parámetro MAIL_APPL_OBJ.
Hola¡
Buenos días, tengo un smartform que quiero enviar via mail por medio de un spool, tengo todo rellenado menos el parametro parámetro MAIL_APPL_OBJ, que no sé como rellenarlo o si por eso no funciona. Cuando ejecuto la SOST, me aparece mi orden de envío pero con estatus de "Ninguna entrada en la cola de espera". Ayuda¡¡¡¡¡¡¡¡¡ :eek: :eek: |
Aca te paso un ejemplo, quizás te sirva:
** Data declaration ..... CALL FUNCTION 'SSF_FUNCTION_MODULE_NAME' EXPORTING formname = 'Z_REPORT' IMPORTING fm_name = v_form_name EXCEPTIONS no_form = 1 no_function_module = 2 OTHERS = 3. IF sy-subrc <> 0. MESSAGE ID sy-msgid TYPE sy-msgty NUMBER sy-msgno WITH sy-msgv1 sy-msgv2 sy-msgv3 sy-msgv4. ENDIF. w_ctrlop-getotf = 'X'. w_ctrlop-no_dialog = 'X'. w_compop-tdnoprev = 'X'. w_compop-tddest = 'Locl'. w_ctrlop-no_dialog = 'X'. w_ctrlop-device = 'PRINTER'. CALL FUNCTION v_form_name EXPORTING control_parameters = w_ctrlop output_options = w_compop user_settings = ' ' l_load = p_load IMPORTING job_output_info = w_return TABLES i_output = i_output EXCEPTIONS formatting_error = 1 internal_error = 2 send_error = 3 user_canceled = 4 OTHERS = 5. IF sy-subrc <> 0. MESSAGE ID sy-msgid TYPE sy-msgty NUMBER sy-msgno WITH sy-msgv1 sy-msgv2 sy-msgv3 sy-msgv4. ENDIF. i_otf[] = w_return-otfdata[]. CALL FUNCTION 'CONVERT_OTF' EXPORTING format = 'PDF' max_linewidth = 132 IMPORTING bin_filesize = v_len_in TABLES otf = i_otf lines = i_tline EXCEPTIONS err_max_linewidth = 1 err_format = 2 err_conv_not_possible = 3 OTHERS = 4. IF sy-subrc <> 0. MESSAGE ID sy-msgid TYPE sy-msgty NUMBER sy-msgno WITH sy-msgv1 sy-msgv2 sy-msgv3 sy-msgv4. ENDIF. * Convert PDF from 132 to 255. LOOP AT i_tline. * Replacing space by ~ TRANSLATE i_tline USING ' ~'. CONCATENATE w_buffer i_tline INTO w_buffer. ENDLOOP. * Replacing ~ by space TRANSLATE w_buffer USING '~ '. DO. i_record = w_buffer. * Appending 255 characters as a record APPEND i_record. SHIFT w_buffer LEFT BY 255 PLACES. IF w_buffer IS INITIAL. EXIT. ENDIF. ENDDO. REFRESH: i_reclist, i_objtxt, i_objbin, i_objpack. CLEAR w_objhead. * Object with PDF. i_objbin[] = i_record[]. DESCRIBE TABLE i_objbin LINES v_lines_bin. * Object with main text of the mail. i_objtxt = text-002. APPEND i_objtxt. CLEAR i_objtxt. APPEND i_objtxt. i_objtxt = 'Kind regards,'. APPEND i_objtxt. i_objtxt = 'Client facing team'. APPEND i_objtxt. DESCRIBE TABLE i_objtxt LINES v_lines_txt. * Document information. w_doc_chng-obj_name = 'Smartform'. w_doc_chng-expiry_dat = sy-datum + 10. w_doc_chng-obj_descr = 'Shipment Summary Report'. w_doc_chng-sensitivty = 'O'. "Standard w_doc_chng-doc_size = v_lines_txt * 255. * Pack to main body as RAW. * Obj. to be transported not in binary form CLEAR i_objpack-transf_bin. * Start line of object header in transport packet i_objpack-head_start = 1. * Number of lines of an object header in object packet i_objpack-head_num = 0. * Start line of object contents in an object packet i_objpack-body_start = 1. * Number of lines of the object contents in an object packet i_objpack-body_num = v_lines_txt. * Code for document class i_objpack-doc_type = 'RAW'. APPEND i_objpack. * Packing as PDF. i_objpack-transf_bin = 'X'. i_objpack-head_start = 1. i_objpack-head_num = 1. i_objpack-body_start = 1. i_objpack-body_num = v_lines_bin. i_objpack-doc_type = 'PDF'. i_objpack-obj_name = 'Smartform'. CONCATENATE 'Hazard report-' p_load '.pdf' INTO i_objpack-obj_descr. i_objpack-doc_size = v_lines_bin * 255. APPEND i_objpack. IF sy-subrc = 0. LOOP AT i_misc INTO w_misc. i_reclist-receiver = w_misc-z_value_1. i_reclist-express = 'X'. i_reclist-rec_type = 'U'. "Internet address APPEND i_reclist. ENDLOOP. * Sending mail. CALL FUNCTION 'SO_NEW_DOCUMENT_ATT_SEND_API1' EXPORTING document_data = w_doc_chng put_in_outbox = 'X' commit_work = 'X' TABLES packing_list = i_objpack object_header = w_objhead contents_bin = i_objbin contents_txt = i_objtxt receivers = i_reclist EXCEPTIONS too_many_receivers = 1 document_not_sent = 2 document_type_not_exist = 3 operation_no_authorization = 4 parameter_error = 5 x_error = 6 enqueue_error = 7 OTHERS = 8. IF sy-subrc <> 0. MESSAGE ID sy-msgid TYPE sy-msgty NUMBER sy-msgno WITH sy-msgv1 sy-msgv2 sy-msgv3 sy-msgv4. ELSE. CALL FUNCTION 'POPUP_TO_INFORM' EXPORTING titel = 'Mail sent'(003) txt1 = 'The report is sent via e-mail.'(004) txt2 = ' '. LEAVE PROGRAM. ENDIF. ELSE. CALL FUNCTION 'POPUP_TO_INFORM' EXPORTING titel = 'No e-mail specified'(005) txt1 = 'You need to maintain the e-mail adress in table'(006) txt2 = text-007. LEAVE PROGRAM. ENDIF. |
Solución
Hola de nuevo,
Ya lo he solucionado, lo único que tenia que poner era un commit work al final de la llama a la función del modulo del smartform. Así que solo es necesario el siguiente código (no hace falta rellenar parametro MAIL_APPL_OBJ). Akí va el código: *---------------Buscar foto de material, SELECT * FROM stxbitmaps INTO stxbitmaps UP TO 1 ROWS WHERE TDOBJECT = 'GRAPHICS' AND TDNAME = i_dats_form-matnr AND TDID = 'BMAP'. ENDSELECT. IF sy-subrc = 0. * parametro que informa si la foto será en b/n o en color l_tipo_img = stxbitmaps-tdbtype. ELSE. l_tipo_img = ''. ENDIF. ---------------------* R_PARAM-NO_DIALOG = 'X'. "No popup R_INPUT-TDNOPREV = 'X'. "No preview D_DEVICE = 'MAIL'. R_INPUT-tdnewid = 'X'. "nueva orden spool R_INPUT-tdimmed = 'X'. "salida inmediata * MONTAR ESTRUCTURA DEL MAIL R_INPUT-tddataset = text-111. R_INPUT-tdsuffix1 = text-112. R_INPUT-tdsuffix2 = sy-uname. * Titulo email CONCATENATE text-113 i_dats_form-ematn i_dats_form-name1 i_dats_form-bukrs INTO R_INPUT-tdtitle SEPARATED BY space. R_PARAM-DEVICE = D_DEVICE. CALL FUNCTION mod_func EXPORTING V_LOGO = i_dats_form-logo "LOGO V_MODO = l_tipo_img "B/N O COLOR * ARCHIVE_INDEX = * ARCHIVE_INDEX_TAB = * ARCHIVE_PARAMETERS = CONTROL_PARAMETERS = R_PARAM * MAIL_APPL_OBJ = ls_MAIL_APPL_OBJ MAIL_RECIPIENT = d_lvs_recipient MAIL_SENDER = d_lvs_sender OUTPUT_OPTIONS = R_INPUT * USER_SETTINGS = 'X' IMPORTING * DOCUMENT_OUTPUT_INFO = * JOB_OUTPUT_INFO = JOB_OUTPUT_OPTIONS = R_OUTPUT TABLES I_PZA_COMPRA = i_dats_form EXCEPTIONS FORMATTING_ERROR = 1 INTERNAL_ERROR = 2 SEND_ERROR = 3 USER_CANCELED = 4 OTHERS = 5. COMMIT WORK. * Si se produce un error, mostrarlo. IF SY-SUBRC <> 0. MESSAGE ID SY-MSGID TYPE SY-MSGTY NUMBER SY-MSGNO WITH SY-MSGV1 SY-MSGV2 SY-MSGV3 SY-MSGV4. ENDIF. |
Husos Horarios son GMT. La hora en este momento es 23:26:59. |
