Hola Buenas tardes,
Me gustaria saber si alguno de ustedes ha tenido alguna experiencia con esto:
El servicio SAPROUTER en windows no levanta, se corta mandando el mensaje de windows 1067 error inesperado:
Actividades:
-Revision de etc host si esta la ip y nombre de host
-Revision de etc services si esta la ip y el puerto 3299
-Revision dev_rout dice:
trc file: "dev_rout", trc level: 1, release: "700"
Fri Jul 22 19:52:04 2011
SAP Network Interface Router, Version 38.10
command line arg 0: saprouter.exe
command line arg 1: -r
main: pid = 5408, ppid = 0, port = 3299, parent port = 0 (0 = parent is not a saprouter)
reading routtab: './saprouttab'
*** ERROR => SNC field without SNC active, skip line 3 [nirout.cpp 7775]
*** ERROR => SNC field without SNC active, skip line 6 [nirout.cpp 7775]
*** ERROR => SNC field without SNC active, skip line 7 [nirout.cpp 7775]
*** ERROR => SNC field without SNC active, skip line 8 [nirout.cpp 7775]
*** ERROR => SNC field without SNC active, skip line 9 [nirout.cpp 7775]
-Revision de saproutrab: (hay dos lineas que me llaman la atencion)dice:
# Access from Iternet - R/3 Frontend to local Network
P * 194.39.131.34 3299 suim780
y
# SNC connection to local system for R/3-Support
KP "p:CN=sapserv2, OU=SAProuter, O=SAP, C=DE" 99.34.48.92 3389 #App26.mexinox.mx, donde app26 = 99.34.48.92 ip y host de server en cuestion.
-Revision de cadena en propiedades del servicio en windows:
e:\usr\saprouter\saprouter.exe service -r -W 60000 -R e:\usr\saprouter\saprouttab –K "p:CN= app26.mexinox.mx, OU=0001119592, OU=SAProuter, O=SAP, C=DE "
-Revision de archivo log en E:\usr\SAPRouter
Mon Jun 27 11:03:45 2011 INIT LOGFILE
Mon Jun 27 11:03:45 2011 READ ROUTTAB ./saprouttab o.k.
Mon Jun 27 11:52:53 2011 CONNECT FROM C1/- host 99.34.55.188/3169 (app34.mexinox.mx)
Mon Jun 27 11:52:53 2011 PERM DENIED C1/- host 99.34.55.188 (app34.mexinox.mx) to 194.39.131.34/sapdp99
Mon Jun 27 11:52:53 2011 DISCONNECT C1/- host 99.34.55.188/3169 (app34.mexinox.mx)
Mon Jun 27 11:52:53 2011 CONNECT FROM C1/- host 99.34.55.188/3170 (app34.mexinox.mx)
Mon Jun 27 11:52:53 2011 DISCONNECT C1/- host 99.34.55.188/3170 (app34.mexinox.mx)
Mon Jun 27 11:52:53 2011 CONNECT FROM C1/- host 99.34.55.188/3171 (app34.mexinox.mx)
-Revision por linea de comando al levantarlo dice:
trcfile dev_route
nologiin active
routtab cannot open ´./sapouttab' : exit program!!! (antes no arcaba esto de exit program!!! )
-Pensaos que es un problema de puertos ya que ya eliminamos el servicio y lo volvimos a crear en windows y no funciona.
Alguien tiene algun otro comentario porfavor muchas gracias por su ayuda a todos.
Actividades:
y
trcfile dev_route
nologiin active
