error urgente
Hola a Tod@s necesitaria ayuda urgente con este tema, al intalar un Support Package me da error :
Error in phase: IMPORT_PROPER Reason for error: TP_STEP_FAILURE Return code: 0008 Error message: OCS Package SAPKH47028, tp step "I", return code 0008 Me estoy volviendo loco y no consigo solucionarlo me podeis ayudar . Muchas gracias a todos. |
Debes averiguar porqué se ha dado el error para que no vuelva a suceder.
Para devolver la spam a su estatus original: PARA RESETEAR LA SPAM EJECUTAR LA SIGUIENTE FUNCION: Ir a la transaccón SE37, poner OCS_RESET_QUEUE, dar a F8 para ejecutar. En los parámetros que pide poner: IV_TOOL SPAM IV_FORCE X Saludos. Moisés. |
hola moisex, he echo lo que me has comentado ahora me da el siguiente error pero no se como seguir , he buscado en help.sap pero nada te agradeceria si me puedes ayudar?
Este es el log: Saving the current OCS Queue (02.01.2008, 13:27:16) Import of the current OCS Queue (02.01.2008, 13:27:26) The import is done with the Standard scenario Import phase 'PROLOGUE' (02.01.2008, 13:27:30) Import phase 'PROLOGUE' was successfully finished (02.01.2008, 13:27 Import phase 'CHECK_REQUIREMENTS' (02.01.2008, 13:27:31) Import phase 'CHECK_REQUIREMENTS' was successfully finished (02.01.2 Import phase 'DISASSEMBLE' (02.01.2008, 13:27:31) Import phase 'DISASSEMBLE' was successfully finished (02.01.2008, 13 Import phase 'ADD_TO_BUFFER' (02.01.2008, 13:27:52) Import phase 'ADD_TO_BUFFER' was successfully finished (02.01.2008, Import phase 'MODIFY_BUFFER' (02.01.2008, 13:27:52) Import phase 'MODIFY_BUFFER' was successfully finished (02.01.2008, Import phase 'IMPORT_OBJECT_LIST' (02.01.2008, 13:27:52) Import phase 'IMPORT_OBJECT_LIST' was successfully finished (02.01.2 Import phase 'OBJECTS_LOCKED_?' (02.01.2008, 13:28:01) Import phase 'OBJECTS_LOCKED_?' was successfully finished (02.01.200 Import phase 'TEST_IMPORT' (02.01.2008, 13:28:03) Error during executing the tp command 'tp TST ALL D01 ...' Details of the error situation can also be found in the import logs |
