Viejo 02/01/08, 10:56:54
alvaromon2 alvaromon2 is offline
Localización: Madrid
error urgente
Hola a Tod@s necesitaria ayuda urgente con este tema, al intalar un Support Package me da error :
Error in phase: IMPORT_PROPER
Reason for error: TP_STEP_FAILURE
Return code: 0008
Error message: OCS Package SAPKH47028, tp step "I", return code
0008
Me estoy volviendo loco y no consigo solucionarlo me podeis ayudar .
Muchas gracias a todos.
Viejo 02/01/08, 11:13:56
moisex moisex is offline
Debes averiguar porqué se ha dado el error para que no vuelva a suceder.
Para devolver la spam a su estatus original:
PARA RESETEAR LA SPAM EJECUTAR LA SIGUIENTE FUNCION:
Ir a la transaccón SE37, poner OCS_RESET_QUEUE, dar a F8 para ejecutar.
En los parámetros que pide poner:
IV_TOOL SPAM
IV_FORCE X
Moisés.
Viejo 02/01/08, 13:02:01
hola moisex, he echo lo que me has comentado ahora me da el siguiente error pero no se como seguir , he buscado en help.sap pero nada te agradeceria si me puedes ayudar?
Este es el log:
Saving the current OCS Queue (02.01.2008, 13:27:16)
Import of the current OCS Queue (02.01.2008, 13:27:26)
The import is done with the Standard scenario
Import phase 'PROLOGUE' (02.01.2008, 13:27:30)
Import phase 'PROLOGUE' was successfully finished (02.01.2008, 13:27
Import phase 'CHECK_REQUIREMENTS' (02.01.2008, 13:27:31)
Import phase 'CHECK_REQUIREMENTS' was successfully finished (02.01.2
Import phase 'DISASSEMBLE' (02.01.2008, 13:27:31)
Import phase 'DISASSEMBLE' was successfully finished (02.01.2008, 13
Import phase 'ADD_TO_BUFFER' (02.01.2008, 13:27:52)
Import phase 'ADD_TO_BUFFER' was successfully finished (02.01.2008,
Import phase 'MODIFY_BUFFER' (02.01.2008, 13:27:52)
Import phase 'MODIFY_BUFFER' was successfully finished (02.01.2008,
Import phase 'IMPORT_OBJECT_LIST' (02.01.2008, 13:27:52)
Import phase 'IMPORT_OBJECT_LIST' was successfully finished (02.01.2
Import phase 'OBJECTS_LOCKED_?' (02.01.2008, 13:28:01)
Import phase 'OBJECTS_LOCKED_?' was successfully finished (02.01.200
Import phase 'TEST_IMPORT' (02.01.2008, 13:28:03)
Error during executing the tp command 'tp TST ALL D01 ...'
Details of the error situation can also be found in the import logs
Husos Horarios son GMT. La hora en este momento es 19:17:43.
