Bapi_incominginvoice_create
hola, estoy realizando la implementacion de la BAPI BAPI_INCOMINGINVOICE_CREATE el cual tengo el siguiente codigo.
*Cabecera L_HEADERDATA-INVOICE_IND = 'X'. L_HEADERDATA-DOC_TYPE = 'RE'. L_HEADERDATA-DOC_DATE = '20111130'. L_HEADERDATA-PSTNG_DATE = '20111130'. L_HEADERDATA-REF_DOC_NO = 'PRUEBA A'. L_HEADERDATA-COMP_CODE = '1000'. L_HEADERDATA-CURRENCY = 'COP'. L_HEADERDATA-GROSS_AMOUNT = '6000000'. L_HEADERDATA-CALC_TAX_IND = 'X'. *pedido POS LT_ITEMDATA-INVOICE_DOC_ITEM = '000006'. LT_ITEMDATA-PO_NUMBER = '5000021945'. LT_ITEMDATA-PO_ITEM = '00020'. LT_ITEMDATA-REF_DOC = '5000142047'. LT_ITEMDATA-REF_DOC_YEAR = '2011'."AÑO Fecha factura EKBE LT_ITEMDATA-REF_DOC_IT = '0001'. LT_ITEMDATA-TAX_CODE = 'V0'. LT_ITEMDATA-ITEM_AMOUNT = '6000000'."WRBTR LT_ITEMDATA-QUANTITY = '30.000'."MENGE-EKBE LT_ITEMDATA-PO_UNIT = '10'. APPEND LT_ITEMDATA. *RETENCIONES *************** LT_WITHTAXDATA-SPLIT_KEY = '000001' . LT_WITHTAXDATA-WI_TAX_TYPE = '+P' . LT_WITHTAXDATA-WI_TAX_CODE = '+P' . LT_WITHTAXDATA-WI_TAX_BASE = '6000000' . LT_WITHTAXDATA-WI_TAX_AMT = '0.00' . LT_WITHTAXDATA-WI_TAX_WITHHELD_AMT = '0.00' . APPEND LT_WITHTAXDATA. LT_WITHTAXDATA-SPLIT_KEY = '000001' . LT_WITHTAXDATA-WI_TAX_TYPE = '+Q' . LT_WITHTAXDATA-WI_TAX_CODE = '+Q' . LT_WITHTAXDATA-WI_TAX_BASE = '700000' . LT_WITHTAXDATA-WI_TAX_AMT = '0.00' . LT_WITHTAXDATA-WI_TAX_WITHHELD_AMT = '0.00' . APPEND LT_WITHTAXDATA. LT_WITHTAXDATA-SPLIT_KEY = '000001' . LT_WITHTAXDATA-WI_TAX_TYPE = '/A' . LT_WITHTAXDATA-WI_TAX_CODE = '/A' . LT_WITHTAXDATA-WI_TAX_BASE = '730000' . LT_WITHTAXDATA-WI_TAX_AMT = '0.00' . LT_WITHTAXDATA-WI_TAX_WITHHELD_AMT = '0.00' . APPEND LT_WITHTAXDATA. LT_WITHTAXDATA-SPLIT_KEY = '000001' . LT_WITHTAXDATA-WI_TAX_TYPE = '/C' . LT_WITHTAXDATA-WI_TAX_CODE = '/C' . LT_WITHTAXDATA-WI_TAX_BASE = '4570000' . LT_WITHTAXDATA-WI_TAX_AMT = '475377' . LT_WITHTAXDATA-WI_TAX_WITHHELD_AMT = '0.00' . APPEND LT_WITHTAXDATA. LT_WITHTAXDATA-SPLIT_KEY = '000001' . LT_WITHTAXDATA-WI_TAX_TYPE = '/D' . LT_WITHTAXDATA-WI_TAX_CODE = '/D' . LT_WITHTAXDATA-WI_TAX_BASE = '1818400' . LT_WITHTAXDATA-WI_TAX_AMT = '0.00' . LT_WITHTAXDATA-WI_TAX_WITHHELD_AMT = '0.00' . APPEND LT_WITHTAXDATA. LT_WITHTAXDATA-SPLIT_KEY = '000001' . LT_WITHTAXDATA-WI_TAX_TYPE = '/E' . LT_WITHTAXDATA-WI_TAX_CODE = '/E' . LT_WITHTAXDATA-WI_TAX_BASE = '200000' . LT_WITHTAXDATA-WI_TAX_AMT = '0.00' . LT_WITHTAXDATA-WI_TAX_WITHHELD_AMT = '0.00' . APPEND LT_WITHTAXDATA. LT_WITHTAXDATA-SPLIT_KEY = '000001' . LT_WITHTAXDATA-WI_TAX_TYPE = 'CE' . LT_WITHTAXDATA-WI_TAX_CODE = 'CE' . LT_WITHTAXDATA-WI_TAX_BASE = '50000' . LT_WITHTAXDATA-WI_TAX_AMT = '0.00' . LT_WITHTAXDATA-WI_TAX_WITHHELD_AMT = '0.00' . APPEND LT_WITHTAXDATA. CLEAR: LT_WITHTAXDATA, LT_ITEMDATA. CALL FUNCTION 'BAPI_INCOMINGINVOICE_CREATE' EXPORTING HEADERDATA = L_HEADERDATA * ADDRESSDATA = ADDRESSDATA * IMPORTING * INVOICEDOCNUMBER = INVOICEDOCNUMBER * FISCALYEAR = FISCALYEAR TABLES ITEMDATA = LT_ITEMDATA * ACCOUNTINGDATA = LT_ACCTDATA * GLACCOUNTDATA = GLACCOUNTDATA * MATERIALDATA = MATERIALDATA * TAXDATA = TAXDATA WITHTAXDATA = LT_WITHTAXDATA * VENDORITEMSPLITDATA = VENDORITEMSPLITDATA RETURN = RETURN . pero al realizar la prueba me genera el mensaje siguiente: 1 E M8 412 Indicador de retención impuestos requiere entrada de importe base 000000 WITHTAXDATA 000001 0 SOLSEP400 ya he probado enviando el importe de diferentes manera pero no me contabiliza. Úlima edición por frank_jruiz fecha: 12/01/12 a las 20:41:07. |
Hola el problema es que todos los indicadores deben tener la base en este caso el primero no la tiene
gracias. |
ya la Bapi esta funcionando pero no genera RETURN para hacer la conta bilizacion que puede ser ??
Solo dejo esta respuesta, por si alguien busca la información, si la tabla RETURN, llega vacía, es porque no se encontró ningún error. Debes revisar los parámetros de Export, que indican el Numero del documento creado y el año fiscal.
ATTILIO TRAVASCIO |
En estos te devuelve los datos
invoicedocnumber = lv_doc fiscalyear = lv_year ya solo si lv_doc no viene vacío, le aplicas un commit CALL FUNCTION 'BAPI_TRANSACTION_COMMIT' EXPORTING wait = 'X'. Saludos.
Los escritores somos seres heridos por ello creamos otra realidad |
