Viejo 03/01/13, 22:02:30
ponchillo ponchillo is offline
Máximo de registros en una tabla interna
Hola, buenas tardes!.
Alguien sabe cual es el tope máximo de registros que puede almacenar una tabla interna?
Creo que tiene que ver con algo de configuración de memoria por usuario, pero no estoy seguro.
Viejo 04/01/13, 07:35:54
Avatar de crounly
crounly crounly is offline
Localización: Zaragoza, España
No hay un limite como tal en el numero de registros de una tabla interna
Depende de la memoria RAM disponible y del parámetro OCCURS
Los parámetros del sistema para determinar la memoria disponible en cada sesión:
"o ztta/roll_area (1.000.000 - 15.000.000)
Classic roll area per user and internal mode
usual amount of roll area per user and internal mode
o ztta/roll_extension (10.000.000 - 500.000.000)
Amount of memory per user in extended memory (EM)
o abap/heap_area_total (100.000.000 - 1.500.000.000)
Amount of memory (malloc) for all users of an application
server. If several background processes are running on
one server, temporary bottlenecks may occur.
Of course, the amount of memory (in bytes) must also be
available on the machine (main memory or file system swap).
Caution:
The operating system must be set up so that there is also
enough memory for each process. Usually, the maximum address
space is too small.
Ask your hardware manufacturer or your competence center
about this.
In this case, consult your hardware vendor
abap/heap_area_dia: (10.000.000 - 1.000.000.000)
Restriction of memory allocated to the heap with malloc
for each dialog process.
Parameters for background processes:
abap/heap_area_nondia: (10.000.000 - 1.000.000.000)
for each background process.
Other memory-relevant parameters are:
em/initial_size_MB: (35-1200)
Extended memory area from which all users of an
application server can satisfy their memory requirement.
Viejo 04/01/13, 14:31:40
Muchas gracias por tu excelente y pronta respuesta Crounly.
Saludos!!.
Husos Horarios son GMT. La hora en este momento es 02:34:16.
