Problemas De Instalacion Minisap
  • daniel_daniel1
    • 31
    QUE TAL BUENAS TARDES, VUELVO A POSTEAR PORQUE TENGO UN PROBLEMA CON LA INSTALACION DEL MINSAP, HE PROVADO INSTALARLO YA UNAS 15 VECES Y SIEMPRE ME DICE LOS MISMOS LOGS DE ERRORES, TENGO INTALADA LA MAQUINA VIRTUAL DE JAVA 1.4_2_8 Y CREE LAS VARIABLES DE ENTORNO DE ESTA FORMA:
    NOMBRE DE LA VARIABLE: JAVA HOME
    VALOR DE VARIABLE: C:\JRDK_1.4_2_8
    IGUAL ANTES DE CREAR ESA VARIABLE DE ENTORNO ME DECIA LO MISMO, LA VERDAD ESTOY DESESPERADO, PORQUE NO SE QUE HACER, AGRADECERIA CUALQUIER TIPO DE AYUDA, MUCHAS GRACIAS.
    ACA DEJO LOS LOGS DE ERRORES:
    (Jun 11, 2008 8:17:41 PM), Install, com.sap.installshield.sdcstepswrapper.StepWrapperI nstallFiles, err, An error occurred and product installation failed. Look at the log file C:\SAP\NSP\log.txt for details.
    (Jun 11, 2008 8:17:41 PM), Install, com.sap.installshield.sdcstepswrapper.StepWrapperI nstallFiles, err, ProductException: (error code = 200; message="Java error"; exception = [java.lang.Exception])
    STACK_TRACE: 15
    at com.sap.installshield.sdcstepswrapper.StepWrapperI nstallFiles.execute(StepWrapperInstallFiles.java:2 54)
    at com.sap.installshield.sdcstepswrapper.StepWrapperI nstallFiles.executeAllSteps(StepWrapperInstallFile s.java:224)
    at com.sap.installshield.sdcstepswrapper.StepWrapperI nstallFiles.executeAllInstallationSteps(StepWrappe rInstallFiles.java:177)
    at com.sap.installshield.sdcstepswrapper.StepWrapperI nstallFiles.install(StepWrapperInstallFiles.java:2 68)
    at com.installshield.product.service.product.PureJava ProductServiceImpl.installProductAction(Unknown Source)
    at com.installshield.product.service.product.PureJava ProductServiceImpl$InstallProduct.getResultForProd uctAction(Unknown Source)
    at com.installshield.product.service.product.Installa bleObjectVisitor.visitComponent(Unknown Source)
    at com.installshield.product.service.product.Installa bleObjectVisitor.visitInstallableComponents(Unknow n Source)
    at com.installshield.product.service.product.Installa bleObjectVisitor.visitProductBeans(Unknown Source)
    at com.installshield.product.service.product.PureJava ProductServiceImpl$InstallProduct.install(Unknown Source)
    at com.installshield.product.service.product.PureJava ProductServiceImpl$Installer.execute(Unknown Source)
    at com.installshield.wizard.service.AsynchronousOpera tion.run(Unknown Source)
    at java.lang.Thread.run(Unknown Source)
    (Jun 11, 2008 8:22:42 PM), Install, com.installshield.product.service.product.PureJava ProductServiceImpl$InstallProduct, err, An error occurred and product uninstallation failed. Look at the log file C:\SAP\NSP\log.txt for details.
    (Jun 11, 2008 8:22:42 PM), Install, com.sap.installshield.sdcstepswrapper.StepWrapperI nstallFiles, err, ProductException: (error code = 200; message="Java error"; exception = [java.lang.Exception])
    STACK_TRACE: 15
    at com.sap.installshield.sdcstepswrapper.StepWrapperI nstallFiles.executeAllUninstallationSteps(StepWrap perInstallFiles.java:192)
    at com.sap.installshield.sdcstepswrapper.StepWrapperI nstallFiles.uninstall(StepWrapperInstallFiles.java :313)
    at com.installshield.product.service.product.PureJava ProductServiceImpl.uninstallProductAction(Unknown Source)
    at com.installshield.product.service.product.PureJava ProductServiceImpl$InstallProduct.processActionsFa iled(Unknown Source)
    GRACIAS POR SU TIEMPO.
