Mandar Mails desde SAP
  • oieraz
    • nov
    • 54
    Buenos días, me han encomendado realizar un report que únicamente envíe un mail con un título y un texto. No he trabajado nunca con mails por lo que agradecería vuestra ayuda. Gracias por adelantado.
    Un saludo.
  • Atlas
    • ago
    • 107
    puedes utilizar esta función, pero sin el objbin que no te hace falta:
    doc_chng-obj_descr = 'test'.
    objtxt = 'Texto adicional.'.
    APPEND objtxt.
    DESCRIBE TABLE objtxt LINES tab_lines.
    READ TABLE objtxt INDEX tab_lines.
    doc_chng-doc_size = ( tab_lines - 1 ) * 255 + STRLEN( objtxt ).
    objpack-body_start = 1.
    objpack-head_start = 1.
    objpack-head_num = 0.
    objpack-body_num = tab_lines.
    objpack-doc_type = 'RAW'.
    objpack-obj_name = 'body'.
    objpack-obj_descr = 'Texto'.
    objpack-doc_size = ( tab_lines - 1 ) * 255 + STRLEN( objtxt ).
    APPEND objpack.
    loop at t_all_spool.
    *if first = 'X'.
    * objpack-body_start = 1.
    * clear first.
    *else.
    objpack-body_start = tab_lines + 1.
    *endif.
    t_spool[] = t_all_spool-spool[].
    append lines of t_spool[] TO objbin[].
    * Esta es la lista
    DESCRIBE TABLE objbin LINES tab_lines.
    * Datos adjuntos
    objpack-transf_bin = 'X'.
    objpack-doc_type = 'ALI'.
    objpack-obj_name = 'Datos adjuntos'.
    objpack-obj_descr = 'spool ABAP'.
    READ TABLE objbin INDEX tab_lines.
    doc_size = ( tab_lines - 1 ) * 255 + STRLEN( objbin ).
    objpack-doc_size = doc_size.
    APPEND objpack.
    endloop.
    reclist-receiver = 'direccion@gmail.com'.
    reclist-rec_type = 'U'.
    RECLIST-EXPRESS = 'X'.
    RECLIST-REC_DATE = sy-datum.
    APPEND reclist.
    CALL FUNCTION 'SO_NEW_DOCUMENT_ATT_SEND_API1'
    EXPORTING
    document_data = doc_chng
    PUT_IN_OUTBOX = 'X'
    COMMIT_WORK = 'X'
    * IMPORTING
    * SENT_TO_ALL =
    * NEW_OBJECT_ID =
    tables
    packing_list = objpack
    OBJECT_HEADER = objhead
    CONTENTS_BIN = objbin
    CONTENTS_TXT = objtxt
    * CONTENTS_HEX =
    * OBJECT_PARA =
    * OBJECT_PARB =
    receivers = reclist
    EXCEPTIONS
    TOO_MANY_RECEIVERS = 1
    DOCUMENT_NOT_SENT = 2
    DOCUMENT_TYPE_NOT_EXIST = 3
    OPERATION_NO_AUTHORIZATION = 4
    PARAMETER_ERROR = 5
    X_ERROR = 6
    ENQUEUE_ERROR = 7
    OTHERS = 8
    IF sy-subrc <> 0.
    MESSAGE ID SY-MSGID TYPE SY-MSGTY NUMBER SY-MSGNO
    WITH SY-MSGV1 SY-MSGV2 SY-MSGV3 SY-MSGV4.
    • oieraz
      • nov
      • 54
      dudas
      Esto te sirve para enviar mails a SAP o al Outlook? Lo que me interesa es que sean enviado al Outlook.
      Originalmente publicado por Atlas
      APPEND objtxt.
      APPEND objpack.
      *if first = 'X'.
      * clear first.
      *else.
      *endif.
      * Esta es la lista
      * Datos adjuntos
      APPEND objpack.
      endloop.
      APPEND reclist.
      EXPORTING
      PUT_IN_OUTBOX = 'X'
      COMMIT_WORK = 'X'
      * IMPORTING
      * SENT_TO_ALL =
      * NEW_OBJECT_ID =
      tables
      * CONTENTS_HEX =
      * OBJECT_PARA =
      * OBJECT_PARB =
      receivers = reclist
      EXCEPTIONS
      PARAMETER_ERROR = 5
      X_ERROR = 6
      ENQUEUE_ERROR = 7
      OTHERS = 8
      IF sy-subrc <> 0.
      • abaper_biz
        • oct
        • 27
        correo
        Hola, esa funcion envia correo a la direccion que ingreses, sea outlook, u otros....aqui un post similar..
        Jhon Riders Juscamaita Rico
        CONSULTOR SAP / ABAP4 DEVELOPER
