Programa para generar claves para Instalaciones SAP
  • wilcom
    Adjunto les dejo un programa que permite crear las claves para la instalación de SAP sin necesidad de generarlas por el SOLMAN.... Espero les sea de utilidad.
    *& Report ZSLM_KEY *
    *& ??SOLUTION MANAGER KEY *
    REPORT ZSLM_KEY.
    types: begin of dswpclientkey,
    INSTNO type num10,
    DBID(3),
    BUNDLE_ID(8),
    SERVICE_KEY(40),
    end of dswpclientkey.
    *data: dswpclientkey_w type standard table of dswpclientkey.
    DATA: P_VALUE(10),
    P_INSTNO(10).
    PARAMETERS: P_SID(3),
    P_SYSNO(2),
    P_SERVER(15).
    START-OF-SELECTION.
    PERFORM GET_SP_VALUE USING P_SID
    P_SYSNO
    P_SERVER
    P_INSTNO
    CHANGING P_VALUE.
    END-OF-SELECTION.
    WRITE P_VALUE.
    *& Form get_sp_value
    * text
    * -->P_PF_SID text
    * -->P_PF_SYSNO text
    * -->P_PF_SERVER text
    * <--P_PF_VALUE text
    FORM get_sp_value USING P_PF_SID
    P_PF_SYSNO
    P_PF_SERVER
    P_PF_INSTNO
    CHANGING P_PF_VALUE.
    CONSTANTS: lc_part_len TYPE i VALUE 5,
    lc_pw_len TYPE i VALUE 10,
    lc_allowed_chars(38) TYPE c VALUE
    '-0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ_'.
    data: lf_string(20) type c,
    lf_key type i,
    ls_key type dswpclientkey,
    lf_part(lc_part_len) type c,
    lf_finalf(lc_pw_len) type c,
    lf_finalx type xstring,
    lf_xbuffer type xstring,
    lf_opf(10) type c,
    lf_langu like sy-langu,
    lf_subrc like sy-subrc,
    lf_len type i,
    lo_conv_to_x TYPE REF TO cl_abap_conv_out_ce.
    clear: lf_string, lf_finalx, lf_opf.
    concatenate p_pf_sid p_pf_sysno p_pf_server into lf_string.
    * Large letters only
    translate lf_string to upper case.
    lf_langu = sy-langu.
    SET LOCALE LANGUAGE 'E'.
    lo_conv_to_x = cl_abap_conv_out_ce=>create( encoding = '1100' ).
    lf_len = STRLEN( lf_string ).
    IF lf_string(lf_len) CN lc_allowed_chars.
    else.
    * Fold the input string to a lc_part_len long string
    WHILE lf_len > 0.
    lf_part = lf_string(lc_part_len).
    SHIFT lf_string BY lc_part_len PLACES.
    CALL METHOD lo_conv_to_x->reset.
    CALL METHOD lo_conv_to_x->write( data = lf_part n = -1 ).
    lf_xbuffer = lo_conv_to_x->get_buffer( ).
    lf_finalx = lf_finalx BIT-XOR lf_xbuffer.
    ENDWHILE.
    lf_key = 12.
    PERFORM scramble USING lf_finalx
    lf_key
    lc_part_len
    CHANGING lf_finalf
    lf_subrc.
    if not lf_finalf is initial.
    p_pf_value = lf_finalf.
    ls_key-dbid = p_pf_sid.
    ls_key-instno = p_pf_instno.
    ls_key-bundle_id = 'SM_KEY'.
    ls_key-service_key = lf_finalf.
    if not p_pf_instno is initial.
    * insert dswpclientkey_w from ls_key.
    if sy-subrc <> 0.
    * update dswpclientkey_w from ls_key.
    endif.
    endif.
    else.
    clear p_pf_value.
    endif.
    endif.
    ENDFORM. " get_sp_value
    *& Form scramble
    * text
    * -->P_LF_FINALX text
    * -->P_LF_KEY text
    * -->P_LC_PART_LEN text
    * <--P_LF_finalf text
    * <--P_LF_SUBRC text
    FORM scramble USING iv_xstring TYPE xstring
    iv_key TYPE i
    iv_src_len TYPE i
    CHANGING lf_finalf
    lf_subrc LIKE sy-subrc.
    CONSTANTS: lc_max_len TYPE i VALUE 20,
    lc_mask(4) TYPE x VALUE '0000003F',
    lc_random(64) TYPE x VALUE
    'F0ED53B83244F1F876C67959FD4F13A2' &
    'C15195EC5483C234774943A27DE26596' &
    '5E5398789A17A33CD383A8B829FBDCA5' &
    '55D702778413ACDDF9B83116610E6DFA'.
    DATA: lv_key_index(4) TYPE x,
    lv_rand_index(4) TYPE x,
    lv_xkey(4) TYPE x,
    lv_xkey_shl_1(4) TYPE x,
    lv_xkey_shr_5(4) TYPE x,
    lv_scramble_byte TYPE x,
    lv_dest(lc_max_len) TYPE x,
    lv_index TYPE i,
    lv_len TYPE i.
    CLEAR lf_subrc.
    IF iv_src_len EQ 0. EXIT. ENDIF.
    lv_len = XSTRLEN( iv_xstring ).
    IF iv_src_len GT lc_max_len OR
    iv_src_len GT lv_len.
    lf_subrc = 2.
    EXIT.
    lv_xkey = iv_key.
    lv_xkey_shl_1 = iv_key * 2.
    lv_xkey_shr_5 = iv_key DIV 32.
    lv_rand_index = lv_xkey BIT-XOR lv_xkey_shr_5 BIT-XOR lv_xkey_shl_1.
    lv_rand_index = lv_rand_index BIT-AND lc_mask.
    lv_index = 0.
    DO iv_src_len TIMES.
    CATCH SYSTEM-EXCEPTIONS compute_int_times_overflow = 1.
    lv_key_index = ( iv_key * lv_index * lv_index ) - lv_index.
    ENDCATCH.
    IF sy-subrc <> 0.
    lf_subrc = 1.
    EXIT.
    lv_scramble_byte = lc_random+lv_rand_index(1) BIT-XOR
    lv_key_index+3(1).
    lv_dest+lv_index(1) = iv_xstring+lv_index(1) BIT-XOR
    lv_scramble_byte.
    lv_index = lv_index + 1.
    lv_rand_index = lv_rand_index + 1.
    ENDDO.
    IF lf_subrc <> 0.
    EXIT.
    WRITE lv_dest(iv_src_len) TO lf_finalf.
    ENDFORM.
