Script SAP-Excel
Buen día, soy reciente usuario de SAP y no tengo mucha experiencia, verán he desarrollado el siguiente script:
If Not IsObject(application) Then Set SapGuiAuto = GetObject("SAPGUI") Set application = SapGuiAuto.GetScriptingEngine End If If Not IsObject(connection) Then Set connection = application.Children(0) End If If Not IsObject(session) Then Set session = connection.Children(0) End If If IsObject(WScript) Then WScript.ConnectObject session, "on" WScript.ConnectObject application, "on" End If session.findById("wnd[0]").maximize session.findById("wnd[0]/tbar[0]/okcd").text = "zsd0107n" session.findById("wnd[0]").sendVKey 0 session.findById("wnd[0]/tbar[1]/btn[17]").press session.findById("wnd[1]/usr/txtV-LOW").text = "COMPLETO" session.findById("wnd[1]/usr/txtENAME-LOW").text = "bdoming1" session.findById("wnd[1]/usr/txtV-LOW").caretPosition = 8 session.findById("wnd[1]/tbar[0]/btn[8]").press session.findById("wnd[0]/tbar[1]/btn[8]").press session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").setCurrentCell -1,"ZINSPFIM" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").firstVisibleColumn = "LAND1" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").selectColumn "ZINSPFIM" session.findById("wnd[0]/tbar[1]/btn[40]").press session.findById("wnd[0]/tbar[1]/btn[43]").press session.findById("wnd[1]/usr/ctxtDY_PATH").text = "Y:\Proyecto Matriz de operadores\H&S" session.findById("wnd[1]/usr/ctxtDY_FILENAME").text = "INSPECCIONES FINAL.XLSX" session.findById("wnd[1]/usr/ctxtDY_FILENAME").caretPosition = 18 session.findById("wnd[1]/tbar[0]/btn[7]").press session.findById("wnd[0]/tbar[0]/btn[3]").press session.findById("wnd[0]/tbar[0]/btn[3]").press session.findById("wnd[0]/tbar[0]/okcd").text = "ZSD0104N" session.findById("wnd[0]").sendVKey 0 session.findById("wnd[0]/tbar[1]/btn[17]").press session.findById("wnd[1]/usr/txtV-LOW").text = "CURSOS" session.findById("wnd[1]/usr/txtENAME-LOW").text = "BDOMING1" session.findById("wnd[1]/usr/txtV-LOW").caretPosition = 6 session.findById("wnd[1]/tbar[0]/btn[8]").press session.findById("wnd[0]/tbar[1]/btn[8]").press session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").setCurrentCell -1,"Z_FIM_VIG" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").selectColumn "Z_FIM_VIG" session.findById("wnd[0]/tbar[1]/btn[40]").press session.findById("wnd[0]/tbar[1]/btn[43]").press session.findById("wnd[1]/usr/ctxtDY_PATH").text = "Y:\Proyecto Matriz de operadores\H&S" session.findById("wnd[1]/usr/ctxtDY_FILENAME").text = "CURSO SEMESTRAL.XLSX" session.findById("wnd[1]/usr/ctxtDY_FILENAME").caretPosition = 15 session.findById("wnd[1]/tbar[0]/btn[7]").press session.findById("wnd[0]/tbar[0]/btn[3]").press session.findById("wnd[0]/usr/ctxtS_WERKS-LOW").text = "" session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").text = "202" session.findById("wnd[0]/usr/ctxtS_WERKS-LOW").setFocus session.findById("wnd[0]/usr/ctxtS_WERKS-LOW").caretPosition = 0 session.findById("wnd[0]/tbar[1]/btn[8]").press session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").setCurrentCell -1,"Z_FIM_VIG" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").selectColumn "Z_FIM_VIG" session.findById("wnd[0]/tbar[1]/btn[40]").press session.findById("wnd[0]/tbar[1]/btn[43]").press session.findById("wnd[1]/usr/ctxtDY_PATH").text = "Y:\Proyecto Matriz de operadores\H&S" session.findById("wnd[1]/usr/ctxtDY_FILENAME").text = "CURSO ANUAL.XLSX" session.findById("wnd[1]/tbar[0]/btn[7]").press session.findById("wnd[0]/tbar[0]/btn[3]").press session.findById("wnd[0]/tbar[0]/btn[3]").press session.findById("wnd[0]/tbar[0]/okcd").text = "ZSD0105N" session.findById("wnd[0]").sendVKey 0 session.findById("wnd[0]/tbar[1]/btn[17]").press session.findById("wnd[1]/usr/txtV-LOW").text = "OPERADORES" session.findById("wnd[1]/usr/txtENAME-LOW").text = "BDOMING1" session.findById("wnd[1]/usr/txtV-LOW").caretPosition = 10 session.findById("wnd[1]/tbar[0]/btn[8]").press session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").text = "201" session.findById("wnd[0]/usr/ctxtS_DATA-LOW").setFocus session.findById("wnd[0]/usr/ctxtS_DATA-LOW").caretPosition = 10 session.findById("wnd[0]/tbar[1]/btn[8]").press session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").setCurrentCell -1,"Z_FIM_VIG" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").selectColumn "Z_FIM_VIG" session.findById("wnd[0]/tbar[1]/btn[40]").press session.findById("wnd[0]/tbar[1]/btn[43]").press session.findById("wnd[1]/usr/ctxtDY_PATH").text = "Y:\Proyecto Matriz de operadores\H&S" session.findById("wnd[1]/usr/ctxtDY_FILENAME").text = "201.XLSX" session.findById("wnd[1]/usr/ctxtDY_FILENAME").caretPosition = 3 session.findById("wnd[1]/tbar[0]/btn[7]").press session.findById("wnd[0]/tbar[0]/btn[3]").press session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").text = "202" session.findById("wnd[0]/usr/ctxtS_DATA-LOW").text = "01.12.2019" session.findById("wnd[0]/usr/ctxtS_DATA-LOW").setFocus session.findById("wnd[0]/usr/ctxtS_DATA-LOW").caretPosition = 5 session.findById("wnd[0]/tbar[1]/btn[8]").press session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").setCurrentCell -1,"Z_FIM_VIG" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").firstVisibleColumn = "LIFNR" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").selectColumn "Z_FIM_VIG" session.findById("wnd[0]/tbar[1]/btn[40]").press session.findById("wnd[0]/tbar[1]/btn[43]").press session.findById("wnd[1]/usr/ctxtDY_PATH").text = "Y:\Proyecto Matriz de operadores\H&S" session.findById("wnd[1]/usr/ctxtDY_FILENAME").text = "202.XLSX" session.findById("wnd[1]/usr/ctxtDY_FILENAME").caretPosition = 3 session.findById("wnd[1]/tbar[0]/btn[7]").press session.findById("wnd[0]/tbar[0]/btn[3]").press session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").text = "203" session.findById("wnd[0]/usr/ctxtS_DATA-LOW").text = "01.12.2015" session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").setFocus session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").caretPosition = 3 session.findById("wnd[0]/tbar[1]/btn[8]").press session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").setCurrentCell -1,"Z_FIM_VIG" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").selectColumn "Z_FIM_VIG" session.findById("wnd[0]/tbar[1]/btn[40]").press session.findById("wnd[0]/tbar[1]/btn[43]").press session.findById("wnd[1]/usr/ctxtDY_PATH").text = "Y:\Proyecto Matriz de operadores\H&S" session.findById("wnd[1]/usr/ctxtDY_FILENAME").text = "203.XLSX" session.findById("wnd[1]/usr/ctxtDY_FILENAME").caretPosition = 3 session.findById("wnd[1]/tbar[0]/btn[7]").press session.findById("wnd[0]/tbar[0]/btn[3]").press session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").text = "204" session.findById("wnd[0]/usr/ctxtS_DATA-LOW").text = "01.12.2015" session.findById("wnd[0]/usr/ctxtS_DATA-LOW").setFocus session.findById("wnd[0]/usr/ctxtS_DATA-LOW").caretPosition = 10 session.findById("wnd[0]/tbar[1]/btn[8]").press session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").setCurrentCell -1,"Z_FIM_VIG" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").firstVisibleColumn = "LIFNR" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").selectColumn "Z_FIM_VIG" session.findById("wnd[0]/tbar[1]/btn[40]").press session.findById("wnd[0]/tbar[1]/btn[43]").press session.findById("wnd[1]/usr/ctxtDY_PATH").text = "Y:\Proyecto Matriz de operadores\H&S" session.findById("wnd[1]/usr/ctxtDY_FILENAME").text = "204.XLSX" session.findById("wnd[1]/usr/ctxtDY_FILENAME").caretPosition = 3 session.findById("wnd[1]/tbar[0]/btn[7]").press session.findById("wnd[0]/tbar[0]/btn[3]").press session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").text = "205" session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").setFocus session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").caretPosition = 3 session.findById("wnd[0]").sendVKey 0 session.findById("wnd[0]/tbar[1]/btn[8]").press session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").setCurrentCell -1,"Z_FIM_VIG" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").selectColumn "Z_FIM_VIG" session.findById("wnd[0]/tbar[1]/btn[40]").press session.findById("wnd[0]/tbar[1]/btn[43]").press session.findById("wnd[1]/usr/ctxtDY_PATH").text = "Y:\Proyecto Matriz de operadores\H&S" session.findById("wnd[1]/usr/ctxtDY_FILENAME").text = "205.XLSX" session.findById("wnd[1]/usr/ctxtDY_FILENAME").caretPosition = 3 session.findById("wnd[1]/tbar[0]/btn[7]").press session.findById("wnd[0]/tbar[0]/btn[3]").press session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").text = "206" session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").setFocus session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").caretPosition = 3 session.findById("wnd[0]").sendVKey 0 session.findById("wnd[0]/tbar[1]/btn[8]").press session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").setCurrentCell -1,"Z_FIM_VIG" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").firstVisibleColumn = "ZAPROV" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").selectColumn "Z_FIM_VIG" session.findById("wnd[0]/tbar[1]/btn[40]").press session.findById("wnd[0]/tbar[1]/btn[43]").press session.findById("wnd[1]/usr/ctxtDY_PATH").text = "Y:\Proyecto Matriz de operadores\H&S" session.findById("wnd[1]/usr/ctxtDY_FILENAME").text = "206.XLSX" session.findById("wnd[1]/usr/ctxtDY_FILENAME").caretPosition = 3 session.findById("wnd[1]/tbar[0]/btn[7]").press session.findById("wnd[0]/tbar[0]/btn[3]").press session.findById("wnd[0]/tbar[1]/btn[17]").press session.findById("wnd[1]/usr/txtV-LOW").text = "UNIDADES" session.findById("wnd[1]/usr/txtENAME-LOW").text = "BDOMING1" session.findById("wnd[1]/usr/txtV-LOW").caretPosition = 8 session.findById("wnd[1]/tbar[0]/btn[8]").press session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").text = "302" session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").setFocus session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").caretPosition = 3 session.findById("wnd[0]/tbar[1]/btn[8]").press session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").setCurrentCell -1,"Z_FIM_VIG" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").selectColumn "Z_FIM_VIG" session.findById("wnd[0]/tbar[1]/btn[40]").press session.findById("wnd[0]/tbar[1]/btn[43]").press session.findById("wnd[1]/usr/ctxtDY_PATH").text = "Y:\Proyecto Matriz de operadores\H&S" session.findById("wnd[1]/usr/ctxtDY_FILENAME").text = "302.XLSX" session.findById("wnd[1]/usr/ctxtDY_FILENAME").caretPosition = 3 session.findById("wnd[1]/tbar[0]/btn[7]").press session.findById("wnd[0]/tbar[0]/btn[3]").press session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").text = "303" session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").setFocus session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").caretPosition = 3 session.findById("wnd[0]").sendVKey 0 session.findById("wnd[0]/tbar[1]/btn[8]").press session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").setCurrentCell -1,"Z_FIM_VIG" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").firstVisibleColumn = "LIFNR" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").selectColumn "Z_FIM_VIG" session.findById("wnd[0]/tbar[1]/btn[40]").press session.findById("wnd[0]/tbar[1]/btn[43]").press session.findById("wnd[1]/usr/ctxtDY_PATH").text = "Y:\Proyecto Matriz de operadores\H&S" session.findById("wnd[1]/usr/ctxtDY_FILENAME").text = "303.XLSX" session.findById("wnd[1]/usr/ctxtDY_FILENAME").caretPosition = 3 session.findById("wnd[1]/tbar[0]/btn[7]").press session.findById("wnd[0]/tbar[0]/btn[3]").press session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").text = "304" session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").setFocus session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").caretPosition = 3 session.findById("wnd[0]").sendVKey 0 session.findById("wnd[0]/tbar[1]/btn[8]").press session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").setCurrentCell -1,"Z_FIM_VIG" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").firstVisibleColumn = "LIFNR" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").selectColumn "Z_FIM_VIG" session.findById("wnd[0]/tbar[1]/btn[40]").press session.findById("wnd[0]/tbar[1]/btn[43]").press session.findById("wnd[1]/usr/ctxtDY_PATH").text = "Y:\Proyecto Matriz de operadores\H&S" session.findById("wnd[1]/usr/ctxtDY_FILENAME").text = "304.XLSX" session.findById("wnd[1]/usr/ctxtDY_FILENAME").caretPosition = 3 session.findById("wnd[1]/tbar[0]/btn[7]").press session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").firstVisibleColumn = "ICON" session.findById("wnd[0]/tbar[0]/btn[3]").press session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").text = "305" session.findById("wnd[0]/usr/ctxtS_DATA-LOW").text = "01.12.2019" session.findById("wnd[0]/usr/ctxtS_DATA-LOW").setFocus session.findById("wnd[0]/usr/ctxtS_DATA-LOW").caretPosition = 10 session.findById("wnd[0]/tbar[1]/btn[8]").press session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").setCurrentCell -1,"Z_FIM_VIG" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").firstVisibleColumn = "LIFNR" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").selectColumn "Z_FIM_VIG" session.findById("wnd[0]/tbar[1]/btn[40]").press session.findById("wnd[0]/tbar[1]/btn[43]").press session.findById("wnd[1]/usr/ctxtDY_PATH").text = "Y:\Proyecto Matriz de operadores\H&S" session.findById("wnd[1]/usr/ctxtDY_FILENAME").text = "305.XLSX" session.findById("wnd[1]/usr/ctxtDY_FILENAME").caretPosition = 3 session.findById("wnd[1]/tbar[0]/btn[7]").press session.findById("wnd[0]/tbar[0]/btn[3]").press session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").text = "306" session.findById("wnd[0]/usr/ctxtS_DATA-LOW").text = "01.01.2010" session.findById("wnd[0]/usr/ctxtS_DATA-LOW").setFocus session.findById("wnd[0]/usr/ctxtS_DATA-LOW").caretPosition = 10 session.findById("wnd[0]").sendVKey 0 session.findById("wnd[0]/tbar[1]/btn[8]").press session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").setCurrentCell -1,"Z_FIM_VIG" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").selectColumn "Z_FIM_VIG" session.findById("wnd[0]/tbar[1]/btn[40]").press session.findById("wnd[0]/tbar[1]/btn[43]").press session.findById("wnd[1]/usr/ctxtDY_PATH").text = "Y:\Proyecto Matriz de operadores\H&S" session.findById("wnd[1]/usr/ctxtDY_FILENAME").text = "306.XLSX" session.findById("wnd[1]/usr/ctxtDY_FILENAME").caretPosition = 3 session.findById("wnd[1]/tbar[0]/btn[7]").press session.findById("wnd[0]/tbar[0]/btn[3]").press session.findById("wnd[0]/tbar[1]/btn[17]").press session.findById("wnd[1]/usr/txtV-LOW").text = "ACOPLADOS" session.findById("wnd[1]/usr/txtENAME-LOW").text = "BDOMING1" session.findById("wnd[1]/usr/txtV-LOW").caretPosition = 9 session.findById("wnd[1]/tbar[0]/btn[8]").press session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").text = "401" session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").setFocus session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").caretPosition = 3 session.findById("wnd[0]/tbar[1]/btn[8]").press session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").setCurrentCell -1,"Z_FIM_VIG" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").firstVisibleColumn = "NAME1" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").selectColumn "Z_FIM_VIG" session.findById("wnd[0]/tbar[1]/btn[40]").press session.findById("wnd[0]/tbar[1]/btn[43]").press session.findById("wnd[1]/usr/ctxtDY_PATH").text = "Y:\Proyecto Matriz de operadores\H&S" session.findById("wnd[1]/usr/ctxtDY_FILENAME").caretPosition = 6 session.findById("wnd[1]").sendVKey 0 session.findById("wnd[1]/usr/ctxtDY_FILENAME").text = "401.XLSX" session.findById("wnd[1]/usr/ctxtDY_FILENAME").caretPosition = 3 session.findById("wnd[1]/tbar[0]/btn[7]").press session.findById("wnd[0]/tbar[0]/btn[3]").press session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").text = "402" session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").setFocus session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").caretPosition = 3 session.findById("wnd[0]/tbar[1]/btn[8]").press session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").setCurrentCell -1,"Z_FIM_VIG" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").firstVisibleColumn = "LIFNR" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").selectColumn "Z_FIM_VIG" session.findById("wnd[0]/tbar[1]/btn[40]").press session.findById("wnd[0]/tbar[1]/btn[43]").press session.findById("wnd[1]/usr/ctxtDY_PATH").text = "Y:\Proyecto Matriz de operadores\H&S" session.findById("wnd[1]/usr/ctxtDY_FILENAME").text = "402.XLSX" session.findById("wnd[1]/usr/ctxtDY_FILENAME").caretPosition = 3 session.findById("wnd[1]/tbar[0]/btn[7]").press session.findById("wnd[0]/tbar[0]/btn[3]").press session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").text = "403" session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").setFocus session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").caretPosition = 3 session.findById("wnd[0]").sendVKey 0 session.findById("wnd[0]/tbar[1]/btn[8]").press session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").setCurrentCell -1,"Z_FIM_VIG" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").firstVisibleColumn = "LIFNR" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").selectColumn "Z_FIM_VIG" session.findById("wnd[0]/tbar[1]/btn[40]").press session.findById("wnd[0]/tbar[1]/btn[43]").press session.findById("wnd[1]/usr/ctxtDY_PATH").text = "Y:\Proyecto Matriz de operadores\H&S" session.findById("wnd[1]/usr/ctxtDY_FILENAME").text = "403.XLSX" session.findById("wnd[1]/usr/ctxtDY_FILENAME").caretPosition = 3 session.findById("wnd[1]/tbar[0]/btn[7]").press session.findById("wnd[0]/tbar[0]/btn[3]").press session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").text = "404" session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").setFocus session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").caretPosition = 3 session.findById("wnd[0]/tbar[1]/btn[8]").press session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").setCurrentCell -1,"Z_FIM_VIG" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").selectColumn "Z_FIM_VIG" session.findById("wnd[0]/tbar[1]/btn[40]").press session.findById("wnd[0]/tbar[1]/btn[43]").press session.findById("wnd[1]/usr/ctxtDY_PATH").text = "Y:\Proyecto Matriz de operadores\H&S" session.findById("wnd[1]/usr/ctxtDY_FILENAME").text = "404.XLSX" session.findById("wnd[1]/usr/ctxtDY_FILENAME").caretPosition = 3 session.findById("wnd[1]/tbar[0]/btn[7]").press session.findById("wnd[0]/tbar[0]/btn[3]").press session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").text = "405" session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").setFocus session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").caretPosition = 3 session.findById("wnd[0]/tbar[1]/btn[8]").press session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").setCurrentCell -1,"Z_FIM_VIG" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").selectColumn "Z_FIM_VIG" session.findById("wnd[0]/tbar[1]/btn[40]").press session.findById("wnd[0]/tbar[1]/btn[43]").press session.findById("wnd[1]/usr/ctxtDY_PATH").text = "Y:\Proyecto Matriz de operadores\H&S" session.findById("wnd[1]/usr/ctxtDY_FILENAME").text = "405.XLSX" session.findById("wnd[1]/usr/ctxtDY_FILENAME").caretPosition = 3 session.findById("wnd[1]/tbar[0]/btn[7]").press session.findById("wnd[0]/tbar[0]/btn[3]").press session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").text = "406" session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").setFocus session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").caretPosition = 3 session.findById("wnd[0]/tbar[1]/btn[8]").press session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").setCurrentCell -1,"Z_FIM_VIG" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").firstVisibleColumn = "LIFNR" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").selectColumn "Z_FIM_VIG" session.findById("wnd[0]/tbar[1]/btn[40]").press session.findById("wnd[0]/tbar[1]/btn[43]").press session.findById("wnd[1]/usr/ctxtDY_PATH").text = "Y:\Proyecto Matriz de operadores\H&S" session.findById("wnd[1]/usr/ctxtDY_FILENAME").text = "406.XLSX" session.findById("wnd[1]/usr/ctxtDY_FILENAME").caretPosition = 3 session.findById("wnd[1]/tbar[0]/btn[7]").press session.findById("wnd[0]/tbar[0]/btn[3]").press session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").text = "407" session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").setFocus session.findById("wnd[0]/usr/ctxtS_CODCAT-LOW").caretPosition = 3 session.findById("wnd[0]/tbar[1]/btn[8]").press session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").setCurrentCell -1,"Z_FIM_VIG" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").firstVisibleColumn = "TXPARVW" session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").selectColumn "Z_FIM_VIG" session.findById("wnd[0]/tbar[1]/btn[40]").press session.findById("wnd[0]/tbar[1]/btn[43]").press session.findById("wnd[1]/usr/ctxtDY_PATH").text = "Y:\Proyecto Matriz de operadores\H&S" session.findById("wnd[1]/usr/ctxtDY_FILENAME").text = "407.XLSX" session.findById("wnd[1]/usr/ctxtDY_FILENAME").caretPosition = 3 session.findById("wnd[1]/tbar[0]/btn[7]").press session.findById("wnd[0]/tbar[0]/btn[3]").press session.findById("wnd[0]/tbar[0]/btn[3]").press Lo que busco son dos cosas, lo primero es que cuando se empieza a ejecutar el script, todos los libros que genera de excel los va abriendo (y como pueden ver son muchos), quiero ver la forma de que no los abra y solo los modifique. Lo otro es que si es posible que este script lo ejecute una macro, mi idea es generar un botón en el formato que recopila toda la información generada el script y desde ahí, ejecutarlo. |
Husos Horarios son GMT. La hora en este momento es 09:44:40. |
