Crear datos en infty 2010 via User Exit
Hola, Estoy teniendo problemas para crear datos en el infty 2010.
Estoy usando el siguiente codigo: FORM f_create2010 USING p_pernr p_begda p_endda p_value p_wt. DATA: header_assob LIKE assob. DATA: l_asshr LIKE asshr. DATA: ls_pdsnr LIKE pdsnr. DATA: w_pdsnr LIKE asshr-pdsnr, w_bukrs LIKE csks-bukrs, w_kokrs LIKE csks-kokrs, w_gsber LIKE csks-gsber, w_seqnr LIKE *pa2010-seqnr. DATA: return TYPE bapireturn1. DATA: pv_viekn LIKE pa0003-viekn. DATA: BEGIN OF p2010 OCCURS 5. INCLUDE STRUCTURE p2010. DATA: END OF p2010. DATA: BEGIN OF wa_infty OCCURS 1. INCLUDE STRUCTURE p2010. DATA: END OF wa_infty. BREAK-POINT. SELECT SINGLE viekn FROM pa0003 INTO pv_viekn WHERE pernr = p_pernr AND begda <= p_begda. CALL FUNCTION 'BAPI_EMPLOYEE_ENQUEUE' EXPORTING number = p_pernr IMPORTING return = return. IF return IS INITIAL. CALL FUNCTION 'HR_READ_INFOTYPE' EXPORTING * TCLAS = 'A' pernr = p_pernr infty = '2010' *BEGDA = '18000101' *ENDDA = '99991231' * BYPASS_BUFFER = ' ' * LEGACY_MODE = ' ' * IMPORTING * SUBRC = SUBRC TABLES infty_tab = p2010. LOOP AT p2010 WHERE subty = p_wt. MOVE p2010 TO wa_infty. EXIT. ENDLOOP. wa_infty-pernr = p_pernr. wa_infty-infty = '2010'. wa_infty-lgart = p_wt. wa_infty-subty = p_wt. wa_infty-stdaz = p_value. wa_infty-begda = p_begda. wa_infty-endda = p_endda. wa_infty-AEDTM = sy-datum. wa_infty-UNAME = sy-uname. CALL FUNCTION 'HR_INFOTYPE_OPERATION' EXPORTING infty = '2010' number = p_pernr subtype = p_wt validitybegin = p_begda record = wa_infty operation = 'INS' view_identifier = pv_viekn tclas = 'A' dialog_mode = '1' IMPORTING return = return. IF NOT return IS INITIAL AND return-type EQ 'E'. MESSAGE e000(38) WITH return-message. ENDIF. CALL FUNCTION 'BAPI_EMPLOYEE_DEQUEUE' EXPORTING number = p_pernr IMPORTING return = return. ENDIF. ENDFORM. " F_CREATE2010 Aparentemente HR_READ_INFOTYPE no funcionaria con el infty 2010. ¿Alguno tiene alguna idea? |
Husos Horarios son GMT. La hora en este momento es 02:24:31. |
