Viejo 19/01/07, 14:49:40
Avatar de DCErick
DCErick DCErick is offline
Localización: Monterrey
Ftp
Hola alguien sabra que funciones existen para trabajar con FTP, lo que necesito es conectarme a un sitio FTP, subir un archivo que el BANCO me dejara ahi y luego borrarlo.
Pero no tengo idea de como hacerlo.....
Viejo 19/01/07, 19:53:20
andyoscky andyoscky is offline
Miembro Honorario
Ejemplo
estructura zx
MANDT MANDT CLNT 3 0 Mandante
SOURCE LOCALFILE CHAR 128 0 Fichero local para upload/download
DESTINATION LOCALFILE CHAR 128 0 Fichero local para upload/download
FILENAME LOCALFILE CHAR 128 0 Fichero local para upload/download
________________ ______________________________ __________ ______ ______ ____________________________________________________________
*"*"Interfase local
*" IMPORTING
*" REFERENCE(HOST) TYPE C
*" REFERENCE(USERID) TYPE C
*" REFERENCE(PASSWORD) TYPE C
*" REFERENCE(USAGE) TYPE C
*" REFERENCE(RFC_DESTINATION) LIKE RFCDES-RFCDEST
*" TABLES
*" COMMANDS
*" RESULTS
*" FILES STRUCTURE Zx
*" EXCEPTIONS
*" INVALID_USAGE
*" NO_FILES_TO_TRANSFER
*" NO_FTP_COMMANDS_TO_EXECUTE
*" FTP_CONNECTION_FAILED
*" FTP_COMMAND_FAILURE
*Function Z_x
*Purpose: This function module simplifies implementation of FTP
*functionality by reducing the setup required and number of calls
*involved within ABAP. This function can operate by passing a table of
*files with source and destination locations to be transferred or by
*passing a table of FTP commands to be executed.
*Parameter Description:
*HOST The host address of the FTP server. Usually specified as
*an IP address. (ex. 65.212.34.120)
*USERID The userid used to login to the FTP server
*PASSWORD The password used to login to the FTP server. Unlike the
*manual implementation of FTP this function accepts only
*plain text passwords.
*USAGE Determines the mode of operation for ZEASY_FTP. Valid
*values are ‘S’, ‘R’, or ‘A’.
*‘S’end – When using mode ‘S’ a table of filenames (FILES)
*with the corresponding source and destination locations are passed in.
*The function will send all files from their source locations to the
*destination locations on the FTP server.
*‘R’etrieve – When using mode ‘R’ a table of filenames (FILES) with the
*corresponding source and destination locations are passed in. The
*function will retrieve all files from the source locations on the FTP
*server and place them in the appropriate destination locations.
*‘A’dvanced – When using mode ‘A’ a table of commands (COMMANDS) is
*passed in. These commands are executed in sequential order.
*RFC_DESTINATION Determines which ‘local’ view to use during the
*transfer process. Valid values are ‘SAPFTP’ or
*‘SAPFTPA’. These destinations are configured in SM59 and already exist
*as defaults provided by SAP.
*‘SAPFTP’ – Use this value to transfer files between
*the GUI front-end machine and the FTP server.
*‘SAPFTPA’ – Use this value to transfer files between the SAP
*application server and the FTP server.
*Table Description:
*COMMANDS Table of FTP commands for processing. When using modes ‘S’ or
*‘R’ this table will be filled on successful execution of ZEASY_FTP
* with* the FTP commands used to perform the file transfer. When using
*mode ‘A’ this table must be filled by the calling program with valid
*FTP commands to be executed by ZEASY_FTP.
*RESULTS Table containing a log of the FTP session results.
*FILES Table containing the source location, destination location,
*and filename of each file to be transferred. When using
*modes ‘S’ or ‘R’ this table must be filled by the calling program.
*The structure of the FILES table consists of the following:
*SOURCE LIKE LOCALFILE (RLGRAP-FILENAME)
*DESTINATION LIKE LOCALFILE (RLGRAP-FILENAME)
*FILENAME LIKE LOCALFILE (RLGRAP-FILENAME)
*Exception Description:
*INVALID_USAGE The usage specified was not equal to a valid value
*consisting of ‘S’, ‘R’, or ‘A’.
*NO_FILES_TO_TRANSFER Mode ‘S’ or ‘R’ was specified for usage; however,
*the necessary table of FILES was not specified.
*NO_FTP_COMMANDS_TO_EXECUTE Mode ‘A’ was specified for usage;
*however, the necessary table of COMMANDS
*to be executed was not specified.
*FTP_CONNECTION_FAILED There was a problem establishing the FTP
*connection. Please verify the host
*address, userid, and password of the FTP
*server. Also verify that the correct
*RFC_DESTINATION was specified.
*FTP_COMMAND_FAILURE There was a problem executing the FTP
*commands. Please check commands for
*validity.
*DOCUMENTATION/NOTES
* Date: 05/2003
* USAGE = 'S'end, 'R'etrieve, 'A'dvanced
* RFC_DESTINATION = 'SAPFTP', 'SAPFTPA' - defined in SM59
* Be aware that FTP userid's, passwords, and commands are case
* sensitive! For easiest use please make sure that the FTP account has
* been created with a lowercase userid and password and TRANSLATE
* the userid and password parameters to lower case before calling this
* function.
* Cannot test ZEASY_FTP, FTP_CONNECT, or other functions that use
* FTP_CONNECT from function tester (auto converts test data to upper
* case)!
* Parameters on selection screens are auto converted to upper case
* during AT SELECTION-SCREEN.
* Structure of ZEASYFTP_FILES (FILES table)
* SOURCE LIKE LOCALFILE
* DESTINATION LIKE LOCALFILE
* FILENAME LIKE LOCALFILE
data: l_key type i value 26101957.
data: l_length type i.
data: l_lines type i.
data: l_ftp_handle type i.
data: l_cd_src(3) type c.
data: l_cd_dest(3) type c.
data: l_transfer_command(3) type c.
*ENSURE PROPER EXECUTION *
if usage ne 'S' and usage ne 'R' and usage ne 'A'.
raise invalid_usage.
endif.
case usage.
when 'A'.
describe table commands lines l_lines.
if l_lines = 0.
raise no_ftp_commands_to_execute.
endif.
when 'S' or 'R'.
clear: commands. refresh: commands.
describe table files lines l_lines.
if l_lines = 0.
raise no_files_to_transfer.
endif.
* build commands
if usage = 'S'.
l_cd_src = 'lcd'.
l_cd_dest = 'cd'.
l_transfer_command = 'put'.
elseif usage = 'R'.
l_cd_src = 'cd'.
l_cd_dest = 'lcd'.
l_transfer_command = 'get'.
endif.
sort files by source destination.
loop at files.
at new source.
if not files-source is initial.
concatenate l_cd_src files-source into commands
separated by space.
append commands.
endif.
endat.
at new destination.
if not files-destination is initial.
concatenate l_cd_dest files-destination into commands
separated by space.
append commands.
endif.
endat.
if not files-filename is initial.
concatenate l_transfer_command files-filename into commands
separated by space.
append commands.
endif.
endloop.
endcase.
*ENCRYPT PASSWORD *
l_length = strlen( password ).
call 'AB_RFC_X_SCRAMBLE_STRING'
id 'SOURCE' field password id 'KEY' field l_key
id 'SCR' field 'X' id 'DESTINATION' field password
id 'DSTLEN' field l_length.
*ESTABLISH FTP CONNECTION *
call function 'FTP_CONNECT'
exporting
user = userid
password = password
host = host
rfc_destination = rfc_destination
importing
handle = l_ftp_handle
exceptions
not_connected = 1
others = 2.
if sy-subrc <> 0.
raise ftp_connection_failed.
endif.
*PROCESS FTP COMMANDS *
call function 'FTP_COMMAND_LIST'
exporting
tables
data = results
commands = commands
exceptions
tcpip_error = 1
command_error = 2
data_error = 3
others = 4.
if sy-subrc <> 0.
raise ftp_command_failure.
endif.
*CLOSE FTP CONNECTION *
call function 'FTP_DISCONNECT'
exporting
handle = l_ftp_handle.
endfunction.
Husos Horarios son GMT. La hora en este momento es 15:50:39.
