Esta funcion convierte a caracter ascii y hexadecimal
FUNCTION Z_CHARACTER_TO_ASCII_CODE. *"---------------------------------------------------------------------- *"*"Interfase local *" IMPORTING *" REFERENCE(FI_CHARACTER) TYPE C *" EXPORTING *" REFERENCE(FE_ASCII_CODE_DEC) TYPE I *" REFERENCE(FE_ASCII_CODE_HEX) TYPE C *"---------------------------------------------------------------------- field-symbols <FS> type x. *Have to use CASTING here to purposely force SAP to convert the *character to an equivalent HEX value (using ASCII chart). *Note that CASTING feature is not available prior release 4.6 assign fi_character(1) to <FS> casting. *The type of the destination field will cause SAP to determine which *type (Decimal/Hexadecimal) of ASCII code should be converted: * X -> I gives Dec value * X -> C gives Hex value fe_ascii_code_dec = <FS>. fe_ascii_code_hex = <FS>. ENDFUNCTION. |
Muchas gracias Ibecerra.
Voy a probar la función, después te cuento como me va...
I.S.C.T. Luis Armando Valdez Rodríguez
Consultor ABAP correo: cel: (045) 5537406023 "La vida premia la acción"
