ORDER_FLOW_INFORMATION) te regresa el flujo de documentos de un solo pedido. Lo que deberias hacer es declararte una tabla interna para seleccionar los pedidos que estén en el rango que indicaste, luego aplicarle un loop a esa tabla interna para ver el flujo de docuemtos de cada pedido seleccionado. Ah y coloca etiquetas cuando pongas código en los post, para facilitar la lectura. |
Gracias DERick.
Voy a probar. |
Estoy totalmente perdido a la hora de crear la tabla interna.
Un extra
le agregaría : when 1. write: / 'No VBFA found.' , w_comwa-vbeln. when 2. write: / 'No VBUK found. Check selection criteria...' ,w_comwa-vbeln. when 3. write: / 'Unknown Error!', w_comwa-vbeln. para saber en que iteracion del loop estas. Suerte!! Ester.- |
Os agradezco a ambos vuestras respuestas y siento el follón que estoy dando.
Entonces el programa debería quedar tal que así? Porque así no me carga ni uno solo. |
El select-option yo lo declararía así:
Y te falta seleccionar los pedidos que están en el rango que indicaste. algo asi: Cuantos tienes en ABAP? |
Ya lo he conseguido!!!
Muchas gracias a ambos!! No entiendo tu pregunta bien DErick de cuantos tengo en ABAP? |
perdón me comí algunas palabras por las prisas ejeje...
Cuanto tiempo tienes en abap? |
En ABAP di un curso hace unos años, pero ahora me he reenganchado, y con algunas cosas aún me pierdo.
Husos Horarios son GMT. La hora en este momento es 21:58:59. |
