Tax Base Amount (tax on purchases)
I need to define the Tax Base Amount of “one” Tax Code with two different “processing keys” (for example: VST, NVT) with the following request:
* The first “processing key” must apply the percentage only if the base “Tax Base Amonunt” is less than a “maximum amount” established. * The other “processing key” must apply the percentage only if the “Tax Base Amount” is higher than a “minimum amount” established. In this case the percentage must apply to a Base that is “Tax Base Amount – Minimum amount” The problem is that I need to use "only one tax code" assigned to the expense in the invoice, I cannot use two tax codes. Is there any exit program to put a table and a program in the moment that SAP builds the Tax Base and apply the Tax Code? Thanks |
Parametrizaciones básicas de gestión financiera (Nuevo) ® Impuesto sobre el volumen de negocios ® Parametrizaciones basicas ® Argentina ® Actualizar importes mínimos para Categorías Fiscales
saludos |
Husos Horarios son GMT. La hora en este momento es 15:08:48. |
