Servicio de Base de Datos Caídos en Servidor XIP
  • luisanac
    Verificando el log en la siguiente ruta: /home/xipadm/startdb.log.
    Opening Database...
    ERR
    -24988,ERR_SQL: SQL error
    -902,I/O error
    3,Database state: OFFLINE
    6,Internal errorcode, Error code 9050 "disk_not_accessible"
    20017,RestartFilesystem failed with 'I/O error'
    Además dando startsap sale :
    Checking ADA db Database
    ABAP Database is not available via R3trans
    Starting SAP-Collector Daemon
    * This is Saposcol Version COLL 20.95 700 - v2.16, AMD/Intel x86_64 with Linux, 2008/08/28
    * Usage: saposcol -l: Start OS Collector
    * saposcol -k: Stop OS Collector
    * saposcol -d: OS Collector Dialog Mode
    * saposcol -s: OS Collector Status
    * The OS Collector (PID 23662) is already running .....
    saposcol already running
    Running /usr/sap/XIP/SYS/exe/run/startdb
    Trying to start database ...
    Log file: /home/xipadm/startdb.log
    /usr/sap/XIP/SYS/exe/run/startdb: line 146: Warning!: command not found
    /usr/sap/XIP/SYS/exe/run/startdb: line 147: [: -lt: unary operator expected
    Database start failed
    DB startup failed
    Editado por última vez por luisanac; 18/10/2013, 15:13:38.
