HOla amigos
Tengo un problema, estoy empezando a instalar el SOL MAN version 4.0 y me dice la guía que instale el motor de la base de datos , entonces al momento de instalar tengo este error:
02/21/08 12:58:38 MST BEGIN install AGENT SESSION (pid=13871)
(jobid=epi-sap--0037)
* Agent session started for user "root@epi-sap-". (pid=13871)
* Beginning Analysis Phase.
* Source:
epi-sap-:/var/SWINC/db27/UNIX/HP11_64/DBSW_EE/db2/
* Target: epi-sap-:/
* Target logfile: epi-sap-:/var/adm/sw/swagent.log
* Reading source for product information.
NOTE: The filesystems in the filesystem table will not be checked
against those currently mounted because the
"mount_all_filesystems" option is set to "false".
WARNING: The product "DB2V7CAE,r=7.1.1.40" is not compatible with this
system's architecture or operating system. If the OS has been
updated since this product was installed, a newer version
should be installed if available.
* This product will still be included in the task because the
"allow_incompatible" option is set to "true".
* Reading source for file information.
The prerequisite
"OS-Core.CMDS-AUX,r>=B.11.00,a=HP-UX_?.11.??_32/64,v=HP" for
fileset "DB2V7CAE.client,r=7.1.1.40" cannot be successfully
resolved.
The prerequisite
"OS-Core.CMDS-MIN,r>=B.11.00,a=HP-UX_?.11.??_32/64,v=HP" for
resolved.
The prerequisite
"SOE.SOE,r>=B.11.00,a=HP-UX_?.11.??_32/64,v=HP" for fileset
"DB2V7CAE.client,r=7.1.1.40" cannot be successfully resolved.
ERROR: The dependencies for fileset "DB2V7CAE.client,r=7.1.1.40"
cannot be resolved (see previous lines).
You must resolve the above dependencies before operating on
this fileset or change the "enforce_dependencies" option to
"false".
* Executing preDSA command.
* Summary of Analysis Phase:
ERROR: Exclude DB2V7CAE.client,r=7.1.1.40
ERROR: 1 of 1 filesets had Errors.
ERROR: The Analysis Phase had errors and warnings. See the above
output for details.
======= 02/21/08 12:58:38 MST END install AGENT SESSION (Cancelled)
(pid=13871) (jobid=epi-sap--0037)
El instalador es de los cds que SAP nos proporcionó
no se cual es el error o como puedo solucionarlo, o si es la versión si alguien me puede ayudar indicando cual es la correcta
Muchas gracias por las ayuda que me puedan dar
SAludos
DANny
* Source:
The prerequisite
resolved.
The prerequisite
resolved.
The prerequisite
"false".
output for details.
SAludos
DANny
