Viejo 15/11/06, 08:00:40
yo2 yo2 is offline
authority-check
Hola a todos.
He encontrado esta sentencia authority-check para chequear una autorización, pero a parte de eso no se como funciona. Alguien me puede echar un cable.
gracias
Viejo 15/11/06, 08:46:32
oarranzli oarranzli is offline
Localización: España
Hola:
Información encontrada en la help de SAP:
AUTHORITY-CHECK
Basic form
AUTHORITY-CHECK OBJECT object ID name1 FIELD f1
ID name2 FIELD f2
ID name10 FIELD f10.
Effect
Explanation of IDs:
object Field which contains the name of the object for which the authorization is to be checked.
name1 ... Fields which contain the names of the name10 authorization fields defined in the object.
f1 ... Fields which contain the values for which the f10 authorization is to be checked.
AUTHORITY-CHECK checks for one object whether the user has an authorization that contains all values of f (see ).
You must specify all authorizations for an object and a also a value for each ID (or DUMMY).
The system checks the values for the IDs by AND-ing them together, i.e. all values must be part of an authorization assigned to the user.
If a user has several authorizations for an object, the values are OR-ed together. This means that if the CHECK finds all the specified values in one authorization, the user can proceed. Only if none of the authorizations for a user contains all the required values is the user rejected.
If the return code value in SY-SUBRC is 0, the user has the required authorization and may continue.
The return code value changes according to the different error scenarios. The return code values have the following meaning:
4 User has no authorization in the SAP System for such an action. If necessary, change the user master record. 8 Too many parameters (fields, values). Maximum allowed is 10. 12 Specified object not maintained in the user master record. 16 No profile entered in the user master record. 24 The field names of the check call do not match those of an authorization. Either the authorization or the call is incorrect. 28 Incorrect structure for user master record. 32 Incorrect structure for user master record. 36 Incorrect structure for user master record.
If the return code value is 8 or 24, inform the person responsible for the program. If the return code value is 4, 12, 16 or 24, consult your system administrator if you think you should have the relevant authorization. In the case of errors 28 to 36, contact SAP because authorizations have probably been destroyed.
Individual authorizations are assigned to users in their respective user profiles, i.e. they are grouped together in profiles which are stored in the user master record.
Note
Instead of ID name FIELD f, you can also write ID name DUMMY. This means that no check is performed for the field concerned.
The check can only be performed on CHAR fields. All other field types result in 'unauthorized'.
Example
Check whether the user is authorized for a particular plant. In this case, the following authorization object applies:
Table OBJ: Definition of authorization object
M_EINF_WRK
ACTVT
WERKS
Here, M_EINF_WRK is the object name, whilst ACTVT and WERKS are authorization fields. For example, a user with the authorizations
M_EINF_WRK_BERECH1
ACTVT 01-03
WERKS 0001-0003 .
can display and change plants within the Purchasing and Materials Management areas.
Such a user would thus pass the checks
AUTHORITY-CHECK OBJECT 'M_EINF_WRK'
ID 'WERKS' FIELD '0002'
ID 'ACTVT' FIELD '02'.
ID 'WERKS' DUMMY
ID 'ACTVT' FIELD '01':
but would fail the check
ID 'WERKS' FIELD '0005'
ID 'ACTVT' FIELD '04'.
To suppress unnecessary authorization checks or to carry out checks before the user has entered all the values, use DUMMY - as in this example. You can confirm the authorization later with another AUTHORITY-CHECK.
Viejo 15/11/06, 10:51:39
yo2 yo2 is offline
Vale, muchas gracias, pero eso ya lo habia visto...
Me gustaria saber como crear un objecto de autorizacion para luego poder utilizar el authority-check.
gracias otra vez
Viejo 15/11/06, 11:55:38
Gregoryg Gregoryg is offline
Localización: Caracas, Venezuela
Authority-check
Primero debes crear una clase de objeto atraves de Tx su21, a esa clase de objeto creada la asigna un objeto en esa misma transacción
Posteriormente por la Tx su20 te creas un ambito de autorización y lo relacionas con la clase y objeto creada anteriormente.
A traves de la Tx su01 le asigna el objeto a los distintos usuarios.
GregoryG
Husos Horarios son GMT. La hora en este momento es 23:44:15.
