Error Activo Fijo
2 Adjunto(s)
Ayuda una manito, tengo este error en este activo 2 cosas primero me gustaría saber porque se produce y segundo como lo puedo borrar, ya que no me deja hacer nada Desactivarlo. Modificarlo, nada, siempre me trae el error.
Sldos y gracias |
Error AA
braschilester,
Busca la nota numero 337699, espero te sirva. Saludos. |
Summary
Symptom The system issues error message AA 609 "SYST: Depreciation area 00 not created in comp.code &", when you change the master record, for example by deleting an index from a depreciation area or deleting the deactivation date of a fixed asset. In both cases, area 00 was not defined. Other terms AS02, SAPLAIST Reason and Prerequisites There can be several reasons for this error: 1. You subsequently removed the deactivation date of the fixed asset (ANLA-DEAKT) without repeating the fiscal year change. ANLB-LGJAN and ANLC-GJAHR are at least 1 less than the relevant entry in T093C-LGJAHR. 2. You delete a depreciation area of the fixed asset manually, even though the depreciation area had been active. You can see this from the fact that the ANLC segments of the fixed asset have a different status than the highest entry in GJAHR. 3. The legacy data transfer is incorrect. A legacy data transfer has been carried out at least twice in the system at a different transfer date in each case. Solution 1. For point 1: Repeat the fiscal year change. You can also repeat the fiscal year change in the past, if the new fiscal year is not smaller than T093C-LGJAHR. If you cannot repeat the fiscal year change, the incorrect fixed asset must be corrected by the R/3 support. For this, create a SAPNet R/3 Frontend (formerly OSS) message with reference to this note. 2. For point 2: Contact SAP consulting. 3. For point 3: Contact SAP consulting. You must add entries to the ANLC table. Header Data Release Status: Released on: 15.02.2007 10:18:59 Master Language: Alemán Priority: Category: Primary Component: FI-AA-AA-A Datos maestros Affected Releases Release-Independent Related Notes 170230 - Error AA609 when removing the retirement date Print Selected Notes (PDF) |
Gracias Amigos - Thanks Friends
Gracias por tu ayuda
ANLA-DEAKT descapitalizacion el
Fe.descapitalización En una baja total, el sistema almacena en este campo la fecha de referencia de la contabilización de baja. Después de desactivar un inmovilizado, no se pueden realizar más contabilizaciones en el inmovilizado (excepción: anular la última baja). Para poder contabilizar correcciones aún después de una desactivación, se puede modificar (anular) manualmente la fecha de desactivación en el registro maestro de inmovilizados. ANLB-LGJAN Ultimo ejercicio Último ejercicio de los valores anuales en Contabilidad AF Cuando, por motivos de rendimiento, al cambiar de ejercicio ya no se creen entradas nuevas en la tabla ANLC para activos fijos sin valores actuales (bien porque ya hayan sido amortizados completamente y no se amortice bajo cero), se indicará aquí el último ejercicio para el cual aún existe una entrada en la tabla ANLC. Esta función no se utiliza actualmente. T093C-LGJAHR SPRO Último ejercicio abierto por cambio de ejercicio Este campo sirve para almacenar el ejercicio que se ha abierto con el último cambio de ejercicio para inmovilizados. Este elemento de datos sólo se utiliza internamente en el sistema. ANLC-GJAHR Ejercicio Período, generalmente de 12 meses, para el que la empresa deberá crear su propio inventario y balance. El ejercicio se puede cubrir con el año natural, pero esto no es obligatorio. |
Husos Horarios son GMT. La hora en este momento es 09:40:39. |
