Viejo 26/08/14, 22:27:19
Liquiddry Liquiddry is offline
Localización: Mexico
Dump CONNE_IMPORT_WRONG_OBJECT_TYPE
Hola a todos,
Quisiera saber quien me puede apoyar con este problema que tengo al momento de ejecutar una transaccion Z la cual me marca un Dump que dice lo siguiente:
Runtime Errors CONNE_IMPORT_WRONG_OBJECT_TYPE
Except. CX_SY_IMPORT_MISMATCH_ERROR
Short text
Error when attempting to IMPORT object "RID0".
What happened?
Error in the ABAP Application Program
The current ABAP program "SAPLZPSIU" had to be terminated because it has
come across a statement that unfortunately cannot be executed.
Try to find out why the type of the object is incorrect.
There are various possible options:
1. The type of the imported object has changed in the Data Dictionary.
Make sure that the type of the imported object matches the type
of the object in the Data Dictionary.
If the data cannot be restored from another source, the data must be
read by the 'old' structure, converted und again eported with the new
structure, so that future IMPORTs will always function with the new
structure.
2. A new program version is active, which no longer fits the dataset.
Try to solve the error generating the program "SAPLZPSIU" again. This
works as follows: Select transaction SE38 in the SAP system. Enter
the program name "SAPLZPSIU". Then activate the function 'Generate'.
En el codigo marca el error en lo siguiente
88 * verifica o status de processamento da interface
>> load_restart_data.
el cual el load_restart_data tiene:
define load_restart_data.
import
dtmh to mc_dtmh
tcnt to mi_tcnt
ecnt to mi_ecnt
scnt to mn_scnt
sqid to mc_sqid
name to mc_name
hstc to mi_hstc
ldfs to mh_ldfs
rid0 to restart_id0
rid1 to restart_id1
rid2 to restart_id2
rid3 to restart_id3
rid4 to restart_id4
from database zb002(sg) id zb000-intid.
end-of-definition.
Pero no se donde definen el objeto de importe RID0... Ojala pudieran apoyarme en este problema ya tengo tiempo con esto
Muchas gracias a todos.
Viejo 27/08/14, 00:41:17
vanesamacri vanesamacri is offline
Buenas noches.
El dump ocurre dentro de el código fuente SAPLZPSIU. Los reportes cuyos nombres comienzan con SAPLZ generalmente corresponden a los códigos fuentes de grupos de funciones custom (Z). En este caso, todo indica que se trata del grupo de funciones ZPSIU.
Tranquilamente lo que puede haber ocurrido es que se le haya realizado algún tipo de mantenimiento a este grupo de funciones, lo que debe haber generado la inconsistencia que deriva en el dump.
Probá realizando la sugerencia que te indica en el detalle del dump:
Si lo anterior no funciona, quizás leyendo el código fuente de algunas de las funciones que componen a este grupo de funciones puedas encontrar alguna pista acerca del origen del objeto "RID0". La excepción del dump pareciera indicar que el error está ocurriendo por una incompatibilidad de tipos entre el dato importado con el del tipo de dato destino de la importación.
Adicionalmente, te recomiendo que también averigües si es que se ha realizado un seguimiento de las modificaciones a ese grupo de funciones, el cual pueda abrirte mejor la cabeza en cuanto a lo que está ocurriendo.
Espero que puedas resolverlo. Un saludo.
Viejo 27/08/14, 21:00:48
Hola vanesamacri:
Gracias por tu respuesta, pero la sugerencia que me dio el DUMP ya lo he hecho y sigo con el problema incluso ahorita con tu ayuda al explicar lo de como identificar los grupos de función fui validando si tenían algún error o si estaban desactivados y todo esta correcto de ahí...
A lo que me dices de buscar de "RID0" ya también me di la tarea de buscarlo en todas las funciones , include y todo y no encuentro donde lo declaran en el codigo... por lo que pienso que son variables definidas (en alguna parte que no encuentro) y poder ver que hay diferente entre ambientes, ya que este problema se presenta sólo en PRD y en QA si funciona....
Realmente no se como solucionarlo...
Seguire investigando, si descubro cómo, vengo y lo explico y de igual manera agradecería su apoyo.
Husos Horarios son GMT. La hora en este momento es 01:14:19.
