ERROR Database Instance SAP IDES4.71
  • cocke
    • nov
    • 87
    Hola!
    Tengo un problema en la instalación con SAP IDES 4.71 y la verdad no sé que puede ser.
    Lo re-instalé 10 veces y aún no consigo pasar la última parte, ya que me arroja el siguiente error luego de seleccionar los paquetes EXPORT.
    Adjunto log:
    INFO 2009-11-25 00:15:37
    Processing of host operation t_HostInfo_SHARED succeeded.
    INFO 2009-11-25 00:15:45
    The 'saploc' share exists at directory 'C:\usr\sap'. Choosing drive C: as SAP System drive.
    INFO[E] 2009-11-25 00:16:18
    Account group="p3lao\SAP_LDAP" does not exist. <#1>
    INFO[E] 2009-11-25 00:16:36
    Account group="p3lao\dbc11ctl" does not exist. <#1>
    INFO 2009-11-25 00:19:23
    Copying file C:/Varios/disk1/EXPORT1/DB/ORA/DBSIZE.XML to: DBSIZE.XML.
    Creating file C:\SAPinst ORACLE SAPINST\DBSIZE.XML.
    Copying file system node C:\Varios\disk1\EXPORT1/DB/ORA/DBSIZE.XML with type NODE to DBSIZE.XML succeeded.
    Processing of all file system node operations of table tORA_filecopy succeeded.
    INFO 2009-11-25 00:19:24
    Copying file C:/Varios/disk1/EXPORT1/DB/DDLORA.TPL to: DDLORA.TPL.
    Creating file C:\SAPinst ORACLE SAPINST\DDLORA.TPL.
    Copying file system node C:\Varios\disk1\EXPORT1/DB/DDLORA.TPL with type NODE to DDLORA.TPL succeeded.
    INFO 2009-11-25 00:19:28
    Moving file C:/SAPinst ORACLE SAPINST/DDLORA.TPL to: orig_ddl_ora_tmp.tpl.
    Moving file C:/SAPinst ORACLE SAPINST/changed_ddl_ora_tmp.tpl to: DDLORA.TPL.
    Removing file C:/SAPinst ORACLE SAPINST/orig_ddl_ora_tmp.tpl.
    ERROR 2009-11-25 00:20:50
    MSC-01002 Couldn't create package table, no packages found in: C:\Varios\disk1\EXPORT1 C:\Varios\disk2\EXPORT2 C:\Varios\disk3\EXPORT3 C:\Varios\disk3\EXPORT4 C:\Varios\disk3\EXPORT5 C:\Varios\disk3\EXPORT6 C:\Varios\disk3\EXPORT7
    FJS-00012 Error when executing script.
    FCO-00011 The step fillR3loadPackageTable with step key SAPSYSTEM|ind|ind|ind|ind|ind|0|SAPComponent|ind|i nd|ind|ind|ind|0|DatabaseLoad|ind|ind|ind|ind|ind| 0|fillR3loadPackageTable executed with status ERROR.
    Para la instalación he seguido el manual en PDF disponible en esta Web -> http://www.mundosap.com/foro/images/...ap_ides_47.pdf
    Si alguien me puede ayudar sería excelente ya que he gogleado bastante pero no he encontrado exactamente el mismo error.
    Cocke
