Viejo 21/12/09, 13:39:02
Hasurac Hasurac is offline
problemas con al convercion
les pido ayuda para ver porque puede ser que no funcione la convercion a pdf y de hai a binario le s paso el codigo aver si ustedes ven algo que se me paso por alto desde ya gracias
form gen_pdf changing p_logo lv_solicitud p_nom_tra p_rut_tra p_empresa
p_fech_ing_emp p_sindicato p_tip_boni p_rut_ben p_nom_hc
p_ap_paterno p_ap_materno p_001 i_cont_bin numbytes.
tables nast.
w_ctrlop-getotf = 'X'.
w_ctrlop-no_dialog = 'X'.
w_compop-tdnoprev = 'X'.
w_compop-tddest = 'LOCL'.
w_compop-tdarmod = '1'.
w_compop-tdcopies = '1'.
w_compop-tdprinter = 'SAPWIN'.
w_compop-tdlifetime = '8'.
call function '/1BCDWB/SF00000006'
exporting
control_parameters = w_ctrlop
output_options = w_compop
user_settings = 'X'
gp_logo = p_logo "Aca los parametros que necesita el smartform
gp_n_solicitud = lv_solicitud
gp_nom_tra = p_nom_tra
gp_rut_tra = p_rut_tra
gp_empresa = p_empresa
gp_fech_ing_emp = p_fech_ing_emp
gp_sindicato = p_sindicato
gp_tip_boni = p_tip_boni
gp_fech_soli = sy-datum
gp_rut_bene = p_rut_ben
gp_nom_famil = p_nom_hc
gp_ap_paterno = p_ap_paterno
gp_ap_materno = p_ap_materno
gp_for001 = p_001
importing
job_output_info = w_return "aca me devuelve el smartform
exceptions
formatting_error = 1
internal_error = 2
send_error = 3
user_canceled = 4
others = 5.
if sy-subrc ne 0.
* MESSAGE ID SY-MSGID TYPE SY-MSGTY NUMBER SY-MSGNO
* WITH SY-MSGV1 SY-MSGV2 SY-MSGV3 SY-MSGV4.
endif.
i_otf[] = w_return-otfdata[].
CALL FUNCTION 'QCE1_CONVERT'
* TABLES
* t_source_tab = i_tline
* t_target_tab = i_cont
* EXCEPTIONS
* CONVERT_NOT_POSSIBLE = 1
* OTHERS = 2
* IF sy-subrc <> 0.
* ENDIF.
endform. " GEN_PDF
despues lo envio
data: objpack like sopcklsti1 occurs 2 with header line.
data: objhead like solisti1 occurs 1 with header line.
data: objbin like solisti1 occurs 10 with header line.
data: objtxt like solisti1 occurs 10 with header line.
data: reclist like somlreci1 occurs 5 with header line.
data: doc_chng like sodocchgi1.
data: tab_lines like sy-tabix.
data l_num(3).
* Creation of the document to be sent
doc_chng-obj_name = 'SENDFILE'.
* Mail Subject
doc_chng-obj_descr = 'Prueba de Correo via Sap'.
* Mail Contents
objtxt = 'Este es el contenido del mensaje'.
append objtxt.
describe table objtxt lines tab_lines.
read table objtxt index tab_lines.
doc_chng-doc_size = ( tab_lines - 1 ) * 255 + strlen( objtxt ).
* Creation of the entry for the compressed document
clear objpack-transf_bin.
objpack-head_start = 1.
objpack-head_num = 0.
objpack-body_start = 1.
objpack-body_num = tab_lines.
objpack-doc_type = 'RAW'.
append objpack.
* Creation of the document attachment
data: saltolinea type x.
saltolinea = '0D'.
describe table objbin lines tab_lines.
objhead = 'PDF'.
append objhead.
** Creation of the entry for the compressed attachment
describe table i_cont_bin lines tab_lines.
objpack-transf_bin = 'X'.
objpack-head_num = 1.
objpack-doc_type = 'PDF'.
objpack-doc_size = numbytes.
move objhead to objpack-obj_descr.
move objhead to objpack-obj_name.
objpack-doc_size = tab_lines * 255.
append objpack.
clear reclist.
reclist-receiver = 'XXXXXXXXX@hotmail.com'.
reclist-express = 'X'.
reclist-rec_type = 'U'.
reclist-copy = 'X'.
append reclist.
* Sending the document
call function 'SO_NEW_DOCUMENT_ATT_SEND_API1'
exporting
document_data = doc_chng
put_in_outbox = 'X'
commit_work = 'X'
tables
packing_list = objpack
object_header = objhead
contents_bin = i_cont_bin
contents_txt = objtxt
receivers = reclist
exceptions
too_many_receivers = 1
document_not_sent = 2
operation_no_authorization = 4
others = 99.
if sy-subrc <> 0.
message id sy-msgid type sy-msgty number sy-msgno
with sy-msgv1 sy-msgv2 sy-msgv3 sy-msgv4.
endif.
el error que tira es en la tranformacion a pdf dentro de la funcion
Viejo 21/12/09, 13:46:43
Avatar de mysmb2
mysmb2 mysmb2 is offline
Localización: Cordoba
¿podrías decirnos que dump te tira?
Sebastián Chiavia
Viejo 21/12/09, 14:14:17
si es este
Err.tmpo.ejec. CONVT_NO_NUMBER
Fecha y hora 21.12.2009 16:12:00
Texto breve
Unable to interpret "*401" as a number.
¿Qué ha sucedido?
Error in the ABAP Application Program
The current ABAP program "SAPLSTXW" had to be terminated because it ha
come across a statement that unfortunately cannot be executed.
Anál.errores
An exception occurred that is explained in detail below.
This exception cannot be caught in the context of the current statemen
The reason for the exception is:
The program attempted to interpret the value "*401" as a number, but
since the value contravenes the rules for correct number formats,
this was not possible.
Posición desencadenante de error tiempo ejecución
Programa SAPLSTXW
Include LSTXWU06
Línea 114
Tp.módulo (FUNCTION)
Nombre módulo CONVERT_OTF
Lín. Txt.fte.
84 *************************************************************
85 * Adobe Acrobat PDF format
86 *************************************************************
87 WHEN 'PDF'.
88 BIN_FILESIZE = 0.
89 if bin_file is supplied. "630
90 pdf_destination = c_pdfcnv_pdfdst_xstring.
91 clear bin_file.
92 else.
93 pdf_destination = c_pdfcnv_pdfdst_inttab.
94 endif.
95 perform pdfcnv_trace_otf tables otf.
96 perform pdfcnv_convertotf tables otf
97 lines
98 using C_PDFCNV_OTFSRC_INTTAB
99 archive_index
100 copynumber
101 spoolid
102 pdf_destination
103 dst_device
104 dst_spoolid
105 bin_filesize
106 bin_file
107 pdf_delete_otftab.
108 subrc = sy-subrc.
109 if pdf_delete_otftab = space.
110 perform pdfcnv_save_otf_tospool tables otf
111 using bin_filesize.
112 endif.
113 set locale language cur_system_lang.
>>>>> IF BIN_FILESIZE < 0 or subrc <> 0.
115 RAISE ERR_CONV_NOT_POSSIBLE. "unable to convert to PDF
116 ENDIF.
117 *************************************************************
118 * unsupported format
119 *************************************************************
Viejo 21/12/09, 16:48:05
ya solucione ese problema pero ahora cuando lo mando al mail lo recivo como pdf-2 el programa que uso para convertir es 'CONVERT_OTF_2_PDF' alguien me podria decir por que XD
Viejo 06/01/12, 15:51:28
quake1107 quake1107 is offline
Convt_no_number
Hola HASURAC
Disculpa cómo solucionaste lo del DUMP CONVT_NO NUMBER, tengo un problema similar,
de antemano muchas Gracias!
Husos Horarios son GMT. La hora en este momento es 06:06:23.
