Pooled Capacity - LSMW
Estoy intentando crear mediante dos LSMW distintas, Pooled capacities y Resources (Recursos de trabajo). La primera LSMW que ejecuto, es para crear las Pooled capacities, y funciona correctamente (crea estas mediante la transacción CR11, marcando el tick de Pooled capacity). Con la segunda LSMW, creo las resouces, mediante la transacción CRC1, teniendo esta todas las vistas necesarias para la creación completa de una resource (Actívities, Cost centers, capacities, formulas, etc...). Uno de los campos a completar, lo podemos encontar en la pestaña de "CAPACITY", y es el campo "POOLED CAPACITY", en este campo se indica cual es la "Pooled C" para la resource que se está creando. Cuando ejecuto la LSMW, mediante "display errors only", esta separa siempre al llegar a este campo, indicandome siempre el mismo error: <<No batch input data for screen SAPLCRA0 4000 Message no. 00344 Diagnosis The transaction sent a screen that was not expected in the batch input session and which therefore could not be supplied with data. Possible reasons: 1. The batch input session was created incorrectly. The sequence of screens was recordly incorrectly. 2. The transaction behaves differently in background processing in a batch work process than when running in dialog (SY-BATCH is queried and changes the screen sequence). 3. The transaction has undergone user-specific Customizing and therefore certain screens may be skipped or processed differently, according to the current user. If the person who created a batch input session is not the same as the person now processing it, this problem may occur frequently. System Response None. Procedure For 1: Either re-create the session or process it in expert mode. Correct the batch input program. For 2. It is very difficult to analyze this problem, particularly in the case that the screen sequence or the display-only options of fields differ according to whether the transaction is being processed in the background or as an online dialog. It could also be that this kind of transaction cannot run with batch input. For 3: Have the creator of the session process it. If no error occurs now, then this is a program with user-specific Customizing.>> Ya que he ejecutado la LSMW sin completar este campo, y creando simplemente la capacidad que va ligada a la resource, y esta funciona correctamente, entiendo que el error viene dado al completar dicho campo. Honestamente, no conozco demasiado bien el uso de dicho campo (ya que hasta ahora tan solo trabajabamos con una sola capacidad por resource), e ignoro por completo como afecta este campo, por lo que si alguno de vosotros tiene experiencia con este tipo de capacidades, o tan siquiera me supiera decir como puedo ver en que afecta este campo, le estaría muy agradecido. Muchas gracias a todos por vuestra ayuda y tiempo! |
Yo te puedo ayudar me manejo en LSMW
enviame un mail |
Desplegado | |
