IMPORT_PROPER error update SPAM
  • plecha
    • 12
    Hola a tod@s,
    cuando estoy actualizando el SPAM/SAINT me da un error en el IMPORT_PROPER.
    en el log: SLOG0849.CSD
    START imp all CSD 20081201093343 DDIC sapdev 20081201093343
    INFO: event SAP_IMPORT_START triggered successfully
    INFO TBATG CONVERSION OF CSD N not needed DDIC sapdev 20081201093343
    START MOVE NAMETABS CSD 6 20081201093344 DDIC sapdev 20081201093343
    START tp_getprots CSD P 20081201093344 DDIC sapdev 20081201093343
    ERROR ALL CSD 6 0008 20081201093409 DDIC sapdev 20081201093343
    STOP tp_getprots CSD P 20081201093412 DDIC sapdev 20081201093343
    STOP MOVE NAMETABS CSD 6 20081201093412 DDIC sapdev 20081201093343
    ERROR: stopping on error 8 during MOVE NAMETABS
    STOP imp all CSD 0008 20081201093412 DDIC sapdev 20081201093343
    START imp all CSD 20081201095258 DDIC sapdev 20081201095258
    INFO TBATG CONVERSION OF CSD N not needed DDIC sapdev 20081201095258
    START MOVE NAMETABS CSD 6 20081201095258 DDIC sapdev 20081201095258
    START tp_getprots CSD P 20081201095258 DDIC sapdev 20081201095258
    ERROR ALL CSD 6 0008 20081201095323 DDIC sapdev 20081201095258
    STOP tp_getprots CSD P 20081201095326 DDIC sapdev 20081201095258
    STOP MOVE NAMETABS CSD 6 20081201095326 DDIC sapdev 20081201095258
    STOP imp all CSD 0008 20081201095326 DDIC sapdev 20081201095258
    En la Actions logs of the queue
    Import phase 'IMPORT_PROPER' (01.12.2008, 09:52:58)
    Error during executing the tp command 'tp IMPORT all CSD ...'
    tp return code: '0008' , tp message: 'A tool used by tp produced errors' , tp output:
    This is tp version 340.16.41 (release 640)
    Warning: Parameter IMPDP_BY_EVENT is no longer used.
    Warning: Parameter DICTIMP_PROC is no longer used.
    Warning: Parameter DBLIBPATH is no longer used.
    Warning: Parameter DBSWPATH is no longer used.
    tp returncode summary:
    TOOLS: Highest return code of single steps was: 8
    WARNS: Highest tp internal warning was: 0118
    standard output from tp and from tools called by tp:
    Details of the error situation can also be found in the import logs
    Interrupt the import due to an error situation (01.12.2008, 09:53:27)
    Display detailed informations concerning the error in phase 'IMPORT_PROPER'
    Abort the import due to an error situation (01.12.2008, 09:53:28)
    ¿Alguien me puede ayudar?
    Muchas gracias
    Imbabura
  • jgsanz
    • 293
    Posiblemente esto te ayude
    • koletas
      • 370
      Mira este link:
      https://www.sdn.sap.com/irj/scn/webl...=/pub/wlg/3930
      Busca en el help.sap.com SPAM PHASES. Relanzalo de nuevo en diálogo y si no en batch, busca dependencias o CRT's que añadir.
      SAP Basis Consultant
      koletas23@hotmail.com
