webdynpro con error
Hola buenas , he empezado a seguir el tutorial de webdynpro que encontre por ahi ,y al termninar me sale este erro , alguien puede indicarme donde esta el problema,
Error when processing your request What has happened? The URL was not called due to an error. Note The following error text was processed in the system NSP : User session (HTTP/SMTP/..) closed after timeout The error occurred on the application server fran_NSP_00 and in the work process 0 . The termination type was: ERROR_MESSAGE_STATE The ABAP call stack was: Method: HANDLE_REQUEST of program CL_WDR_UCF====================CP Method: IF_HTTP_EXTENSION~HANDLE_REQUEST of program CL_WDR_MAIN_TASK==============CP Method: EXECUTE_REQUEST_FROM_MEMORY of program CL_HTTP_SERVER================CP Function: HTTP_DISPATCH_REQUEST of program SAPLHTTP_RUNTIME Module: %_HTTP_START of program SAPMHTTP What can I do? If the termination type was RABAX_STATE, then you can find more information on the cause of the termination in the system NSP in transaction ST22. If the termination type was ABORT_MESSAGE_STATE, then you can find more information on the cause of the termination on the application server fran_NSP_00 in transaction SM21. If the termination type was ERROR_MESSAGE_STATE, then you can search for more information in the trace file for the work process 0 in transaction ST11 on the application server fran_NSP_00 . In some situations, you may also need to analyze the trace files of other work processes. If you do not yet have a user ID, contact your system administrator. Error code: ICF-IE-http -c: 000 -u: BCUSER -l: E -s: NSP -i: fran_NSP_00 -w: 0 -d: 20081028 -t: 135946 -v: ERROR_MESSAGE_STATE -e: User session (HTTP/SMTP/..) closed after timeout HTTP 500 - Internal Server Error Your SAP Internet Communication Framework Team |
Hola akiestudio
Ese mensaje sale por Time Out, es decir cuando la pagina esta un tiempo sin ser usada y tratas de usarla de nuevo te muestra ese error de Time Out, tienes que cerrarla y volverla a abrir. Saludos César |
Hola , has revisado si los servicios estan levantados.
en la spro-sap netweaver-> servidor de aplicacion-->Activar servicios HTTP para cada aplicación Saludos |
Muchas gracias , que es la spro-saonetweave, es una transacion , he probado como transaccion la spro , pero no veo nada de lo que me comentas , donde encuentro esto.
spro-sap netweaver-> servidor de aplicacion-->Activar servicios HTTP Seguro que esto, yo uso la trial version que se descrga uno de esta pagina , mucha gracias ....ya veo que san no es un mundo son multiples mundo... |
![]() la Spro es una transaccion y dudo mucho q lo tenga el trial. |
la spro si que aparece en mi trial , pero no se como llegar aqui
spro-sap netweaver-> servidor de aplicacion-->Activar servicios HTTP ,si pongo spro , me aparece my customizing worlist , pero no me aparece nada de sevidor de aplicacion , donde se encuentra eso para activar el servicio de htpp |
Úlima edición por akiestudio fecha: 30/10/08 a las 17:50:27. |
