![]() como saber si una transaccion tiene una subscreen exit ???? ya que necesito ingresar dos field text a la transaccion FD01 ayudaaaaaaaa
hola.
En principio, si creas este report en tu sistema y lo ejecutas, debería listarte la exits para la transaccion que necesitas: *&---------------------------------------------------------------------* *& Report ZUSEREXIT *& *&---------------------------------------------------------------------* *& *& *&---------------------------------------------------------------------* report zuserexit_proba no standard page heading. tables : tstc, tadir, modsapt, modact, trdir, tfdir, enlfdir. tables : tstct. data : jtab like tadir occurs 0 with header line. data : field1(30). data : v_devclass like tadir-devclass. parameters : p_tcode like tstc-tcode obligatory. select single * from tstc where tcode eq p_tcode. if sy-subrc eq 0. select single * from tadir where pgmid = 'R3TR' and object = 'PROG' and obj_name = tstc-pgmna. move : tadir-devclass to v_devclass. if sy-subrc ne 0. select single * from trdir where name = tstc-pgmna. if trdir-subc eq 'F'. select single * from tfdir where pname = tstc-pgmna. select single * from enlfdir where funcname = tfdir-funcname. select single * from tadir where pgmid = 'R3TR' and object = 'FUGR' and obj_name eq enlfdir-area. move : tadir-devclass to v_devclass. endif. endif. select * from tadir into table jtab where pgmid = 'R3TR' and object = 'SMOD' and devclass = v_devclass. select single * from tstct where sprsl eq sy-langu and tcode eq p_tcode. format color col_positive intensified off. write:/(19) 'Transaction Code - ', 20(20) p_tcode, 45(50) tstct-ttext. skip. if not jtab[] is initial. write:/(95) sy-uline. format color col_heading intensified on. write:/1 sy-vline, 2 'Nombre Exit', 21 sy-vline , 22 'Descripcion', 95 sy-vline. write:/(95) sy-uline. loop at jtab. select single * from modsapt where sprsl = sy-langu and name = jtab-obj_name. format color col_normal intensified off. write:/1 sy-vline, 2 jtab-obj_name hotspot on, 21 sy-vline , 22 modsapt-modtext, 95 sy-vline. endloop. write:/(95) sy-uline. describe table jtab. skip. format color col_total intensified on. write:/ 'Número de Exits:' , sy-tfill. else. format color col_negative intensified on. write:/(95) 'No existe ninguna user exit'. endif. else. format color col_negative intensified on. write:/(95) 'El código de transacción no existe'. endif. at line-selection. get cursor field field1. check field1(4) eq 'JTAB'. set parameter id 'MON' field sy-lisel+1(10). call transaction 'SMOD' and skip first screen. |
![]() ![]() Hola Atlas Gracias por el codigo me sirvio mucho y ya revise mi transaccion sap estandard desgraciadamente no cuenta con un screen exit. Pero ya cuento con la herramienta para poder saberlo y no perder el tiempo tratando de adivinar si existe o no .... Saludos Isabel ![]() |
Pestañas en una ampliacion
Hola, quisiera saber como puedo agregar unas pestañas a una dynpro estandar, y por supuesto como asigno los datos de una estructura a esas pestañas. De antemano muchas gracias por la ayuda. Saludos
