Viejo 22/11/10, 22:38:41
Victor Hugo Mendez Victor Hugo Mendez is offline
SAp Nw 7.0 EHP1 - Error Instalando Server Aplicación JAVA
Buena tarde:
Se esta instalando SAp Netweaver 7.0 EHP1, Oracle 10.2g, Red Hat Enterprise Linux 5, SAP Application Server JAVA. Central System
En el paso 22 del proceso: Configure UME, se esta deteniendo la instalación con el siguiente error en el archivo de log BatchConfig.log
/usr/sap/BJD/JC01/j2ee/admin/adminCFG.properties doesn't exist and will be created by batchconfig.
/usr/sap/BJD/JC01/j2ee/admin/cfg/adminCFG.properties doesn't exist and will be created by batchconfig.
/usr/sap/BJD/JC01/j2ee/deploying/dplOptions.options doesn't exist and will be created by batchconfig.
/usr/sap/BJD/JC01/j2ee/configtool/config.properties doesn't exist and will be created by batchconfig.
/usr/sap/BJD/JC01/j2ee/deploying/rdb.properties doesn't exist and will be created by batchconfig.
.hotspot_compiler is missing in cluster_data.
ChangeServicePropsTask has finished successfully. Service: ssl on dispatcher
ChangeManagerPropsTask has finished successfully. Manager: LockingManager on dispatcher
ChangeManagerPropsTask has finished successfully. Manager: ClusterManager on dispatcher
Error occurred while working with Configuration.com.sap.engine.frame.core.configuration.NameNotFoundException: A property with the name "java.parameters" cannot be found in the
PropertySheet "cluster_data/server/cfg/element-info.ID139743".
at com.sap.engine.core.configuration.impl.addons.PropertyEntryImpl.<init>(PropertyEntryImpl.java:85)
at com.sap.engine.core.configuration.impl.addons.PropertyEntryImpl.readPropertyEntry(PropertyEntryImpl.java:54)
at com.sap.engine.core.configuration.impl.addons.PropertySheetImpl.getPropertyEntry(PropertySheetImpl.java:127)
at com.sap.engine.configtool.batch.task.ElementInfoTask.setElementInfoProperties(ElementInfoTask.java:243)
at com.sap.engine.configtool.batch.task.ElementInfoTask.go(ElementInfoTask.java:184)
at com.sap.engine.configtool.batch.BatchConfig.go(BatchConfig.java:60)
at com.sap.engine.configtool.batch.BatchConfig.main(BatchConfig.java:98)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:88)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:61)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:60)
at java.lang.reflect.Method.invoke(Method.java:391)
at com.sap.engine.offline.OfflineToolStart.main(OfflineToolStart.java:81)
Por favor, su colaboración para buscar la solución
Viejo 23/05/11, 17:55:54
XIPE_CSESD XIPE_CSESD is offline
Hola encontraste algo para tu problema?
Husos Horarios son GMT. La hora en este momento es 23:40:43.
