no consigo cargar las tablas en el contenedor
Hola muchas gracias , tengo el problema de que no cargo los datos de la tabla sflight en el contenedor , alguien puede echarle un ojo que puede sucerderme , aqui esta el include , si creis que el error puede estar en la pai o pbo .... decidmelo , muchas gracias
***INCLUDE ZFRAN_SFLIGHT . *----------------------------------------------------------------------* DATA: IT_SFLIGHT TYPE TABLE OF SFLIGHT, HE_SFILGHT LIKE LINE OF it_sflight. DATA: IT_TABLA TYPE LVC_T_FCAT, HE_TABLA LIKE LINE OF IT_TABLA. DATA: CONTENEDOR TYPE REF TO CL_GUI_CUSTOM_CONTAINER, ALV TYPE REF TO CL_GUI_ALV_GRID. * ESTO MEJORA LA ESTETICA DE LA TABLA DATA LAYOUT TYPE LVC_S_LAYO. START-OF-SELECTION. *CREAMOS LOS OBJETOS create object contenedor exporting container_name = 'CONTENEDOR'. create object alv exporting i_parent = CONTENEDOR. LAYOUT-ZEBRA = 'X'. LAYOUT-SEL_MODE = 'C'. *CARGAMOS LAS TABLAS CON LOS CAMPOS DESEADOS HE_TABLA-FIELDNAME = 'CARRID'. HE_TABLA-REF_TABLE = 'SFLIGHT'. APPEND HE_TABLA TO IT_TABLA. CLEAR HE_TABLA. HE_TABLA-FIELDNAME = 'CONNID'. HE_TABLA-REF_TABLE = 'SFLIGHT'. APPEND HE_TABLA TO IT_TABLA. CLEAR HE_TABLA. HE_TABLA-FIELDNAME = 'FLDATE'. HE_TABLA-REF_TABLE = 'SFLIGHT'. APPEND HE_TABLA TO IT_TABLA. CLEAR HE_TABLA. HE_TABLA-FIELDNAME = 'PRICE'. HE_TABLA-REF_TABLE = 'SFLIGHT'. APPEND he_tabla TO IT_TABLA. CLEAR HE_TABLA. HE_TABLA-FIELDNAME = 'CURRENCY'. HE_TABLA-REF_TABLE = 'SFLIGHT'. append he_tabla TO IT_TABLA. CLEAR HE_TABLA. SELECT * INTO TABLE IT_SFLIGHT FROM SFLIGHT . call method alv->set_table_for_first_display exporting is_layout = LAYOUT changing it_outtab = IT_SFLIGHT. it_fieldcatalog = IT_TABLA. end-of-selection. *&---------------------------------------------------------------------* *& Module PBO_SFLIGHT OUTPUT *&---------------------------------------------------------------------* * text *----------------------------------------------------------------------* module PBO_SFLIGHT output. SET PF-STATUS PBO_SFLIGHT. endmodule. " PBO_SFLIGHT OUTPUT *&---------------------------------------------------------------------* *& Module PAI_SFLIGHT INPUT *&---------------------------------------------------------------------* * text *----------------------------------------------------------------------* module PAI_SFLIGHT input. SA_CODE = OK_CODE. CLEAR OK_CODE. CASE SA_CODE. WHEN 'BACK' OR 'CANCEL' OR 'EXIT'. LEAVE PROGRAM. ENDCASE. endmodule. " PAI_SFLIGHT INPUT |
mira si te sirve esto...
Buenas!!
he leído un poco por encima tu problema xq no tengo mucho tiempo para echarle un ojo pero creo (no estoy segura) que te puede faltar definirte la Dynpro en la transacción SE80, te mando este enlace que viene todo explicado a ver si te ayuda y a ver si eso te pasaba ![]() Saludos! |
Hola ... revisate los ejemplos estandar de SAP que comienzan con BCALV*, para tu caso creo q eson los BCALV_GRID_01, BCALV_GRID_02, etc .... espero te ayude ...
David Carballido Córdova ![]() |
