Viejo 14/11/11, 17:59:01
sapidesmexico sapidesmexico is offline
Dispatcher no trabaja SAP ECC 6.0
Hola a todos tengo un SAP ECC 6.0 con Oracle 10g todo funcionaba bien durante 10 meses lo apagaba y prendía sin problema. Un día lo apagué al momento de encenderlo me marca q el dispatcher esta parado
le hice un Trace y me marca el siguiente error:
alguien podria ayudarme?
trc file: "dev_disp", trc level: 1, release: "701"
sysno 00
sid WY2
systemid 562 (PC with Windows NT)
relno 7010
patchlevel 0
patchno 32
intno 20020600
make: multithreaded, Unicode, 64 bit, optimized
pid 1564
Mon Nov 14 10:46:14 2011
kernel runs with dp version 241000(ext=110000) (@(#) DPLIB-INT-VERSION-241000-UC)
length of sys_adm_ext is 576 bytes
*** SWITCH TRC-HIDE on ***
***LOG Q00=> DpSapEnvInit, DPStart (00 1564) [dpxxdisp.c 1286]
shared lib "dw_xml.dll" version 32 successfully loaded
shared lib "dw_xtc.dll" version 32 successfully loaded
shared lib "dw_stl.dll" version 32 successfully loaded
shared lib "dw_gui.dll" version 32 successfully loaded
shared lib "dw_mdm.dll" version 32 successfully loaded
rdisp/softcancel_sequence : -> 0,5,-1
use internal message server connection to port 3900
Mon Nov 14 10:46:19 2011
*** WARNING => DpNetCheck: NiAddrToHost(1.0.0.0) took 5 seconds
***LOG GZZ=> 1 possible network problems detected - check tracefile and adjust the DNS settings [dpxxtool2.c 5529]
MtxInit: 30000 0 0
DpSysAdmExtInit: ABAP is active
DpSysAdmExtInit: VMC (JAVA VM in WP) is not active
DpIPCInit2: start server >sapserverid_WY2_00 <
DpShMCreate: sizeof(wp_adm) 29792 (1752)
DpShMCreate: sizeof(tm_adm) 5912704 (29416)
DpShMCreate: sizeof(wp_ca_adm) 24064 (80)
DpShMCreate: sizeof(appc_ca_adm) 8000 (80)
DpCommTableSize: max/headSize/ftSize/tableSize=500/16/552064/552080
DpShMCreate: sizeof(comm_adm) 552080 (1088)
DpSlockTableSize: max/headSize/ftSize/fiSize/tableSize=0/0/0/0/0
DpShMCreate: sizeof(slock_adm) 0 (104)
DpFileTableSize: max/headSize/ftSize/tableSize=0/0/0/0
DpShMCreate: sizeof(file_adm) 0 (72)
DpShMCreate: sizeof(vmc_adm) 0 (1864)
DpShMCreate: sizeof(wall_adm) (41664/36752/64/192)
DpShMCreate: sizeof(gw_adm) 48
DpShMCreate: SHM_DP_ADM_KEY (addr: 00000000092B0050, size: 6614144)
DpShMCreate: allocated sys_adm at 00000000092B0050
DpShMCreate: allocated wp_adm at 00000000092B2270
DpShMCreate: allocated tm_adm_list at 00000000092B96D0
DpShMCreate: allocated tm_adm at 00000000092B9730
DpShMCreate: allocated wp_ca_adm at 000000000985CFB0
DpShMCreate: allocated appc_ca_adm at 0000000009862DB0
DpShMCreate: allocated comm_adm at 0000000009864CF0
DpShMCreate: system runs without slock table
DpShMCreate: system runs without file table
DpShMCreate: allocated vmc_adm_list at 00000000098EB980
DpShMCreate: allocated gw_adm at 00000000098EBA00
DpShMCreate: system runs without vmc_adm
DpShMCreate: allocated ca_info at 00000000098EBA30
DpShMCreate: allocated wall_adm at 00000000098EBA40
MBUF state OFF
DpCommInitTable: init table for 500 entries
rdisp/queue_size_check_value : -> off
ThTaskStatus: rdisp/reset_online_during_debug 0
EmInit: MmSetImplementation( 2 ).
MM global diagnostic options set: 0
<ES> client 0 initializing ....
<ES> InitFreeList
<ES> block size is 4096 kByte.
<ES> Info: em/initial_size_MB( 4085MB) not multiple of em/blocksize_KB( 4096KB)
<ES> Info: em/initial_size_MB rounded up to 4088MB
Using implementation view
<EsNT> Using memory model view.
<EsNT> Memory Reset disabled as NT default
<ES> 1021 blocks reserved for free list.
ES initialized.
Mon Nov 14 10:46:20 2011
rdisp/http_min_wait_dia_wp : 1 -> 1
***LOG CPS=> DpLoopInit, ICU ( 3.0 3.0 4.0.1) [dpxxdisp.c 1681]
***LOG Q0K=> DpMsAttach, mscon ( sapserverid) [dpxxdisp.c 12483]
DpStartStopMsg: send start message (myname is >sapserverid_WY2_00 <)
DpStartStopMsg: start msg sent
CCMS: AlInitGlobals : alert/use_sema_lock = TRUE.
CCMS: Initalizing shared memory of size 60000000 for monitoring segment.
CCMS: Checking Downtime Configuration of Monitoring Segment.
CCMS: start to initalize 3.X shared alert area (first segment).
DpMsgAdmin: Set release to 7010, patchlevel 0
MBUF state PREPARED
MBUF component UP
DpMBufHwIdSet: set Hardware-ID
***LOG Q1C=> DpMBufHwIdSet [dpxxmbuf.c 1048]
DpMsgAdmin: Set patchno for this platform to 32
Release check o.K.
Mon Nov 14 10:47:00 2011
my types changed after wp death/restart 0xbf --> 0xbe
my types changed after wp death/restart 0xbe --> 0xbc
my types changed after wp death/restart 0xbc --> 0xb8
my types changed after wp death/restart 0xb8 --> 0xb0
my types changed after wp death/restart 0xb0 --> 0xa0
my types changed after wp death/restart 0xa0 --> 0x80
*** DP_FATAL_ERROR => DpWPCheck: no more work processes
*** DISPATCHER EMERGENCY SHUTDOWN ***
increase tracelevel of WPs
NiWait: sleep (10000ms) ...
NiISelect: timeout 10000ms
NiISelect: maximum fd=449
NiISelect: read-mask is NULL
NiISelect: write-mask is NULL
Mon Nov 14 10:47:10 2011
NiISelect: TIMEOUT occured (10000ms)
dump system status
Workprocess Table (long) Mon Nov 14 16:47:10 2011
No Ty. Pid Status Cause Start Err Sem CPU Time Program Cl User Action Table
0 DIA 1900 Ended no 1 0 0
1 DIA 2696 Ended no 1 0 0
2 DIA 2916 Ended no 1 0 0
3 DIA 2976 Ended no 1 0 0
4 DIA 1548 Ended no 1 0 0
5 DIA 500 Ended no 1 0 0
6 DIA 1728 Ended no 1 0 0
7 DIA 2964 Ended no 1 0 0
8 DIA 1044 Ended no 1 0 0
9 DIA 1608 Ended no 1 0 0
10 UPD 2604 Ended no 1 0 0
11 ENQ 2440 Ended no 1 0 0
12 BTC 604 Ended no 1 0 0
13 BTC 588 Ended no 1 0 0
14 BTC 1720 Ended no 1 0 0
15 SPO 2948 Ended no 1 0 0
16 UP2 2112 Ended no 1 0 0
Dispatcher Queue Statistics Mon Nov 14 16:47:10 2011
| Typ | now | high | max | writes | reads |
| NOWP | 0 | 2 | 2000 | 5 | 5 |
| DIA | 5 | 5 | 2000 | 5 | 0 |
| UPD | 0 | 0 | 2000 | 0 | 0 |
| ENQ | 0 | 0 | 2000 | 0 | 0 |
| BTC | 0 | 0 | 2000 | 0 | 0 |
| SPO | 0 | 0 | 2000 | 0 | 0 |
| UP2 | 0 | 0 | 2000 | 0 | 0 |
max_rq_id 12
wake_evt_udp_now 0
wake events total 8, udp 6 ( 75%), shm 2 ( 25%)
since last update total 8, udp 6 ( 75%), shm 2 ( 25%)
Dump of tm_adm structure: Mon Nov 14 16:47:10 2011
Term uid man user term lastop mod wp ta a/i (modes)
Workprocess Comm. Area Blocks Mon Nov 14 16:47:10 2011
Slots: 300, Used: 1, Max: 0
| id | owner | pid | eyecatcher |
| 0 | DISPATCHER | -1 | *WPCAAD000* |
NiWait: sleep (5000ms) ...
NiISelect: timeout 5000ms
Mon Nov 14 10:47:15 2011
NiISelect: TIMEOUT occured (5000ms)
DpHalt: shutdown server >sapserverid_WY2_00 < (normal)
DpJ2eeDisableRestart
DpModState: buffer in state MBUF_PREPARED
NiBufSend starting
NiIWrite: hdl 2 sent data (wrt=110,pac=1,MESG_IO)
MsINiWrite: sent 110 bytes
MsIModState: change state to SHUTDOWN
DpModState: change server state from STARTING to SHUTDOWN
Switch off Shared memory profiling
ShmProtect( 57, 3 )
ShmProtect(SHM_PROFILE, SHM_PROT_RW
ShmProtect( 57, 1 )
ShmProtect(SHM_PROFILE, SHM_PROT_RD
DpWakeUpWps: wake up all wp's
Stop work processes
Stop gateway
killing process (2608) (SOFT_KILL)
Stop icman
killing process (2960) (SOFT_KILL)
Terminate gui connections
wait for end of work processes
wait for end of gateway
[DpProcDied] Process lives (PID:2608 HANDLE:416)
waiting for termination of gateway ...
NiWait: sleep (1000ms) ...
NiISelect: timeout 1000ms
Mon Nov 14 10:47:16 2011
NiISelect: TIMEOUT occured (1000ms)
[DpProcDied] Process died (PID:2608 HANDLE:416)
wait for end of icman
[DpProcDied] Process lives (PID:2960 HANDLE:424)
waiting for termination of icman ...
Mon Nov 14 10:47:17 2011
Mon Nov 14 10:47:18 2011
Mon Nov 14 10:47:19 2011
Mon Nov 14 10:47:20 2011
Mon Nov 14 10:47:21 2011
Mon Nov 14 10:47:22 2011
Mon Nov 14 10:47:23 2011
Mon Nov 14 10:47:24 2011
Mon Nov 14 10:47:25 2011
Mon Nov 14 10:47:26 2011
Mon Nov 14 10:47:27 2011
[DpProcDied] Process died (PID:2960 HANDLE:424)
DpStartStopMsg: send stop message (myname is >sapserverid_WY2_00 <)
DpStartStopMsg: Write AD_STARTSTOP message with type= 0, name=sapserverid_WY2_00 , sapsysnr= 0, hostname=sapserverid
AdGetSelfIdentRecord: > <
AdCvtRecToExt: opcode 60 (AD_SELFIDENT), ser 0, ex 0, errno 0
AdCvtRecToExt: opcode 4 (AD_STARTSTOP), ser 0, ex 0, errno 0
DpConvertRequest: net size = 189 bytes
NiBufSend starting
NiIWrite: hdl 2 sent data (wrt=562,pac=1,MESG_IO)
MsINiWrite: sent 562 bytes
send msg (len 110+452) to name -, type 4, key -
DpStartStopMsg: stop msg sent
NiIRead: hdl 2 received data (rcd=274,pac=1,MESG_IO)
NiBufIIn: NIBUF len=274
NiBufIIn: packet complete for hdl 2
NiBufReceive starting
MsINiRead: received 274 bytes
MSG received, len 110+164, flag 1, from MSG_SERVER , typ 0, key -
DpHalt: received 164 bytes from message server
NiIRead: hdl 2 recv would block (errno=EAGAIN)
NiIRead: read for hdl 2 timed out (0ms)
DpHalt: no more messages from the message server
DpHalt: send keepalive to synchronize with the message server
NiBufSend starting
NiIWrite: hdl 2 sent data (wrt=114,pac=1,MESG_IO)
MsINiWrite: sent 114 bytes
send msg (len 110+4) to name MSG_SERVER, type 0, key -
MsSndName: MS_NOOP ok
Send 4 bytes to MSG_SERVER
NiIPeek: peek successful for hdl 2 (r)
NiIRead: hdl 2 received data (rcd=114,pac=1,MESG_IO)
NiBufIIn: NIBUF len=114
MsINiRead: received 114 bytes
MSG received, len 110+4, flag 3, from MSG_SERVER , typ 0, key -
Received 4 bytes from MSG_SERVER
Received opcode MS_NOOP from msg_server, reply MSOP_OK
MsOpReceive: ok
MsSendKeepalive : keepalive sent to message server
Mon Nov 14 10:47:28 2011
NiIPeek: peek for hdl 2 timed out (r; 1000ms)
NiIRead: read for hdl 2 timed out (1000ms)
DpHalt: sync with message server o.k.
detach from message server
***LOG Q0M=> DpMsDetach, ms_detach () [dpxxdisp.c 12829]
NiBufSend starting
MsIDetach: send logout to msg_server
MsIDetach: call exit function
DpMsShutdownHook called
NiBufISelUpdate: new MODE -- (r-) for hdl 2 in set0
SiSelNSet: set events of sock 340 to: ---
NiBufISelRemove: remove hdl 2 from set0
SiSelNRemove: removed sock 340 (pos=2)
NiSelIRemove: removed hdl 2
MBUF state OFF
AdCvtRecToExt: opcode 40 (AD_MSBUF), ser 0, ex 0, errno 0
blks_in_queue/wp_ca_blk_no/wp_max_no = 1/300/17
LOCK WP ca_blk 1
make DISP owner of wp_ca_blk 1
DpRqPutIntoQueue: put request into queue (reqtype 1, prio LOW, rq_id 15)
MBUF component DOWN
NiICloseHandle: shutdown and close hdl 2 / sock 340
NiBufIClose: clear extension for hdl 2
MsIDetach: detach MS-system
cleanup EM
EsCleanup ....
EmCleanup() -> 0
Es2Cleanup: Cleanup ES2
***LOG Q05=> DpHalt, DPStop ( 1564) [dpxxdisp.c 11045]
Viejo 21/11/11, 10:42:01
jgsanz jgsanz is offline
prueba a subirle la swap y reinicia servidor.
Si sigue fallando pon los archivos dev_disp y el w0
Viejo 28/11/11, 22:03:40
Hola amigo ahora lo q me hace es q el dispathcer es q se pone en verde y despues de un cierto tiempo unos 30 segundos se va a stopped.
alguna sugerencia?
gracias
Viejo 29/11/11, 08:08:46
Avatar de elalien
elalien elalien is offline
Localización: Madrid
Intenta ponernos el trace de algun workprocess
dev_w0 por ejemplo.
¿la BBDD levanta bien?
Viejo 29/11/11, 18:28:17
Hola amigo te paso la imagen zipeada de lo q me indica el dispatcher despues de el mensaje de running, message server conection ok, Dialog queue time se va a stopped
alguna sugerencia?
como le hago para sacar los traces q me indicas?
Archivos Adjuntos
Tipo de Archivo: zip dispatcher.zip (20.2 KB, 23 visitas)
Viejo 30/11/11, 14:48:51
Avatar de elalien
En la imagen que mandas solo se ve un pantallazo de la consola con todo en verde
el fichero trace de los workprocess o bien lo ves en la consola (abres los WP's y boton derecho sobre uno de ellos) o en el directorio work de sap.
Viejo 30/11/11, 14:51:57
Despues de ese pantallazo en verde despues de un rato se va a stopped. Te paso el archivo trace de dispatcher q hice despues de q se fue a stopped
gracias
Archivos Adjuntos
Tipo de Archivo: txt trace.txt (18.4 KB, 12 visitas)
Viejo 01/12/11, 16:35:32
Amigos les agrego el archivo DEV_W0
el problema se presnta de la siguiente manera.
Inicio el servidor, todo bien empieza el dispatcher a ponerse en amarillo con la leyenda
RUNNINGBUT MESSAGE SERVER UNREACHABLE
cambia a verde con la leyenda
RUNNING BUT DIALOG QUEUE STANDSTILL
posteriormente se pone en verde con el siguiente mensaje
RUNNING, MENSAGE SERVER CONNECTION OK, DIALOG QUEUE TIME: 0.0.sec
después de unos segundos se va a verder
algun comentario?
gracias
trc file: "dev_w0", trc level: 1, release: "701"
* ACTIVE TRACE LEVEL 1
* ACTIVE TRACE COMPONENTS all, MJ
B
B Thu Dec 01 11:22:56 2011
B create_con (con_name=R/3)
B Loading DB library 'D:\usr\sap\WY2\DVEBMGS00\exe\dboraslib.dll' ...
B Library 'D:\usr\sap\WY2\DVEBMGS00\exe\dboraslib.dll' loaded
B Version of 'D:\usr\sap\WY2\DVEBMGS00\exe\dboraslib.dll' is "700.08", patchlevel (0.25)
B New connection 0 created
M sysno 00
M sid WY2
M systemid 562 (PC with Windows NT)
M relno 7010
M patchlevel 0
M patchno 32
M intno 20020600
M make: multithreaded, Unicode, 64 bit, optimized
M pid 2204
M
M kernel runs with dp version 241000(ext=110000) (@(#) DPLIB-INT-VERSION-241000-UC)
M length of sys_adm_ext is 576 bytes
M ***LOG Q0Q=> tskh_init, WPStart (Workproc 0 2204) [dpxxdisp.c 1348]
I MtxInit: 30000 0 0
M DpSysAdmExtCreate: ABAP is active
M DpSysAdmExtCreate: VMC (JAVA VM in WP) is not active
M DpShMCreate: sizeof(wp_adm) 29792 (1752)
M DpShMCreate: sizeof(tm_adm) 5912704 (29416)
M DpShMCreate: sizeof(wp_ca_adm) 24064 (80)
M DpShMCreate: sizeof(appc_ca_adm) 8000 (80)
M DpCommTableSize: max/headSize/ftSize/tableSize=500/16/552064/552080
M DpShMCreate: sizeof(comm_adm) 552080 (1088)
M DpSlockTableSize: max/headSize/ftSize/fiSize/tableSize=0/0/0/0/0
M DpShMCreate: sizeof(slock_adm) 0 (104)
M DpFileTableSize: max/headSize/ftSize/tableSize=0/0/0/0
M DpShMCreate: sizeof(file_adm) 0 (72)
M DpShMCreate: sizeof(vmc_adm) 0 (1864)
M DpShMCreate: sizeof(wall_adm) (41664/36752/64/192)
M DpShMCreate: sizeof(gw_adm) 48
M DpShMCreate: SHM_DP_ADM_KEY (addr: 000000000B2B0050, size: 6614144)
M DpShMCreate: allocated sys_adm at 000000000B2B0050
M DpShMCreate: allocated wp_adm at 000000000B2B2270
M DpShMCreate: allocated tm_adm_list at 000000000B2B96D0
M DpShMCreate: allocated tm_adm at 000000000B2B9730
M DpShMCreate: allocated wp_ca_adm at 000000000B85CFB0
M DpShMCreate: allocated appc_ca_adm at 000000000B862DB0
M DpShMCreate: allocated comm_adm at 000000000B864CF0
M DpShMCreate: system runs without slock table
M DpShMCreate: system runs without file table
M DpShMCreate: allocated vmc_adm_list at 000000000B8EB980
M DpShMCreate: allocated gw_adm at 000000000B8EBA00
M DpShMCreate: system runs without vmc_adm
M DpShMCreate: allocated ca_info at 000000000B8EBA30
M DpShMCreate: allocated wall_adm at 000000000B8EBA40
M rdisp/queue_size_check_value : -> off
M ThTaskStatus: rdisp/reset_online_during_debug 0
X EmInit: MmSetImplementation( 2 ).
X MM global diagnostic options set: 0
X <ES> client 0 initializing ....
X Using implementation view
X <EsNT> Using memory model view.
M <EsNT> Memory Reset disabled as NT default
X ES initialized.
M
M Thu Dec 01 11:22:57 2011
M ThInit: running on host sapserverid
M
M Thu Dec 01 11:22:58 2011
M calling db_connect ...
C Prepending D:\usr\sap\WY2\DVEBMGS00\exe to Path.
C Oracle Client Version: '10.2.0.4.0'
C Client NLS setting (OCINlsGetInfo): 'AMERICAN_AMERICA.UTF8'
C Logon as OPS$-user to get SAPSR3's password
C Connecting as /@WY2 on connection 0 (nls_hdl 0) ... (dbsl 700 151208)
C Nls CharacterSet NationalCharSet C EnvHp ErrHp ErrHpBatch
C 0 UTF8 0 0000000002F5F900 0000000002509500 000000000250AD28
C Attaching to DB Server WY2 (con_hdl=0,svchp=000000000250ABE8,srvhp=0000000002F67958)
C Starting user session: OCISessionBegin(con_hdl=0, usr='/',svchp=000000000250ABE8, srvhp=0000000002F67958, usrhp=0000000002F6E2B0)
C *** ERROR => OCI-call 'OCISessionBegin' failed with rc=1033
[dboci.c 4704]
C Detaching from DB Server (con_hdl=0,svchp=000000000250ABE8,srvhp=0000000002F67958)
C *** ERROR => CONNECT failed with sql error '1033'
[dbsloci.c 11175]
C Try to connect with default password
C Connecting as SAPSR3/<pwd>@WY2 on connection 0 (nls_hdl 0) ... (dbsl 700 151208)
C
C Thu Dec 01 11:22:59 2011
C Starting user session: OCISessionBegin(con_hdl=0, usr=SAPSR3/<pwd>, svchp=000000000250ABE8, srvhp=0000000002F67958, usrhp=0000000002F6E2B0)
[dboci.c 4704]
[dbsloci.c 11175]
B ***LOG BV3=> severe db error 1033 ; work process is stopped [dbsh#2 @ 1203] [dbsh 1203 ]
B ***LOG BY2=> sql error 1033 performing CON [dblink#3 @ 431] [dblink 0431 ]
B ***LOG BY0=> ORA-01033: ORACLE initialization or shutdown in progress [dblink#3 @ 431] [dblink 0431 ]
M ***LOG R19=> ThInit, db_connect ( DB-Connect 000256) [thxxhead.c 1449]
M in_ThErrHandle: 1
M *** ERROR => ThInit: db_connect (step 1, th_errno 13, action 3, level 1) [thxxhead.c 10563]
M
M Info for wp 0
M
M pid = 2204
M severity = 0
M status = 0
M stat = WP_RUN
M waiting_for = NO_WAITING
M reqtype = DP_RQ_DIAWP
M act_reqtype = NO_REQTYPE
M rq_info = 0
M tid = -1
M mode = 255
M len = -1
M rq_id = 65535
M rq_source =
M last_tid = 0
M last_mode = 0
M semaphore = 0
M act_cs_count = 0
M csTrack = 0
M csTrackRwExcl = 0
M csTrackRwShrd = 0
M mode_cleaned_counter = 0
M control_flag = 0
M int_checked_resource(RFC) = 0
M ext_checked_resource(RFC) = 0
M int_checked_resource(HTTP) = 0
M ext_checked_resource(HTTP) = 0
M report = > <
M action = 0
M tab_name = > <
M attachedVm = no VM
M
M *****************************************************************************
M *
M * LOCATION SAP-Server sapserverid_WY2_00 on host sapserverid (wp 0)
M * ERROR ThInit: db_connect
M *
M * TIME Thu Dec 01 11:22:59 2011
M * RELEASE 701
M * COMPONENT Taskhandler
M * VERSION 1
M * RC 13
M * MODULE thxxhead.c
M * LINE 10783
M * COUNTER 1
M *
M
M PfStatDisconnect: disconnect statistics
M Entering TH_CALLHOOKS
M ThCallHooks: call hook >BtcCallLgCl< for event BEFORE_DUMP
M ThCallHooks: call hook >ThrSaveSPAFields< for event BEFORE_DUMP
M *** ERROR => ThrSaveSPAFields: no valid thr_wpadm [thxxrun1.c 723]
M *** ERROR => ThCallHooks: event handler ThrSaveSPAFields for event BEFORE_DUMP failed [thxxtool3.c 261]
M Entering ThSetStatError
M ThIErrHandle: do not call ThrCoreInfo (no_core_info=0, in_dynp_env=0)
M Entering ThReadDetachMode
M call ThrShutDown (1)...
M ***LOG Q02=> wp_halt, WPStop (Workproc 0 2204) [dpnttool.c 334]
Viejo 01/12/11, 18:04:51
Les dejo los errores que obtuve de oracle
Dump file d:\oracle\wy2\saptrace\usertrace\wy2_ora_2084.trc
Thu Dec 01 11:22:40 2011
ORACLE V10.2.0.4.0 - 64bit Production vsnsta=0
vsnsql=14 vsnxtr=3
Oracle Database 10g Enterprise Edition Release 10.2.0.4.0 - 64bit Production
With the Partitioning, OLAP, Data Mining and Real Application Testing options
Windows NT Version V5.2 Service Pack 2
CPU : 2 - type 8664, 1 Physical Cores
Process Affinity : 0x0000000000000000
Memory (Avail/Total): Ph:3269M/4085M, Ph+PgF:60680M/61730M
Instance name: wy2
Redo thread mounted by this instance: 1
Oracle process number: 14
Windows thread id: 2084, image: ORACLE.EXE (SHAD)
*** ACTION NAME) 2011-12-01 11:22:40.406
*** MODULE NAMEsqlplus.exe) 2011-12-01 11:22:40.406
*** SERVICE NAME) 2011-12-01 11:22:40.406
*** SESSION ID149.3) 2011-12-01 11:22:40.406
Successfully allocated 2 recovery slaves
Using 66 overflow buffers per recovery slave
Thread 1 checkpoint: logseq 22289, block 2, scn 1375672039
cache-low rba: logseq 22289, block 10372
on-disk rba: logseq 22289, block 29850, scn 1375698286
start recovery at logseq 22289, block 10372, scn 0
*** 2011-12-01 11:22:43.031
ksedmp: internal or fatal error
ORA-00600: internal error code, arguments: [kcrfr_update_nab_2], [0x7FFA78E7008], [2], [], [], [], [], []
Current SQL statement for this session:
ALTER DATABASE OPEN
check trace file d:\oracle\product\10.2.0\db_1\rdbms\trace\wy2_ora_0.trc for preloading .sym file messages
Viejo 01/12/11, 18:24:26
Avatar de elalien
Está claro que el problema lo tienes en la BBDD Oracle.
Intenta levantarla desde sqlplus y a ver que te dice.
Mira tambien y pon aqui si quieres el ficehero de alertas de oracle. Si es muy grande no lo pongas entero, pon lo que te aparezca desde que intentas arrancar
Husos Horarios son GMT. La hora en este momento es 18:30:57.
