Estimados foristas les mando este error q me presenta el instalar el sap ecc 6.0 es en la parte de cuando le faltan 2 tareas para acompletar la instalación de abap el log pertenece al archivo PCL2.log
alguna sugerencia?
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: START OF LOG: 20111210013352
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: sccsid @(#) $Id: //bas/701_REL/src/R3ld/R3load/R3ldmain.c#5 $ SAP
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: version R7.01/V1.4 [UNICODE]
Compiled Feb 24 2009 23:41:07
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe -ctf I Z:\Descomprimidos\51037623_InstallationExport\5103 7623_2\DATA_UNITS\EXPORT_2\DATA\PCL2.STR C:\Program Files\sapinst_instdir\ERPEhP4\AS-ABAP\ORA\CENTRAL\DDLORA_LRG.TPL PCL2.TSK ORA -l PCL2.log
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: job completed
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: END OF LOG: 20111210013352
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: START OF LOG: 20111210013353
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe -i PCL2.cmd -dbcodepage 4103 -l PCL2.log -stop_on_error
DbSl Trace: ORA-1403 when accessing table SAPUSER
(DB) INFO: connected to DB
(DB) INFO: DbSlControl(DBSL_CMD_NLS_CHARACTERSET_GET): UTF8
(DB) INFO: PCL2 created #20111210013355
(RFF) ERROR: file PCL2.002 not found
(TFH) ERROR: Unable to close Z:\Descomprimidos\51037623_InstallationExport\5103 7623_2\DATA_UNITS\EXPORT_2\DATA\PCL2.001
(DB) INFO: disconnected from DB
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: job finished with 1 error(s)
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: END OF LOG: 20111210013924
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: START OF LOG: 20111210175403
(DB) INFO: PCL2 deleted/truncated #20111210175422
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: END OF LOG: 20111210175734
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: START OF LOG: 20111211084536
(DB) INFO: PCL2 deleted/truncated #20111211084557
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: END OF LOG: 20111211084840
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: START OF LOG: 20111211085910
(DB) INFO: PCL2 deleted/truncated #20111211085928
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: END OF LOG: 20111211090221
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: START OF LOG: 20111211092152
(DB) INFO: PCL2 deleted/truncated #20111211092211
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: END OF LOG: 20111211092503
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: START OF LOG: 20111211094526
DbSl Trace: OCI-call 'OCISessionBegin' failed with rc=1034
DbSl Trace: CONNECT failed with sql error '1034'
(DB) ERROR: db_connect rc = 256
(DB) ERROR: DbSlErrorMsg rc = 99
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: END OF LOG: 20111211094526
alguna sugerencia?
