SAp Nw 7.0 EHP1 - Error Instalando Server Aplicación JAVA
Buena tarde:
Se esta instalando SAp Netweaver 7.0 EHP1, Oracle 10.2g, Red Hat Enterprise Linux 5, SAP Application Server JAVA. Central System En el paso 22 del proceso: Configure UME, se esta deteniendo la instalación con el siguiente error en el archivo de log BatchConfig.log /usr/sap/BJD/JC01/j2ee/admin/adminCFG.properties doesn't exist and will be created by batchconfig. /usr/sap/BJD/JC01/j2ee/admin/cfg/adminCFG.properties doesn't exist and will be created by batchconfig. /usr/sap/BJD/JC01/j2ee/deploying/dplOptions.options doesn't exist and will be created by batchconfig. /usr/sap/BJD/JC01/j2ee/configtool/config.properties doesn't exist and will be created by batchconfig. /usr/sap/BJD/JC01/j2ee/deploying/rdb.properties doesn't exist and will be created by batchconfig. .hotspot_compiler is missing in cluster_data. ChangeServicePropsTask has finished successfully. Service: ssl on dispatcher ChangeManagerPropsTask has finished successfully. Manager: LockingManager on dispatcher ChangeManagerPropsTask has finished successfully. Manager: ClusterManager on dispatcher Error occurred while working with Configuration.com.sap.engine.frame.core.configuration.NameNotFoundException: A property with the name "java.parameters" cannot be found in the PropertySheet "cluster_data/server/cfg/element-info.ID139743". at com.sap.engine.core.configuration.impl.addons.PropertyEntryImpl.<init>(PropertyEntryImpl.java:85) at com.sap.engine.core.configuration.impl.addons.PropertyEntryImpl.readPropertyEntry(PropertyEntryImpl.java:54) at com.sap.engine.core.configuration.impl.addons.PropertySheetImpl.getPropertyEntry(PropertySheetImpl.java:127) at com.sap.engine.configtool.batch.task.ElementInfoTask.setElementInfoProperties(ElementInfoTask.java:243) at com.sap.engine.configtool.batch.task.ElementInfoTask.go(ElementInfoTask.java:184) at com.sap.engine.configtool.batch.BatchConfig.go(BatchConfig.java:60) at com.sap.engine.configtool.batch.BatchConfig.main(BatchConfig.java:98) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:88) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:61) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:60) at java.lang.reflect.Method.invoke(Method.java:391) at com.sap.engine.offline.OfflineToolStart.main(OfflineToolStart.java:81) Por favor, su colaboración para buscar la solución |
Hola encontraste algo para tu problema?
Desplegado | |
