  #41
Viejo 20/06/08, 17:26:35
atomv atomv is offline
Se agradece. muiy buen esfuerzo espero a todos les ayude tanto como a mi.
  #42
Viejo 20/06/08, 20:30:08
Avatar de DavidXD_XD
Localización: Lima - Perú
Hola foro, yo tbm toy proximo a certificarme en ABAP, xfas les agradeceria si me pueden enviar los screenshots a mi correo , muchisimas gracias de antemano
David Carballido Córdova
  #43
Viejo 02/07/08, 16:20:19
ordazjl ordazjl is offline
Hola raza, yo tmb estoy proximo a certificarme en ABAP, por favor les agradeceria si me pueden enviar los screenshots a mi correo , muchisimas gracias por su apoyo.Saludos
  #44
Viejo 04/07/08, 19:32:57
Avatar de Alfredosite
Alfredosite Alfredosite is offline
Localización: Lima-Perú
algunas respuestas
SAP ABAP FAQ - Frequently Asked Questions
The ANSWERS is in BOLD.
Please note that not all questions have answers.
1. If a table does not have MANDT as part of the primary key, it is.
A: A structure
B: Invalid
C: Client-independent
D: Not mandatory
2. In regard to CALL, which of the following is NOT a valid statement?
A: CALL FUNCTION
B: CALL SCREEN
C: CALL TRANSACTION
D: CALL PROGRAM
3. Name the type of ABAP Dictionary table that has these characteristics:
Same number of fields as the database table
Same name as database table
Maps 1:1 to database table
A: Pooled
B: Cluster
C: Transparent
D: View
4. An event starts with an event keyword and ends with:
A: Program execution.
B: END-OF-EVENT.
C: Another event keyword.
D: END-EVENT.
5. What is the system field for the current date?
A: SY-DATUM
B: SY-DATE
C: SY-DATID
D: SY-SDATE
6. The following code indicates: A
SELECT fld1 fld2 FROM tab1 APPENDING TABLE itab WHERE fld1 IN sfld1.
A: Add rows to the existing rows of itab.
B: Add rows to itab after first deleting any existing rows of itab.
C: Select rows from tab1 for matching itab entries.
D: Nothing, this is a syntax error.
7. You may change the following data object as shown below so that it equals 3.14.
CONSTANTS: PI type P decimals 2 value '3.1'.
PI = '3.14'.
A: True
B: False
8. The SAP service that ensures data integrity by handling locking is called:
A: Update
B: Dialog
C: Enqueue/Dequeue
D: Spool
9. Which of these sentences most accurately describes the GET VBAK LATE. event?
A: This event is processed before the second time the GET VBAK event is processed.
B: This event is processed after all occurrences of the GET VBAK event are completed.
C: This event will only be processed after the user has selected a basic list row.
D: This event is only processed if no records are selected from table VBAK.
10. Which of the following is not a true statement in regard to a hashed internal table type?
A: Its key must always be UNIQUE.
B: May only be accessed by its key.
C: Response time for accessing a row depends on the number of entries in the table.
D: Declared using internal table type HASHED TABLE.
11. TO include database-specific SQL statements within an ABAP program, code them between:
A: NATIVE SQL_ENDNATIVE.
B: DB SQL_ENDDB.
C: SELECT_ENDSELECT.
D: EXEC SQL_ENDEXEC.
12. To measure how long a block of code runs, use the ABAP statement:
A: GET TIME .
B: SET TIME FIELD .
C: GET RUN TIME FIELD .
D: SET CURSOR FIELD .
13. When a secondary list is being processed, the data of the basic list is available by default.
A: True
B: False
14. Given:
DATA: BEGIN OF itab OCCURS 10,
qty type I,
END OF itab.
DO 25 TIMES. itab-qty = sy-index. APPEND itab.
ENDDO.
LOOP AT itab WHERE qty > 10.
WRITE: /1 itab-qty.
ENDLOOP.
This will result in:
A: Output of only those itab rows with a qty field less than 10
B: Output of the first 10 itab rows with a qty field greater than 10
C: A syntax error
D: None of the above
15. After a DESCRIBE TABLE statement SY-TFILL will contain
A: The number of rows in the internal table.
B: The current OCCURS value.
C: Zero, if the table contains one or more rows.
D: The length of the internal table row structure.
16. You may declare your own internal table type using the TYPES keyword.
A: True
B: False
17. After adding rows to an internal table with COLLECT, you should avoid adding more rows with APPEND.
A: True
B: False
18. Which of the following is not a component of control break processing when looping at an internal table?
A: AT START OF
B: AT FIRST
C: AT LAST
D: AT NEW
19. A dictionary table is made available for use within an ABAP program via the TABLES statement.
A: True
B: False
20. Which of the following would be best for hiding further selection criteria until a function is chosen?
A: AT NEW SELECTION-SCREEN
B: SELECTION-SCREEN AT LINE-SELECTION
C: SUBMIT SELECTION-SCREEN
D: CALL SELECTION-SCREEN
21. What must you code in the flow logic to prevent a module from being called unless a field contains a non-initial value (as determined by its data type)?
A: ON INPUT
B: CHAIN
C: FIELD
D: ON REQUEST
22. The AT USER-COMMAND event is triggered by functions defined in the ____.
A: screen painter
B: ABAP report
C: menu painter status
D: ABAP Dictionary
23. In regard to a function group, which of the following is NOT a true statement?
A: Combines similar function modules.
B: Shares global data with all its function modules.
C: Exists within the ABAP workbench as an include program.
D: Shares subroutines with all its function modules.
24. In regard to SET PF-STATUS, you can deactivate unwanted function codes by using ____.
A: EXCLUDING
B: IMMEDIATELY
C: WITHOUT
D: HIDE
25. In regard to data transported in PAI when the FIELD statement is used, which of the following is NOT a true statement?
A: Fields in PBO are transported directly from PAI.
B: Fields with identical names are transported to the ABAP side.
C: Fields not defined in FIELD statements are transported first.
D: Fields that are defined in FIELD statements are transported when their corresponding module is called.
26. The order in which an event appears in the ABAP code determines when the event is processed.
A: True
B: False
27. A field declared as type T has the following internal representation:
A: SSMMHH
B: HHMMSS
C: MMHHSS
D: HHSSMM
28. Which of the following is NOT a component of the default standard ABAP report header?
A: Date and Time
B: List title
C: Page number
D: Underline
29. Assuming a pushbutton with function code 'FUNC' is available in the toolbar of a list report, what event is processed when the button is clicked?
A: AT USER-COMMAND.
B: AT PFn.
C: AT SELECTION-SCREEN.
D: END-OF-SELECTION.
30. In regard to field selection, what option of the SELECT statement is required?
A: FOR ALL ENTRIES
B: WHERE
C: INTO
D: MOVE-CORRESPONDING
  #45
Viejo 02/10/08, 15:46:06
2terry1 2terry1 is offline
Hola a todos....
me certifique el viernes pasado de ABAP y tengo un BUENISIMO materialde verdad... con sus respuestas y todo...
Bueno los que esten interesados manden un correo a o a
de verdad es muy buen material...
Saludos!
  #46
Viejo 10/11/08, 16:14:55
lamosquita lamosquita is offline
Podes subir lo que guardaste? o mandar por mail?
  #47
Viejo 01/04/09, 20:33:07
raul.gomez raul.gomez is offline
Screenshots
Agradeceria que me enviaran los screen desde ya muchas gracias
  #48
Viejo 16/04/09, 02:14:34
marc_rmz marc_rmz is offline
screenshots de mi examen
lo siento no habia podido subirlas y mandarselas el trabajo pero aqui las subo para que se descarguen directamente
bueno no pude subirlo al foro pero lo subi a otro lugar
son 39 preguntas
disculpen si no les hice caso pero aqui esta
ojo no todas las preguntas estan correctas lo cual sugiero que las chequen muy bien.
Úlima edición por marc_rmz fecha: 16/04/09 a las 02:29:56.
  #49
Viejo 28/04/09, 22:43:48
o21joaco o21joaco is offline
Localización: Mexico
Chequen http://www.codeexcellence.com/
chequen .
Muy buena.
Joaco...
  #50
Viejo 05/06/09, 07:21:23
Luz031 Luz031 is offline
holaaa
hola amigo oye porfis estoy a punto de mi examen de certificacion no se si me podrias proporcionar las preguntas que dices grax
Husos Horarios son GMT. La hora en este momento es 16:56:39.
