Viejo 10/08/10, 16:58:35
m_dicto m_dicto is offline
Localización: Viña del Mar Chile
error de tiempo ejec DBIF_RSQL_SQL_ERROR
Hola soy nuevo en el tema sap y necesito ayuda a este tema,
La pltafrma donde esta montado sap es
windows 2003 servers
SQL 2005
SAP 6.0
Este error afecta a las transacciones st04, db02, st03 ya que no corre el programa que recolecta la informacion agradeceria su ayuda
EL DUMPS ES
Errores tiempo ejec. DBIF_RSQL_SQL_ERROR
Excepción CX_SY_OPEN_SQL_DB
Texto breve
SQL error in the database when accessing a table.
¿Qué puede hacer?
Note which actions and input led to the error.
For further help in handling the problem, contact your SAP administrator
You can use the ABAP dump analysis transaction ST22 to view and manage
termination messages, in particular for long term reference.
Notas para corregir errores
Database error text........: "[468] Cannot resolve the collation conflict
between "SQL_Latin1_General_CP850_BIN" and "SQL_Latin1_General_CP850_BIN2" in
the equal to operation."
Internal call code.........: "[RSQL/OPEN/SRT_MONLOG_DATA2 ]"
Please check the entries in the system log (Transaction SM21).
If the error occures in a non-modified SAP program, you may be able to
find an interim solution in an SAP Note.
If you have access to SAP Notes, carry out a search with the following
keywords:
"DBIF_RSQL_SQL_ERROR" "CX_SY_OPEN_SQL_DB"
"CL_SOAP_MONI_DB_ADAPTER=======CP" or "CL_SOAP_MONI_DB_ADAPTER=======CM001"
"READ_DATA"
"READ_DATA"
If you cannot solve the problem yourself and want to send an error
notification to SAP, include the following information:
1. The description of the current problem (short dump)
To save the description, choose "System->List->Save->Local File
(Unconverted)".
2. Corresponding system log
Display the system log by calling transaction SM21.
Restrict the time interval to 10 minutes before and five minutes
after the short dump. Then choose "System->List->Save->Local File
(Unconverted)".
3. If the problem occurs in a problem of your own or a modified SAP
program: The source code of the program
In the editor, choose "Utilities->More
Utilities->Upload/Download->Download".
4. Details about the conditions under which the error occurred or which
The exception must either be prevented, caught within proedure
"READ_DATA" "(METHOD)", or its possible occurrence must be declared in the
RAISING clause of the procedure.
To prevent the exception, note the following:
Info posición de cancelación
Termination occurred in the ABAP program "CL_SOAP_MONI_DB_ADAPTER=======CP" -
in "READ_DATA".
The main program was "SRT_COLLECTOR_FOR_MONITORING ".
In the source code you have the termination point in line 88
of the (Include) program "CL_SOAP_MONI_DB_ADAPTER=======CM001".
The program "CL_SOAP_MONI_DB_ADAPTER=======CP" was started as a background job.
Job Name....... "SAP_SRT_COLLECTOR_FOR_MONITORING"
Job Initiator.. "DDIC"
Job Number..... 06593100
The termination is caused because exception "CX_SY_OPEN_SQL_DB" occurred in
procedure "READ_DATA" "(METHOD)", but it was neither handled locally nor
declared
in the RAISING clause of its signature.
The procedure is in program "CL_SOAP_MONI_DB_ADAPTER=======CP "; its source
code begins in line
1 of the (Include program "CL_SOAP_MONI_DB_ADAPTER=======CM001 ".
Husos Horarios son GMT. La hora en este momento es 03:41:50.
