Rol Customazing Only Display
  • sapitoo
    • nov
    • 104
    Hola solicito su apoyo para saber si existe alguna tip para hacer un rol, de solo display del customazig.
    muchas gracias por su apoyo
    saludos.
  • SAP Inicial
    • abr
    • 813
    Roles
    No se si existe un ROl estandar ..
    Pero es facil crear un ROL con solo la SPRO y en la pestaña,,autorizaciones
    dajas todo VISUALIZACION....
    attte
    _________
    www.ayudasap.net
    • johangonz
      • 816
      Originalmente publicado por sapitoo
      saludos.
      He seguido este procedimiento cuando me lo han solicitado y me ha funcionado:
      Authorization to only display customizing (SPRO)
      Anyone can advise on what profile or role I should assign to my consultants, for them to display the customizing in production?
      === 1. There are no SAP-roles for customizing (update or display).
      2. You can create a customizing role in PFCG:
      in the menu tab utilities/customizing auth; you can use a project IMG (maintainable in SPRO) to restrict the authorizations for example to FI or CO.
      As the roles can get pretty big it is quite a lot of work to check the generated authorizations and to limit them if necessary (e.g. only display) and to delete authorizations which certain users (e.g. consultants) do not need. This is especially important if they have other roles which in combination may allow "unwanted access" to certain things.
      What is basically necessary for customizing display is SM30, S_TABU_DIS for the relevant authorization groups (activity 03) plus if you want to read the tables out of the IMG the relevant S_TCODE-authorizations. Additionally many transactions require various other authorization objects (which are generated out of SU24 - which is not "100% accurate" as SAP states).
      === We use version 3.1. but there is no posting in any web site suitable for creating IMG All display only profile for Ver 3.1
      Can any one please share there knowledge.
      === The 3.1 version I beleive is a different structure than the higher versions so I am not sure the CUST_ACTOBJ table exists. You will have to debut the IMG to find the source where the tcodes are housed. There are MANY transactions associated with the IMG and S_TABU_DIS is only a part.
      Version 3.i is VERY difficult to use to get SU24 to load the role so you can make a display IMG.
      It would be simplet to copy SAP_ALL and change the activities to '03'.
      === But even in SAP_ALL the customizing for IMG (S_IMG_ACTV) object value is only having Change or nothing..!! There is no option to display... their are few more objects like this. If I dont have any value selected, the profile is not be effective. Nothing can be done. Any more suggestions..
      === And S_IMG_ACTV means very little. You can configure with or without it and since configuration is tcode driven and accessable anywhere in the system. You have to give S_IMG_ACTV '02', it means little
      === I beleive you need S_IMG_GENE to actually change the config. We have two roles (4.6C) ... one for display only and one for changing.
      === Create f.ex a role "CUSTOMIZING" and run the following ABAP.
      It will bring to your role all SPRO tarnsactions. Then go through the auth objects and change them display only. This way you'll have a display only role.
      REPORT ZTCODES .
      tables: cus_actobj, agr_tcodes.
      data: ica like cus_actobj occurs 1000 with header line,
      iagrtc like agr_tcodes occurs 4000 with header line.
      select * from cus_actobj into table ica.
      sort ica by tcode.
      delete adjacent duplicates from ica comparing tcode.
      iagrtc-agr_name = 'CUSTOMIZING'.
      iagrtc-TYPE = 'TR'.
      iagrtc-direct = 'X'.
      loop at ica.
      iagrtc-tcode = ica-tcode.
      append iagrtc.
      endloop.
      modify agr_tcodes from table iagrtc.
      Note, there is another table cus_acth as well that you load into your internal table and you need to add a sort tcodes and delete adjacent duplicated. then load to your role.
      Debes crear el rol previamente en blanco. Lo que definas en iagrtc-agr_name debe hacer match con el nombre del rol.
      Johan González
      CEO
      NW Consulting Services
      www.nwcs.website
      Siguenos en Facebook: www.facebook.com/nwconsultingservices
      Moderador www.mundosap.com
      • SAP Inicial
        • abr
        • 813
        Sugerencias..
        Johan González..
        Por q tan gringo......no puede en EspaIndio...
        _________
        www.ayudasap.net
        • sapitoo
          • nov
          • 104
          Hola, muchas gracias, permiteme revisarlo y aplicarlo, muchas gracias por la respuesta, excelente dia, saludos.
          • SAP Inicial
            • abr
            • 813
            Traduccion - para Ispanos..
            Autorización para mostrar sólo la personalización (SPRO)
            Cualquier persona puede aconsejar sobre qué perfil o rol que debería asignar a mis asesores, para ellos para mostrar la personalización en la producción?
            === 1. No hay SAP funciones de personalización (actualización o pantalla).
            2. Usted puede crear una función de personalización en PFCG:
            en la pestaña del menú de utilidades de personalización / auth, se puede utilizar un IMG proyecto (mantenible en SPRO) para restringir las autorizaciones, por ejemplo, a FI o CO
            A medida que los roles pueden ser bastante grande que es bastante un montón de trabajo para revisar las autorizaciones generadas por y para limitar si es necesario (por ejemplo, sólo pantalla) y suprimir las autorizaciones que ciertos usuarios (por ejemplo, consultores) no es necesario. Esto es especialmente importante si se tienen otras funciones que en combinación pueden permitir "el acceso no deseado" para ciertas cosas.
            ¿Qué es básicamente necesario para la personalización de la pantalla es SM30, S_TABU_DIS para los grupos de autorización pertinente (actividad 03), más si quieres leer las tablas de las IMG las correspondientes autorizaciones S_TCODE-. Adicionalmente muchas de las transacciones requieren varios otros objetos de autorización (que se generan fuera de SU24 - que no es "100% exacto" como estados SAP).
            === Utilizamos la versión 3.1. pero no se puede publicar en cualquier sitio web adecuado para crear IMG Todos perfil de visualización sólo para Ver. 3.1
            ¿Puede alguien por favor compartir conocimientos allí.
            La versión 3.1 === yo creo es una estructura diferente que las versiones más altas, así que no estoy seguro de la tabla CUST_ACTOBJ existe. Usted tendrá que debutará el IMG para encontrar la fuente donde se alojan los tcodes. Existen muchas transacciones asociadas con el IMG y S_TABU_DIS es sólo una parte.
            Versión 3.i es muy difícil de usar para obtener SU24 para cargar el papel para que pueda hacer una pantalla de IMG.
            Sería simplet copiar SAP_ALL y cambiar las actividades a '03 '.
            === Pero incluso en la personalización para SAP_ALL valor IMG objeto (S_IMG_ACTV) es sólo tener Cambio o nada ..! No hay ninguna opción para mostrar ... sus pocos más objetos de este tipo. Si no tiene ningún valor seleccionado, el perfil no es ser eficaz. Nada se puede hacer. Cualquier sugerencia más ..
            Y === S_IMG_ACTV significa muy poco. Se puede configurar con o sin ella, y puesto que la configuración es impulsado TCODE y accesible en cualquier parte del sistema. Usted tiene que dar S_IMG_ACTV '02 ', significa poco
            === Yo creo que necesitas S_IMG_GENE para cambiar realmente la config. Tenemos dos roles (4.6C) ... uno para la pantalla solamente y otro para cambiar.
            Crear === f.ex un papel "Personalizar" y ejecute el siguiente ABAP.
            Traerá a su papel todas tarnsactions SPRO. A continuación, vaya a través de los objetos de autenticación y cambiarlos mostrar solamente. De esta manera usted tendrá una función de sólo visualización.
            INFORME ZTCODES.
            tablas: cus_actobj, agr_tcodes.
            datos: ica como ocurre cus_actobj 1000 con línea de cabecera,
            iagrtc como ocurre agr_tcodes 4000 con línea de cabecera.
            select * from cus_actobj en la tabla de ICA.
            ordenar por TCODE ica.
            eliminar duplicados adyacentes de ica comparar TCODE.
            iagrtc-agr_name = 'PERSONALIZAR'.
            iagrtc-TYPE = 'TR'.
            lazo en ica.
            iagrtc-TCODE = ica-TCODE.
            añadir iagrtc.
            endloop.
            modificar agr_tcodes de iagrtc mesa.
            Tenga en cuenta que hay otra cus_acth mesa, así que cargue en su tabla interna y hay que añadir unas tcodes ordenar y eliminar duplicados adyacentes. a continuación, cargue con su rol.
            Debes CREAR el rol previamente en blanco. Lo Que definas en iagrtc-agr_name debe HACER partido con el Nombre del rol.
            _________
            www.ayudasap.net
            • johangonz
              • 816
              Originalmente publicado por SAP Inicial
              Johan González..
              Pana sentarme a traducir es imposible, ademas el traductor lo hizo a un español raro, al rol lo llama papel jajajaja...
              Espero te haya funcionado así.
              Johan González
              CEO
              www.nwcs.website
              • bruky
                • 555
                Sinceramente, si se quiere un rol para la SPRO (solo visualización) entiendo segun tu restricción que es un rol para el entorno de Desarrollo.
                Sinceramente yo crearía un rol ZSAP_ALL_DISPLAY
                Dando acceso a todas las transacciones del sistema de forma visualización (en internet puedes conseguir este tipo de roles).
                No se si te valdrá la idea, pero creo que es la forma mas rapida y facil de hacerlo.
                un saludo.
                • bruky
                  • 555
                  Adjunto un ZSAP_ALL_DISPLAY que tengo en mi ordenador:
                  ZSAP_ALL_DISPLAY:
                  Espero que sirva de ayuda.
                  Un saludo.
