Viejo 24/10/11, 15:03:31
MMCM MMCM is offline
Database startup failed
Buen día,
Alguien puede apoyarme, no puedo levantar sap, y no se mucho de basis ni soy dba este es el error que me marca
Gracias !!
Starting SAP-Collector Daemon
* This is Saposcol Version COLL 20.79 03/08/22 46D - V3.40 64Bit
* Usage: saposcol -l: Start OS Collector
* saposcol -k: Stop OS Collector
* saposcol -d: OS Collector Dialog Mode
* saposcol -s: OS Collector Status
* The OS Collector is already running .....
saposcol already running
Checking SAP R/3 ALU Database
Database is not available via /usr/sap/ALU/SYS/exe/run/R3trans -d -w
Starting SAP R/3 ALU Database
Startup-Log is written to /oracle/ALU/startdb.log
Database startup failed !
See /oracle/ALU/startdb.log for details
Este archivo tiene el siguiente contenido:
------------------------------ Mon Oct 24 10:15:48 CDT 2011
LOGFILE FOR STARTING ORACLE
checking required environment variables
ORACLE_HOME is >/oracle/ALU/817_32<
ORACLE_SID is >ALU<
check initora
check initora
checking V2 connect
TNS Ping Utility for Solaris: Version 8.1.7.4.0 - Production on 24-OCT-2011 10:1
5:48
(c) Copyright 1997 Oracle Corporation. All rights reserved.
Attempting to contact (ADDRESS=(COMMUNITY=SAP.WORLD)(PROTOCOL=TCP)(HOST=alu890)(
PORT=1527))
OK (10 msec)
tnsping: V2 connect to ALU
Connect to the database to check the database state:
R3trans: connect check finished with return code: 12
Database not available
Shutdown database
First trying to shutdown the database - May be,
the database is in the nomount or mount state
starting database
Oracle Server Manager Release 3.1.7.0.0 - Production
Copyright (c) 1997, 1999, Oracle Corporation. All Rights Reserved.
Oracle8i Enterprise Edition Release 8.1.7.4.0 - Production
With the Partitioning option
JServer Release 8.1.7.4.0 - Production
Connected.
ORACLE instance started.
Total System Global Area 294473888 bytes
Fixed Size 73888 bytes
Variable Size 133001216 bytes
Database Buffers 161054720 bytes
Redo Buffers 344064 bytes
Database mounted.
Database opened.
Server Manager complete.
------------------------------ Mon Oct 24 10:15:57 CDT 2011
Connect to the database to verify, that the database is now open
R3trans check finished with return code: 12
*** ERROR: Startup of database failed
Notify Database Administrator.
------------------------------ Mon Oct 24 10:15:59 CDT 2011
/usr/sap/ALU/SYS/exe/run/startdb: Terminating with error code 2
Viejo 25/10/11, 16:57:50
nadie ? helpp, alguna idea ?
Husos Horarios son GMT. La hora en este momento es 12:54:51.
