Viejo 17/12/07, 15:51:18
apisani apisani is offline
WF Work items generated by an IDOC
Hi,
I would like to know if any of you have an idea of how to find the workflow items which were generated by an IDOC.
Thanks in advance,
Andrea
Viejo 17/12/07, 16:39:21
asantos asantos is offline
Localización: El Salvador
Hi
If you create a work item you have to check in your SAP inbox tcode SBWP
I don't know wich task are you using, depeding on this you asign possible agents to do the task.
cheers
Alex
Viejo 17/12/07, 17:09:44
Hi Alex,
Thanks for your reply. The issue I am having is that I have the IDOC number but I do not have the work item number so I need to know if there is any TCode that allows me entering the IDOC number in order to see the workflow items generated by it.
Thanks again,
Andrea
Viejo 17/12/07, 23:26:06
Hi Andrea
what is your scenario? becuase I don't know if we are talking about incoming or outgoing documents.
I am trying to uderstand your process
Cheers
Alex
Viejo 18/12/07, 18:34:56
Hi Alex,
They can be inbound or outbound idocs. When an error occurs then a workflow item is generated. We lost one of the workflow items which was generated by an idoc and we want to see who has it. In order to know this we need the number of the workflow item which was generated by this idoc. We know the idoc number but we do not know the workflow item number.
Thanks in advance for your help,
Andrea
Viejo 18/12/07, 23:50:30
Hi Andrea
you can look for the work item in the table SWWWIHEAD. this is the table for all work items ready to process, canceled or finished.
may be this is what you want.
regards
Alex
Husos Horarios son GMT. La hora en este momento es 14:28:52.
