Viejo 28/08/13, 14:05:55
cosagaucha cosagaucha is offline
Dump con sentencia SUBMIT
Hola a todos, estoy teniendo este problema, se genera un dump en esta sentencia:
SUBMIT (p_name) VIA SELECTION-SCREEN AND RETURN.
y lo unico "raro" de la misma, en todo caso, es el valor que llega ahi a p_name, que es '/1BCDWB/DBVBAK'.
Esta correcto que sea asi ese literal? O el dump se debe a las / del contenido?
Este es parte del dump:
The current ABAP program "SAPLZBC004" had to be terminated because it has
come across a statement that unfortunately cannot be executed.
The following syntax error occurred in program "/1BCDWB/DBVBAK " in include
line 1090:
"Campo "%_ENQU_VBAK" desconocido: No está incluido en una de las tablas"
" indicadas ni definido mediante una sentencia "DATA" ."
The include has been created and last changed by:
Created by: "SAP* "
Last changed by: "SAP* "
Error in the ABAP Application Program
.errores
The following syntax error was found in the program /1BCDWB/DBVBAK :
Husos Horarios son GMT. La hora en este momento es 19:36:00.
