![]() Buenas Tardes amigos, queria saber si sabran a que se debe este error el cual se me esta generando al ingresar a la transaccion F-58 y cual es su posible solución, desconozco en su totalidad porque esta pasando esto, si alguien tiene alguna idea agradeceria su ayuda. Aqui les anexo el error. Gracias de Antemano.
ShrtText Syntax error in program "SAPMF05A ". What happened? Error in ABAP application program. The current ABAP program "????????????????????????????????????????" had to be terminated because one of the statements could not be executed. This is probably due to an error in the ABAP program. In program "SAPMF05A ", the following syntax error occurred in the Include "MF05AFA0_ABZUEGE_BUCHEN " in line 241: "Different number of parameters in FORM and PERFORM (routine: KONTENFIN" "DUNG_ADDAA, number of formal parameters: 11, number of actual paramete" "rs: 10)." " " Author and last person to change the Include are: Author "SAP " Last changed by "SAP " Error analysis In program "SAPMF05A ", the following syntax error occurred: "Different number of parameters in FORM and PERFORM (routine: KONTENFIN" "DUNG_ADDAA, number of formal parameters: 11, number of actual paramete" "rs: 10)." " " |
Buenas,
Tiene pinta de parametrización, habla con un funcional de finanzas y que se revise la parametrizacion de la f-58. Saludos, LouieBoy |
