Viejo 27/09/12, 20:06:00
CRISTINO.GARCIA CRISTINO.GARCIA is offline
Reeporte ALV
Hola a Todos
Ejecutando un Reporte con ALV, me arroja el siguiente error: Que puedo chequear?
Muchas Gracias
Cristino
Error Code RAISE_EXCEPTION.
A *** ERROR => RFC-GUI: illegal data appl x1, applid x50, len 41 [abrfcsys.c 7291]
A *** ERROR => RFC Error RFCIO_ERROR_SYSERROR in abrfcsys.c : 7296
*** ERROR => DpWPCheck: max_hold_time W0 exceeded (T13=fatima ) [dpxxdisp.c 15955]
*** ERROR => DpRqCheck: mode 2 in status CANCEL [dpxxdisp.c 7508]
***LOG Q0G=> DpRqBadHandle, bad_req ( DIA) [dpxxdisp.c 5721]
*** ERROR => BAD REQUEST - Reason: DpRqCheck failed (line 6536): [dpxxdisp.c 5723]
-IN sender_id DISPATCHER tid 13 wp_ca_blk 60 wp_id 0
-IN action SEND_TO_WP uid 38 appc_ca_blk -1 type DIA
-IN new_stat NO_CHANGE mode 2 len 9 rq_id 21626
-IN req_info MSG_WITH_REQ_BUF MSG_WITH_OH
-IN forward to T13/U38/M2
M *** WARNING => PfStatWrite: missing STAT_END for opcode STAT_GUI [pfxxstat.c 4220]
A Thu Sep 27 14:14:28 2012
A
A ABAP Program SAPLOLEA .
A Source LOLEAU10 Line 352.
A Error Code RAISE_EXCEPTION.
A Module $Id: //bas/700_REL/src/krn/runt/abfunc.c#20 $ SAP.
A Function ab_jfune Line 2561.
A ** RABAX: level LEV_RX_STDERR completed.
A ** RABAX: level LEV_RX_RFC_ERROR entered.
A ** RABAX: level LEV_RX_RFC_ERROR completed.
A ** RABAX: level LEV_RX_RFC_CLOSE entered.
A ** RABAX: level LEV_RX_RFC_CLOSE completed.
A ** RABAX: level LEV_RX_IMC_ERROR entered.
A ** RABAX: level LEV_RX_IMC_ERROR completed.
A ** RABAX: level LEV_RX_DATASET_CLOSE entered.
A ** RABAX: level LEV_RX_DATASET_CLOSE completed.
A ** RABAX: level LEV_RX_ERROR_SAVE entered.
A ** RABAX: level LEV_RX_ERROR_SAVE completed.
A ** RABAX: level LEV_RX_ERROR_TPDA entered.
A ** RABAX: level LEV_RX_ERROR_TPDA completed.
A ** RABAX: level LEV_RX_PXA_RELEASE_RUDI entered.
A ** RABAX: level LEV_RX_PXA_RELEASE_RUDI completed.
A ** RABAX: level LEV_RX_LIVE_CACHE_CLEANUP entered.
A ** RABAX: level LEV_RX_LIVE_CACHE_CLEANUP completed.
A ** RABAX: level LEV_RX_END entered.
A ** RABAX: level LEV_RX_END completed.
A ** RABAX: end no http/smtp
A ** RABAX: end RX_GOTO_RABAX
A Exception condition "SYSTEM_FAILURE" raised..
Viejo 28/09/12, 13:12:10
Error en ALV
Revisando el error en el reporte con ALV observo esto:
En el Programa LOLEAU10 en la funcion AC_FLUSH_CALL_INTERNAL
MESSAGE_NR = SAVE_SUBRC.
MESSAGE_TEXT = SAVE_MSGLI.
* fatale error in RFC queue or XML-Data-Steam
IF SAVE_SUBRC = 5 OR SAVE_SUBRC = 6.
PERFORM HANDLE_DATA_STREAM_ERROR(SAPFGUICNTL) IF FOUND.
if save_subrc = 1.
RAISE SYSTEM_FAILURE. " Aqui es que da el error
endif.
EXIT. "===========================================> Exit
Que puedo revisar. Muchas Gracias de Antemano.
Husos Horarios son GMT. La hora en este momento es 16:47:50.
