Viejo 20/08/08, 21:17:35
Carlos Quezada S. Carlos Quezada S. is offline
Aplicacion SupporPackage SAPKH60012
Estimados todos,
al aplicar el support package SAPKH60012 para el componente SAP_APPL, me error el la fase IMPORT_PROPER, y el log es el siguiente:
Summary:
4 ETW000
4 ETW000 180 bytes modified in database.
4 ETW000 [dev trc ,00000] Wed Aug 20 17:13:11 2008 71302906 71.302906
4 ETW000 [dev trc ,00000] Disconnecting from ALL connections: 122 71.303028
4 ETW000 [dev trc ,00000] Disconnecting from connection 0 ... 198 71.303226
4 ETW000 [dev trc ,00000] Closing user session (con_hdl=0,svchp=0x1018b3d68,usrhp=0x1018a3f18)
4 ETW000 3498 71.306724
4 ETW000 [dev trc ,00000] Detaching from DB Server (con_hdl=0,svchp=0x1018b3d68,srvhp=0x1018b6058)
4 ETW000 18430 71.325154
4 ETW000 [dev trc ,00000] Now I'm disconnected from ORACLE 2679 71.327833
4 ETW000 [dev trc ,00000] Disconnected from connection 0 147 71.327980
4 ETW000 [dev trc ,00000] statistics db_con_commit (com_total=3, com_tx=3)
4 ETW000 193 71.328173
4 ETW000 [dev trc ,00000] statistics db_con_rollback (roll_total=0, roll_tx=0)
4 ETW000 194 71.328367
4 ETW000 Disconnected from database.
4 ETW000 End of Transport (0008).
4 ETW000 date&time: 20.08.2008 - 17:13:11
4 ETW000 1 error occured.
1 ETP154 MAIN IMPORT
1 ETP110 end date and time : "20080820171311"
1 ETP111 exit code : "8"
1 ETP199 ######################################
gracias.
Viejo 20/08/08, 23:44:27
Avatar de rikardote
rikardote rikardote is offline
Lightbulb Support Pakcage
Actualiza tu Kernel a la ultima versión.
Saludos.!
Viejo 21/08/08, 08:13:28
spanishpower spanishpower is offline
Localización: Oviedo , Asturias
Ese support package miraste los requerimientos ??? kernel , nivel de spam , otros packages ???
Viejo 21/08/08, 09:52:54
koletas koletas is offline
Localización: Aranda De Duero, España
Smile
Holasss,
Actualiza lo primero la SPAM, luego mira las dependencias y en la STMS -> Systems -> <SID> -> en la pestaña Transport Tool revisa los parámetros R3TRANSPATH (/usr/sap/trans/exe/R3trans) y R3TRANSPATH (\\hostname\sapmnt\<SID>\sys\exe\run\R3trans.exe). Ve a dichos paths y has un R3trans -version, ambas tienen que ser iguales, ya que una inferior hace lo mismo que la superior.
Esto me pasó tras actualizar el kernel y lo resolví de esta manera.
SAP Basis Consultant
Viejo 21/08/08, 17:00:56
Estimados todos, voy a probar vuestras sugerencias y les cuento.
Husos Horarios son GMT. La hora en este momento es 03:38:40.
