user-exit VA01 en pestaña interlocutor
estoy buscando una user-exit para la Creación de pedido- VA01- donde el usuario se situa en la pestaña de interlocutor (PARTNER). Encontré ésta EXIT_SAPLV09A_004 pero se activa justo antes de lo que buscamos. Gracias por anticipado es un tema urgente |
Buena Suerte!!! :)
Enhancement Description
USEREXIT_CHANGE_SALES_ORDER In the standard SAP R/3 System, the quantity and confirmed date of the sales document schedule line is changed automatically if a purchase requisition is allocated, and it or the sales document is changed (for example, quantity, date). USEREXIT_CHECK_VBAK This user exit can be used to carry out additional checks (e.g. for completion) in the document header. The system could, for example, check whether certain shipping conditions are allowed for a particular customer group. USEREXIT_CHECK_VBAP This user exit can be used to carry out additional checks (e.g. for completion) at item level. USEREXIT_CHECK_VBEP This user exit can be use to carry out additional checks (e.g. for completion) on the schedule line. USEREXIT_CHECK_VBKD The user exit can be used to carry out additional checks (e.g. for completion) on the business data in the order. USEREXIT_CHECK_VBSN You can use this user exit to carry out additional checks (e.g. for completion) on the serial number. USEREXIT_CHECK_XVBAP_FOR_DELET In this user exit, you can enter additional data for deletion of an item. If the criteria are met, the item is not deleted (unlike in the standard system). USEREXIT_CHECK_XVBEP_FOR_DELET In this user exit, you can enter additional data for deletion of a schedule line. If the criteria are met, the schedule line is not deleted (unlike in the standard system). USEREXIT_CHECK_XVBSN_FOR_DELET In this user exit, you can enter additional criteria for deletion of the serial number. If the criteria are met, the serial number is not deleted (unlike in the standard system). USEREXIT_COBL_RECEIVE_VBAK Option to assign values from the document header to the new fields. USEREXIT_COBL_RECEIVE_VBAP Option to supply values from the item to the new fields. USEREXIT_COBL_SEND_HEADER A changed field can be copied from the structure to the header (see source text MV45AFZB) USEREXIT_COBL_SEND_ITEM A changed field can be copied from the structure into the item. You could use the user exit to display a certain field in the account assignment block (see also MV45AFZB). USEREXIT_CUST_MATERIAL_READ You can use this user exit to set another customer number in the customer material info record (e.g. with a customer hierarchy) USEREXIT_DELETE_DOCUMENT This user exit can be used for deleting data which was stored in a separate table during sales document creation, for example, if the sales document is deleted. USEREXIT_FIELD_MODIFICATION This user exit can be used to modify the attributes of the screen fields. USEREXIT_FILL_VBAP_FROM_HVBAP You can use this user exit to fill additional fields in the sub-item with data from the main item. USEREXIT_MOVE_FIELD_TO_COBL Option to include new fields in structure COBL. USEREXIT_MOVE_FIELD_TO_KOMKH You can use this user exit to include new fields for batch determination (document header). USEREXIT_MOVE_FIELD_TO_KOMPH You can use this user exit to include new fields for batch determination (document item). USEREXIT_MOVE_FIELD_TO_ME_REQ "With this user exit you can include additional fields for the following fields: EBAN (purchase requisition) EBKN (purchase requisition-account assignment) USEREXIT_GET_FIELD_FROM_SDCOM" USEREXIT_MOVE_FIELD_TO_TVCOM_H You can use this user exit to influence text determination for header texts. For example, you can include new fields for text determination or fill fields that already exist with a new value. USEREXIT_MOVE_FIELD_TO_TVCOM_I You can use this user exit to influence text determination for item texts. For example, you can include new fields for text determination or fill fields that already exist with a new value. USEREXIT_MOVE_FIELD_TO_VBAK Use this user exit to assign values to new fields at sales document header level. USEREXIT_MOVE_FIELD_TO_VBAKKOM Option to include additional fields in structure VBAKKOM (communiction fields for maintaining the sales document header) USEREXIT_MOVE_FIELD_TO_VBAP Use this user exit to assign values to new fields at sales document item level USEREXIT_MOVE_FIELD_TO_VBAPKOM Option to include additional fields in structure VBAPKOM (communication fields for maintaining a sales item) USEREXIT_MOVE_FIELD_TO_VBEP Use this user exit to assign values to new fields at the level of the sales document schedule lines USEREXIT_MOVE_FIELD_TO_VBEPKOM Option to include additional fields in structure VBEPKOM (communication fields for maintaining a sales document schedule line) USEREXIT_MOVE_FIELD_TO_VBKD Use this user exit to assign values to new fields for business data of the sales document USEREXIT_MOVE_FIELD_TO_VBSN You can use this user exit to include fields in structure VBSN (scheduling agreement-related change status). USEREXIT_MOVE_WORKAREA_TO_SDWA You can use this user exit to format additional work areas for the variant configuration. You will find notes on the user exit in MV45AFZB. USEREXIT_NEW_PRICING_VBAP Option for entry of preconditions for carrying out pricing again (e.g. changes made to a certain item field could be used as the precondition for pricing to be carried out again). Further information in MV45AFZB. USEREXIT_NEW_PRICING_VBKD Option for entry of preconditions for carrying out pricing again (e.g. changes to the customer group or price group could be set as the preconditions for the system to carry out pricing again). Further information in MV45AFZB. USEREXIT_NUMBER_RANGE user exit to define the number ranges for internal document number assignment depending on the required fields USEREXIT_PRICING_PREPARE_TKOMK Use this user exit if you want to include and assign a value to an additional header field in the communication structure KOMK taken as a basis for pricing. USEREXIT_PRICING_PREPARE_TKOMP Use this user exit if you want to include or assign a value to an additional item field in the communication structure KOMP taken as a basis for pricing. USEREXIT_READ_DOCUMENT "You use this user exit if further additional tables are to be read when importing TA01 or TA02. The user exit is called up at the end of the FORM routine BELEG_LESEN." USEREXIT_SAVE_DOCUMENT Use this user exit to fill user-specific statistics update tables. USEREXIT_SAVE_DOCUMENT_PREPARE Use this user exit to make certain changes or checks immediately before saving a document. USEREXIT_SET_STATUS_VBUK In this user exit you can you can store a specification for the reserve fields in VBUK (header status). USEREXIT_SET_STATUS_VBUP In this user exit you can you can store a specification for the reserve fields for VBUP (item status). USEREXIT_SOURCE_DETERMINATION You can use this user exit to determine which plant will be used for the delivery USEREXIT_STATUS_VBUK_INVOICE You can use this user exit to influence billing status at header level. SDAPO001 Activating Sourcing Subitem Quantity Propagation SDTRM001 Reschedule schedule lines without a new ATP check V45A0001 Determine alternative materials for product selection V45A0002 Predefine sold-to party in sales document V45A0003 Collector for customer function modulpool MV45A V45A0003 Collector for customer function modulpool MV45A V45A0004 Copy packing proposal V45E0001 Update the purchase order from the sales order V45E0002 Data transfer in procurement elements (PRreq., assembly) V45L0001 SD component supplier processing (customer enhancements) V45L0001 SD component supplier processing (customer enhancements) V45L0001 SD component supplier processing (customer enhancements) V45L0001 SD component supplier processing (customer enhancements) V45L0001 SD component supplier processing (customer enhancements) V45L0001 SD component supplier processing (customer enhancements) V45L0001 SD component supplier processing (customer enhancements) V45P0001 SD customer function for cross-company code sales V45S0001 Update sales document from configuration V45S0003 MRP-relevance for incomplete configuration V45S0003 MRP-relevance for incomplete configuration V45S0004 Effectivity type in sales order V45W0001 SD Service Management: Forward Contract Data to Item V46H0001 SD Customer functions for resource-related billing V46H0001 SD Customer functions for resource-related billing V60F0001 SD Billing plan (customer enhancement) diff. to billing plan SDVFX001 User exit header line in delivery to accounting SDVFX002 User exit for A/R line (transfer to accounting) SDVFX003 User exit: Cash clearing (transfer to accounting) SDVFX004 User exit: G/L line (transfer to accounting) SDVFX005 User exit: Reserves (transfer to accounting) SDVFX006 User exit: Tax line (transfer to accounting) SDVFX007 User exit: Billing plan during transfer to Accounting SDVFX008 User exit: Processing of transfer structures SD-FI SDVFX009 Billing doc. processing KIDONO (payment reference number) SDVFX010 User exit item table for the customer lines SDVFX011 Userexit for the komkcv- and kompcv-structures V05I0001 User exits for billing index V05I0001 User exits for billing index V05I0001 User exits for billing index V05I0001 User exits for billing index V05N0001 User Exits for Printing Billing Docs. using POR Procedure V05N0001 User Exits for Printing Billing Docs. using POR Procedure V05N0001 User Exits for Printing Billing Docs. using POR Procedure V60A0001 Customer functions in the billing document V60P0001 Data provision for additional fields for display in lists V60P0001 Data provision for additional fields for display in lists V60P0001 Data provision for additional fields for display in lists V60P0001 Data provision for additional fields for display in lists V60P0001 Data provision for additional fields for display in lists V60P0001 Data provision for additional fields for display in lists V60P0001 Data provision for additional fields for display in lists V60P0001 Data provision for additional fields for display in lists V60P0001 Data provision for additional fields for display in lists V60P0001 Data provision for additional fields for display in lists V60P0001 Data provision for additional fields for display in lists V60P0001 Data provision for additional fields for display in lists V60P0001 Data provision for additional fields for display in lists V60P0001 Data provision for additional fields for display in lists V60P0001 Data provision for additional fields for display in lists V61A0001 Customer enhancement: Pricing V02V0001 Sales area determination for stock transport order V02V0002 User exit for storage location determination V02V0003 User exit for gate + matl staging area determination (headr) V02V0004 User Exit for Staging Area Determination (Item) V50PSTAT Delivery: Item Status Calculation V50Q0001 Delivery Monitor: User Exits for Filling Display Fields V50Q0001 Delivery Monitor: User Exits for Filling Display Fields V50R0001 Collective processing for delivery creation V50R0002 Collective processing for delivery creation V50R0004 Calculation of Stock for POs for Shipping Due Date List V50S0001 User Exits for Delivery Processing V50S0001 User Exits for Delivery Processing V53C0001 Rough workload calculation in time per item V53C0002 W&S: RWE enhancement - shipping material type/time slot V53W0001 User exits for creating picking waves V53W0001 User exits for creating picking waves V53W0001 User exits for creating picking waves VMDE0001 Shipping Interface: Error Handling - Inbound IDoc VMDE0002 Shipping Interface: Message PICKSD (Picking, Outbound) VMDE0003 Shipping Interface: Message SDPICK (Picking, Inbound) VMDE0004 Shipping Interface: Message SDPACK (Packing, Inbound) SDQUX001 User exit: SD product allocation processing, extended checks SDQUX002 SD product allocation processing, change schedule line SDQUX003 User-Exit : SD Product allocation, extended checks (ATP) SDQUX004 Product Allocations: Change the Product Allocation Steps SDQUX005 Product Allocations: Adjust product allocation quantities SDVAX001 Determine Billing Plan Type V09A0001 Reference/duplicate decision making manual address V09A0002 Partner type KU EXIT for NO_KNVV |
gracias!
Buenas,
lo hice por la include MV45AFZZ, user-exit: USEREXIT_PRICING_PREPARE_TKOMK . |
Desplegado | |
