Dump CONNE_IMPORT_WRONG_OBJECT_TYPE
Hola a todos,
Quisiera saber quien me puede apoyar con este problema que tengo al momento de ejecutar una transaccion Z la cual me marca un Dump que dice lo siguiente: Runtime Errors CONNE_IMPORT_WRONG_OBJECT_TYPE Except. CX_SY_IMPORT_MISMATCH_ERROR Short text Error when attempting to IMPORT object "RID0". What happened? Error in the ABAP Application Program The current ABAP program "SAPLZPSIU" had to be terminated because it has come across a statement that unfortunately cannot be executed. Try to find out why the type of the object is incorrect. There are various possible options: 1. The type of the imported object has changed in the Data Dictionary. Make sure that the type of the imported object matches the type of the object in the Data Dictionary. If the data cannot be restored from another source, the data must be read by the 'old' structure, converted und again eported with the new structure, so that future IMPORTs will always function with the new structure. 2. A new program version is active, which no longer fits the dataset. Try to solve the error generating the program "SAPLZPSIU" again. This works as follows: Select transaction SE38 in the SAP system. Enter the program name "SAPLZPSIU". Then activate the function 'Generate'. En el codigo marca el error en lo siguiente 88 * verifica o status de processamento da interface >> load_restart_data. el cual el load_restart_data tiene: define load_restart_data. import dtmh to mc_dtmh tcnt to mi_tcnt ecnt to mi_ecnt scnt to mn_scnt sqid to mc_sqid name to mc_name hstc to mi_hstc ldfs to mh_ldfs rid0 to restart_id0 rid1 to restart_id1 rid2 to restart_id2 rid3 to restart_id3 rid4 to restart_id4 from database zb002(sg) id zb000-intid. end-of-definition. Pero no se donde definen el objeto de importe RID0... Ojala pudieran apoyarme en este problema ya tengo tiempo con esto :( Muchas gracias a todos. |
Buenas noches.
El dump ocurre dentro de el código fuente SAPLZPSIU. Los reportes cuyos nombres comienzan con SAPLZ generalmente corresponden a los códigos fuentes de grupos de funciones custom (Z). En este caso, todo indica que se trata del grupo de funciones ZPSIU. Tranquilamente lo que puede haber ocurrido es que se le haya realizado algún tipo de mantenimiento a este grupo de funciones, lo que debe haber generado la inconsistencia que deriva en el dump. Probá realizando la sugerencia que te indica en el detalle del dump: Si lo anterior no funciona, quizás leyendo el código fuente de algunas de las funciones que componen a este grupo de funciones puedas encontrar alguna pista acerca del origen del objeto "RID0". La excepción del dump pareciera indicar que el error está ocurriendo por una incompatibilidad de tipos entre el dato importado con el del tipo de dato destino de la importación. Adicionalmente, te recomiendo que también averigües si es que se ha realizado un seguimiento de las modificaciones a ese grupo de funciones, el cual pueda abrirte mejor la cabeza en cuanto a lo que está ocurriendo. Espero que puedas resolverlo. Un saludo. |
Hola vanesamacri:
Gracias por tu respuesta, pero la sugerencia que me dio el DUMP ya lo he hecho y sigo con el problema incluso ahorita con tu ayuda al explicar lo de como identificar los grupos de función fui validando si tenían algún error o si estaban desactivados y todo esta correcto de ahí... A lo que me dices de buscar de "RID0" ya también me di la tarea de buscarlo en todas las funciones , include y todo y no encuentro donde lo declaran en el codigo... por lo que pienso que son variables definidas (en alguna parte que no encuentro) y poder ver que hay diferente entre ambientes, ya que este problema se presenta sólo en PRD y en QA si funciona.... Realmente no se como solucionarlo... Seguire investigando, si descubro cómo, vengo y lo explico y de igual manera agradecería su apoyo. Gracias :) |
Husos Horarios son GMT. La hora en este momento es 09:32:11. |
