disp+work.exe stopped
  • yosoydekaslimon
    Buenas tardes
    Soy nuevo en el mundo sap, pero estoy encontrando bastantes inconvenientes para instalar SAPNWABAP701SR1_TRIAL
    Llevo ya cerca de 2 meses intentando instalar la aplicación y he observado peor nio ha sido posibl, he observado que al levantar la instancia, queda parada disp+work.exe
    Ruego vuestra ayuda, estoy bastante desesperado.
    La traza es la siguiente
    trc file: "dev_disp", trc level: 1, release: "701"
    sysno 02
    sid NSP
    systemid 560 (PC with Windows NT)
    relno 7010
    patchlevel 0
    patchno 29
    intno 20020600
    make: multithreaded, Unicode, optimized
    pid 936
    Thu Mar 04 22:38:37 2010
    kernel runs with dp version 241000(ext=110000) (@(#) DPLIB-INT-VERSION-241000-UC)
    length of sys_adm_ext is 576 bytes
    *** SWITCH TRC-HIDE on ***
    ***LOG Q00=> DpSapEnvInit, DPStart (02 936) [dpxxdisp.c 1261]
    shared lib "dw_xml.dll" version 29 successfully loaded
    shared lib "dw_xtc.dll" version 29 successfully loaded
    shared lib "dw_stl.dll" version 29 successfully loaded
    shared lib "dw_gui.dll" version 29 successfully loaded
    shared lib "dw_mdm.dll" version 29 successfully loaded
    rdisp/softcancel_sequence : -> 0,5,-1
    use internal message server connection to port 3902
    Thu Mar 04 22:38:41 2010
    *** WARNING => DpNetCheck: NiAddrToHost(1.0.0.0) took 4 seconds
    ***LOG GZZ=> 1 possible network problems detected - check tracefile and adjust the DNS settings [dpxxtool2.c 5529]
    MtxInit: 30000 0 0
    DpSysAdmExtInit: ABAP is active
    DpSysAdmExtInit: VMC (JAVA VM in WP) is not active
    DpIPCInit2: start server >localhost_NSP_02 <
    DpShMCreate: sizeof(wp_adm) 13632 (1704)
    DpShMCreate: sizeof(tm_adm) 4415616 (21968)
    DpShMCreate: sizeof(wp_ca_adm) 1664 (80)
    DpShMCreate: sizeof(appc_ca_adm) 1600 (80)
    DpCommTableSize: max/headSize/ftSize/tableSize=500/8/528056/528064
    DpShMCreate: sizeof(comm_adm) 528064 (1048)
    DpSlockTableSize: max/headSize/ftSize/fiSize/tableSize=0/0/0/0/0
    DpShMCreate: sizeof(slock_adm) 0 (96)
    DpFileTableSize: max/headSize/ftSize/tableSize=0/0/0/0
    DpShMCreate: sizeof(file_adm) 0 (72)
    DpShMCreate: sizeof(vmc_adm) 0 (1544)
    DpShMCreate: sizeof(wall_adm) (38456/34360/64/184)
    DpShMCreate: sizeof(gw_adm) 48
    DpShMCreate: SHM_DP_ADM_KEY (addr: 060D0040, size: 5042120)
    DpShMCreate: allocated sys_adm at 060D0040
    DpShMCreate: allocated wp_adm at 060D2170
    DpShMCreate: allocated tm_adm_list at 060D56B0
    DpShMCreate: allocated tm_adm at 060D56E0
    DpShMCreate: allocated wp_ca_adm at 0650B760
    DpShMCreate: allocated appc_ca_adm at 0650BDE0
    DpShMCreate: allocated comm_adm at 0650C420
    DpShMCreate: system runs without slock table
    DpShMCreate: system runs without file table
    DpShMCreate: allocated vmc_adm_list at 0658D2E0
    DpShMCreate: allocated gw_adm at 0658D320
    DpShMCreate: system runs without vmc_adm
    DpShMCreate: allocated ca_info at 0658D350
    DpShMCreate: allocated wall_adm at 0658D358
    MBUF state OFF
    DpCommInitTable: init table for 500 entries
    rdisp/queue_size_check_value : -> off
    ThTaskStatus: rdisp/reset_online_during_debug 0
    *** ERROR => ztta/cua_area is 180000. [sapinit.c 975]
    *** ERROR => ztta/cua_area adjusted to 500000. [sapinit.c 979]
    EmInit: MmSetImplementation( 2 ).
    MM global diagnostic options set: 0
    <ES> client 0 initializing ....
    <ES> InitFreeList
    <ES> block size is 1024 kByte.
    Using implementation view
    <EsNT> Using memory model view.
    <EsNT> Memory Reset disabled as NT default
    <ES> 1023 blocks reserved for free list.
    ES initialized.
    Thu Mar 04 22:38:42 2010
    rdisp/http_min_wait_dia_wp : 1 -> 1
    ***LOG CPS=> DpLoopInit, ICU ( 3.0 3.0 4.0.1) [dpxxdisp.c 1656]
    ***LOG Q0K=> DpMsAttach, mscon ( localhost) [dpxxdisp.c 12362]
    *** DP_FATAL_ERROR => DpMsAttach: local hostname 'localhost' is resolved to loopback address (cf. SAP note 1054467 for details)
    *** DISPATCHER EMERGENCY SHUTDOWN ***
    increase tracelevel of WPs
    [DpWpDied] W0 lives (PID:3600 HANDLE:1576)
    killing W0-3600 (SIGUSR2)
    *** ERROR => DpWpKill(3600, SIGUSR2) failed [dpxxtool.c 2549]
    [DpWpDied] W1 lives (PID:3496 HANDLE:1568)
    killing W1-3496 (SIGUSR2)
    *** ERROR => DpWpKill(3496, SIGUSR2) failed [dpxxtool.c 2549]
    [DpWpDied] W2 lives (PID:672 HANDLE:1564)
    killing W2-672 (SIGUSR2)
    *** ERROR => DpWpKill(672, SIGUSR2) failed [dpxxtool.c 2549]
    [DpWpDied] W3 lives (PID:2012 HANDLE:1560)
    killing W3-2012 (SIGUSR2)
    *** ERROR => DpWpKill(2012, SIGUSR2) failed [dpxxtool.c 2549]
    [DpWpDied] W4 lives (PID:1716 HANDLE:1556)
    killing W4-1716 (SIGUSR2)
    *** ERROR => DpWpKill(1716, SIGUSR2) failed [dpxxtool.c 2549]
    [DpWpDied] W5 lives (PID:1800 HANDLE:1552)
    killing W5-1800 (SIGUSR2)
    *** ERROR => DpWpKill(1800, SIGUSR2) failed [dpxxtool.c 2549]
    [DpWpDied] W6 lives (PID:3868 HANDLE:1548)
    killing W6-3868 (SIGUSR2)
    *** ERROR => DpWpKill(3868, SIGUSR2) failed [dpxxtool.c 2549]
    [DpWpDied] W7 lives (PID:3824 HANDLE:1544)
    killing W7-3824 (SIGUSR2)
    *** ERROR => DpWpKill(3824, SIGUSR2) failed [dpxxtool.c 2549]
    NiWait: sleep (10000ms) ...
    NiISelect: timeout 10000ms
    NiISelect: maximum fd=1617
    NiISelect: read-mask is NULL
    NiISelect: write-mask is NULL
  • Tonijua
    • 801
    Mmm yo no se mucho de esto, pero lo he instalado dos veces, dejame un correo y te mando un manual que tengo en dnd explica como se instala.
    Tonijua.
    Moderador FICO
    • BREZHNEV
      • 478
      hola, de casualidad has leido los pre requisitos para instalar ese producto?, cuando lo descargas te descarga tambien ese documento, y ahi se indica que cosas tienes que configurar en tu PC, para que no tengas problemas, pero me parece que no lo has hecho, ya que el error:
      me hace pensar que no tienes sificiente memoria (fisica o de paginacion), adicionalmente el error:
      me hace pensar que no has configurado la red que te sugiere SAP de la manera correcta (creo que es 10.10.0.10), ni tampoco el atchivo ETC.
      por favor indicame si configuraste todos los pre requisitos correctamente, asi como cuanto de memoria tienes en tu PC (fisica y de paginacion).
      salu2
      ==»BREZHNEV«==
