Crea el parámetro REC/CLIENT en el perfil de instancia de SAP, con uno de los siguientes valores:
ALL Table logging is activated in all clients. All change
operations for tables are
logged, according to the settings in the
ABAP Dictionary.
<Client1>,<Client2>,...,<ClientN> (1 <= N <= 10)
Table logging is only activated for the specified
clients. You can specify up to 10 different
clients.
Caution: Make sure there are no space characters before
or after the
separator ",".
