Subscreen
HOLA!!!
OTRA VEZ POR AQUI, RESULTA QUE YA ME FUNCIONAN LOS DOS PROGRAMAS QUE HE VENIDO DE DESARROLLANDO, RESULTA QUE ESTOS DOS LOS TENGO QUE INCLUIR EN UN SOLO PROGRAMA, CON SUBSCREEN, PERO LO QUE HE INTENDADO HACER ES HACER UN INCLUDE EN CADA SUBSCREEN RESPECTIVAMENTE, PERO ME VOTA DOS ERRORES, Programa YACSAP001 Each ABAP program can contain only one "REPORT", "PROGRAM", or "FUNCTION-POOL". "FUNCTION-POOL" statement. Programa YACSAP002 Each ABAP program can contain only one "REPORT", "PROGRAM", or "FUNCTION-POOL". "FUNCTION-POOL" statement. AHORA SI INCLUYO TODO LO QUE HICE EN ESTOS DE TODAS FORMAS ME EMPIEZA A GENERAR UN MONTONON DE ERRORES, QUE PENA MOLESTAR TANTO, AGRADEZCO SU COLABORACION Y COMPRENSION, GRACIAS *&---------------------------------------------------------------------* *& Report YACSAP003 *& *&---------------------------------------------------------------------* *& *& *&---------------------------------------------------------------------* Report YACSAP003. *________________________________________________ * CARPETA PARA LA TOMA DE DATOS PERSONALES *________________________________________________ SELECTION-SCREEN BEGIN OF SCREEN 100 AS SUBSCREEN. * INCLUDE YACSAP001. SELECTION-SCREEN END OF SCREEN 100. *________________________________________________ * CARPETA PARA EL MANEJO DE MATERIALES *________________________________________________ SELECTION-SCREEN BEGIN OF SCREEN 200 AS SUBSCREEN. * INCLUDE YACSAP002. SELECTION-SCREEN END OF SCREEN 200. *_______________________________________________ * *_______________________________________________ SELECTION-SCREEN: BEGIN OF TABBED BLOCK datos FOR 10 LINES, TAB (20) carpeta1 USER-COMMAND push1 DEFAULT SCREEN 100, TAB (20) carpeta2 USER-COMMAND push2 DEFAULT SCREEN 200, END OF BLOCK datos. INITIALIZATION. carpeta1 = 'DATOS PERSONALES'. carpeta2 = 'SELECCION MATERIALES'. |
El primer problema que planteas, creo que se debe a que para incluir un report en otro , debes declarar el report que debes incluir como tipo INCLUDE, si los hicistes de forma independiente seguramente los tengas como tipo EJECUTABLE y de ahí el error. Estos datos los puedes mirar en los atributos del report. Espero que te sirva :)
Husos Horarios son GMT. La hora en este momento es 05:31:24. |
