Buenos días,
Estoy instalando la versión 730 de Sap logon en un equipo que tiene Windows 8 y al intentar entrar en el sistema, me da el siguiente error:
Exception condition "CNTL_ERROR" raised.
Adjunto mas abajo detalle de error.
Por favor, alguien sabe como se peude arreglar?
Muchas gracias
Detalle error:
Texto breve
¿Qué ha sucedido?
The current ABAP/4 program encountered an unexpected
situation.
¿Qué puede hacer?
Note down which actions and inputs caused the error.
To process the problem further, contact you SAP system
administrator.
Using Transaction ST22 for ABAP Dump Analysis, you can look
at and manage termination messages, and you can also
keep them for a long time.
Anál.errores
A RAISE statement in the program "SAPLCNDP" raised the exception
condition "CNTL_ERROR".
Since the exception was not intercepted by a superior
program, processing was terminated.
Short description of exception condition:
Control Error
For detailed documentation of the exception condition, use
Transaction SE37 (Function Library). You can take the called
function module from the display of active calls.
Notas para corregir errores
If the error occures in a non-modified SAP program, you may be able to
find an interim solution in an SAP Note.
If you have access to SAP Notes, carry out a search with the following
keywords:
"RAISE_EXCEPTION" " "
"SAPLCNDP" or "LCNDPU40"
"DP_SYNC_URLS"
or
"SAPLCNDP" "CNTL_ERROR"
or
"SAPLSMTR_NAVIGATION " "CNTL_ERROR"
If you cannot solve the problem yourself and want to send an error
notification to SAP, include the following information:
1. The description of the current problem (short dump)
To save the description, choose "System->List->Save->Local File
(Unconverted)".
2. Corresponding system log
Display the system log by calling transaction SM21.
Restrict the time interval to 10 minutes before and five minutes
after the short dump. Then choose "System->List->Save->Local File
(Unconverted)".
3. If the problem occurs in a problem of your own or a modified SAP
program: The source code of the program
In the editor, choose "Utilities->More
Utilities->Upload/Download->Download".
4. Details about the conditions under which the error occurred or which
actions and input led to the error.
Muchas gracias
Detalle error:
Texto breve
¿Qué ha sucedido?
situation.
¿Qué puede hacer?
administrator.
Anál.errores
Control Error
keywords:
"DP_SYNC_URLS"
or
or
(Unconverted)".
(Unconverted)".
