Problema con disp+work.exe no corre
  • Arquilanda
    Amigos soy nuevo en SAP, sin mucho conocimiento, agradezco me ayuden:
    trc file: "dev_disp", trc level: 1, release: "721"
    sysno 00
    sid PRB
    systemid 562 (PC with Windows NT)
    relno 7210
    patchlevel 0
    patchno 402
    intno 20020600
    make multithreaded, Unicode, 64 bit, optimized
    profile \\PruebaSapPRB\sapmnt\PRB\SYS\profile\PRB_DVEBMGS0 0_PruebaSapPRB
    pid 1388
    kernel runs with dp version 139000(ext=121000) (@(#) DPLIB-INT-VERSION-139000-UC)
    length of sys_adm_ext is 592 bytes
    *** SWITCH TRC-HIDE on ***
    ***LOG Q00=> DpSapEnvInit, DPStart (00 1388) [dpxxdisp.c 1323]
    shared lib "dw_xml.dll" version 402 successfully loaded
    shared lib "dw_xtc.dll" version 402 successfully loaded
    shared lib "dw_stl.dll" version 402 successfully loaded
    shared lib "dw_gui.dll" version 402 successfully loaded
    shared lib "dw_mdm.dll" version 402 successfully loaded
    shared lib "dw_rndrt.dll" version 402 successfully loaded
    shared lib "dw_abp.dll" version 402 successfully loaded
    shared lib "dw_sym.dll" version 402 successfully loaded
    Mon Feb 15 09:57:08 2016
    shared lib "dw_aci.dll" version 402 successfully loaded
    rdisp/softcancel_sequence : -> 0,5,-1
    use internal message server connection to port 3901
    rdisp/dynamic_wp_check : 1
    rdisp/calculateLoadAverage : 1
    Mon Feb 15 09:57:12 2016
    *** WARNING => DpNetCheck: NiAddrToHost(1.0.0.0) took 4 seconds
    ***LOG GZZ=> 1 possible network problems detected - check tracefile and adjust the DNS settings [dpxxtool2.c 6525]
    MtxInit: 30000 0 0
    DpSysAdmExtInit: ABAP is active
    DpSysAdmExtInit: VMC (JAVA VM in WP) is not active
    display_tcp_ip: 0
    Set Check Logoff Flags to 0x0
    DpIPCInit2: write dp-profile-values into sys_adm_ext
    DpIPCInit2: start server >PruebaSapPRB_PRB_00 <
    DpShMCreate: sizeof(wp_adm) 40608 (2256)
    DpShMCreate: sizeof(tm_adm) 5517056 (27448)
    DpShMCreate: sizeof(wp_ca_adm) 64000 (64)
    DpShMCreate: sizeof(appc_ca_adm) 64000 (64)
    DpCommTableSize: max/headSize/ftSize/tableSize=500/16/1392064/1392080
    DpShMCreate: sizeof(comm_adm) 1392080 (2768)
    DpSlockTableSize: max/headSize/ftSize/fiSize/tableSize=0/0/0/0/0
    DpShMCreate: sizeof(slock_adm) 0 (296)
    DpFileTableSize: max/headSize/ftSize/tableSize=0/0/0/0
    DpShMCreate: sizeof(file_adm) 0 (80)
    DpShMCreate: sizeof(vmc_adm) 0 (2160)
    DpShMCreate: sizeof(wall_adm) (41664/42896/64/192)
    DpShMCreate: sizeof(gw_adm) 48
    DpShMCreate: sizeof(j2ee_adm) 3952
    DpShMCreate: SHM_DP_ADM_KEY (addr: 0000000000210050, size: 7180576)
    DpShMCreate: allocated sys_adm at 0000000000210060
    DpShMCreate: allocated wp_adm_list at 00000000002130B0
    DpShMCreate: allocated wp_adm at 00000000002132A0
    DpShMCreate: allocated tm_adm_list at 000000000021D150
    DpShMCreate: allocated tm_adm at 000000000021D1A0
    DpShMCreate: allocated wp_ca_adm at 00000000007600B0
    DpShMCreate: allocated appc_ca_adm at 000000000076FAC0
    DpShMCreate: allocated comm_adm at 000000000077F4D0
    DpShMCreate: system runs without slock table
    DpShMCreate: system runs without file table
    DpShMCreate: allocated vmc_adm_list at 00000000008D32B0
    DpShMCreate: system runs without vmc_adm
    DpShMCreate: allocated gw_adm at 00000000008D3360
    DpShMCreate: allocated j2ee_adm at 00000000008D33A0
    DpShMCreate: allocated ca_info at 00000000008D4320
    DpShMCreate: allocated wall_adm at 00000000008D43B0
    Mon Feb 15 09:57:13 2016
    DpCommAttachTable: attached comm table (header=000000000077F4D0/ft=000000000077F4E0)
    DpSysAdmIntInit: initialize sys_adm
    rdisp/test_roll : roll strategy is DP_NORMAL_ROLL
    dia token check not active (10 token)
    MBUF state OFF
    DpCommInitTable: init table for 500 entries
    DpRqQInit: keep protect_queue / slots_per_queue 0 / 2001 in sys_adm
    rdisp/queue_size_check_value : -> on,50,30,40,500,50,500,80
    EmInit: MmSetImplementation( 2 ).
    MM global diagnostic options set: 0
    <ES> client 0 initializing ....
    <ES> EsILock: use Mutex for locking
    <ES> InitFreeList
    <ES> block size is 4096 kByte.
    <ES> Info: em/initial_size_MB( 8115MB) not multiple of em/blocksize_KB( 4096KB)
    <ES> Info: em/initial_size_MB rounded up to 8116MB
    Using implementation view
    <EsNT> Using memory model view.
    <EsNT> Memory Reset disabled as NT default
    <ES> 2028 blocks reserved for free list.
    ES initialized.
    mm.dump: set maximum dump mem to 192 MB
    mm.dump: set global maximum dump mem to 192 MB
    EsRegisterEmCheck: Register EmGetEsHandles at 000007F70446B1E0
    DpVmcSetActive: set vmc state DP_VMC_NOT_ACTIVE
    MPI: dynamic quotas disabled.
    MPI init: pipes=4000 buffers=1279 reserved=383 quota=10%
    rdisp/http_min_wait_dia_wp : 1 -> 1
    ***LOG CPS=> DpLoopInit, ICU ( 4.0.1 4.0.1 5.1) [dpxxdisp.c 1709]
    ***LOG Q0K=> DpMsAttach, mscon ( PruebaSapPRB) [dpxxdisp.c 12944]
    MBUF state LOADING
    DpStartStopMsg: send start message (myname is >PruebaSapPRB_PRB_00 <)
    DpStartStopMsg: start msg sent to message server o.k.
    CCMS: Initialized monitoring segment of size 60000000.
    CCMS: Initialized CCMS Headers in the shared monitoring segment.
    CCMS: Checking Downtime Configuration of Monitoring Segment.
    CCMS: AlMsUpload called by wp 1024.
    Mon Feb 15 09:57:14 2016
    CCMS: AlMsUpload successful for E:\usr\sap\PRB\DVEBMGS00\log\ALMTTREE.DAT (755 MTEs).
    CCMS: start to initalize 3.X shared alert area (first segment).
    DpMBufHwIdSet: set Hardware-ID
    ***LOG Q1C=> DpMBufHwIdSet [dpxxmbuf.c 1296]
    MBUF state ACTIVE
    DpWpBlksLow: max wp blocks in queue is 800 (80 %)
    MBUF component UP
    DpMsgProcess: 1 server in MBUF
    DpAppcBlksLow: max appc blocks in queue is 500 (50 %)
    Mon Feb 15 09:58:53 2016
    *** ERROR => DpHdlDeadWp: W1 (pid 3204) died (severity=0, status=0) [dpxxwp.c 1746]
    *** ERROR => DpHdlDeadWp: W11 (pid 3284) died (severity=0, status=0) [dpxxwp.c 1746]
    *** ERROR => DpHdlDeadWp: W12 (pid 3292) died (severity=0, status=0) [dpxxwp.c 1746]
    Mon Feb 15 09:59:13 2016
    *** ERROR => DpHdlDeadWp: W3 (pid 3220) died (severity=0, status=0) [dpxxwp.c 1746]
    *** ERROR => DpHdlDeadWp: W5 (pid 3236) died (severity=0, status=0) [dpxxwp.c 1746]
    *** ERROR => DpHdlDeadWp: W9 (pid 3268) died (severity=0, status=0) [dpxxwp.c 1746]
    Mon Feb 15 09:59:33 2016
    *** ERROR => DpHdlDeadWp: W0 (pid 3196) died (severity=0, status=0) [dpxxwp.c 1746]
    *** ERROR => DpHdlDeadWp: W2 (pid 3212) died (severity=0, status=0) [dpxxwp.c 1746]
    *** ERROR => DpHdlDeadWp: W4 (pid 3228) died (severity=0, status=0) [dpxxwp.c 1746]
    *** ERROR => DpHdlDeadWp: W6 (pid 3244) died (severity=0, status=0) [dpxxwp.c 1746]
    *** ERROR => DpHdlDeadWp: W7 (pid 3252) died (severity=0, status=0) [dpxxwp.c 1746]
    *** ERROR => DpHdlDeadWp: W8 (pid 3260) died (severity=0, status=0) [dpxxwp.c 1746]
    *** ERROR => DpHdlDeadWp: W10 (pid 3276) died (severity=0, status=0) [dpxxwp.c 1746]
    *** ERROR => DpHdlDeadWp: W13 (pid 3300) died (severity=0, status=0) [dpxxwp.c 1746]
    *** ERROR => DpHdlDeadWp: W14 (pid 3308) died (severity=0, status=0) [dpxxwp.c 1746]
    *** ERROR => DpHdlDeadWp: W15 (pid 3316) died (severity=0, status=0) [dpxxwp.c 1746]
    *** DP_FATAL_ERROR => DpWPCheck: no more work processes
    *** DISPATCHER EMERGENCY SHUTDOWN ***
    increase tracelevel of WPs
    NiWait: sleep (10000ms) ...
    NiISelect: timeout 10000ms
    NiISelect: maximum fd=1021
    NiISelect: read-mask is NULL
    NiISelect: write-mask is NULL
    Mon Feb 15 09:59:43 2016
    NiISelect: TIMEOUT occured (10000ms)
    dump system status
    Workprocess Table (long) Mon Feb 15 14:29:43 2016
    No Type Pid Status Cause Start Rstr Err Sem Time Program Cl User Action Table
    0 DIA -1 Ended no no 1 0 0 NO_ACTION
    1 DIA -1 Ended no no 1 0 0 NO_ACTION
    2 DIA -1 Ended no no 1 0 0 NO_ACTION
    3 DIA -1 Ended no no 1 0 0 NO_ACTION
    4 DIA -1 Ended no no 1 0 0 NO_ACTION
    5 DIA -1 Ended no no 1 0 0 NO_ACTION
    6 DIA -1 Ended no no 1 0 0 NO_ACTION
    7 DIA -1 Ended no no 1 0 0 NO_ACTION
    8 DIA -1 Ended no no 1 0 0 NO_ACTION
    9 DIA -1 Ended no no 1 0 0 NO_ACTION
    10 UPD -1 Ended no no 1 0 0 NO_ACTION
    11 BTC -1 Ended no no 1 0 0 NO_ACTION
    12 BTC -1 Ended no no 1 0 0 NO_ACTION
    13 BTC -1 Ended no no 1 0 0 NO_ACTION
    14 SPO -1 Ended no no 1 0 0 NO_ACTION
    15 UP2 -1 Ended no no 1 0 0 NO_ACTION
    Dispatcher Queue Statistics Mon Feb 15 14:29:43 2016
    | Typ | now | high | max | writes | reads |
    | NOWP | 0 | 2 | 2000 | 6 | 6 |
    | DIA | 7 | 7 | 2000 | 7 | 0 |
    | UPD | 0 | 0 | 2000 | 0 | 0 |
    | ENQ | 0 | 0 | 2000 | 0 | 0 |
    | BTC | 0 | 0 | 2000 | 0 | 0 |
    | SPO | 1 | 1 | 2000 | 1 | 0 |
    | UP2 | 0 | 0 | 2000 | 0 | 0 |
    max_rq_id 13
    wake_evt_udp_now 1
    wake events total 11, udp 7 ( 63%), shm 4 ( 36%)
    since last update total 11, udp 7 ( 63%), shm 4 ( 36%)
    DpGetLoadAverage: la1[1] = 2.166667 / -1.000000 %
    DpGetLoadAverage: la5[1] = 0.633333 / -1.000000 %
    DpGetLoadAverage: la15[1] = 0.266667 / -1.000000 %
    Dispatcher Load Statistics
    | Typ | LA1 | LA5 | LA15 |
    | DIA | 2.167 | 0.633 | 0.267 |
    DpGetLoadAverage: la1[2] = 0.000000 / -1.000000 %
    DpGetLoadAverage: la5[2] = 0.000000 / -1.000000 %
    DpGetLoadAverage: la15[2] = 0.000000 / -1.000000 %
    | UPD | 0.000 | 0.000 | 0.000 |
    DpGetLoadAverage: la1[3] = 0.000000 / -1.000000 %
    DpGetLoadAverage: la5[3] = 0.000000 / -1.000000 %
    DpGetLoadAverage: la15[3] = 0.000000 / -1.000000 %
    | ENQ | 0.000 | 0.000 | 0.000 |
    DpGetLoadAverage: la1[4] = 0.000000 / -1.000000 %
    DpGetLoadAverage: la5[4] = 0.000000 / -1.000000 %
    DpGetLoadAverage: la15[4] = 0.000000 / -1.000000 %
    | BTC | 0.000 | 0.000 | 0.000 |
    DpGetLoadAverage: la1[5] = 0.333333 / -1.000000 %
    DpGetLoadAverage: la5[5] = 0.066667 / -1.000000 %
    DpGetLoadAverage: la15[5] = 0.033333 / -1.000000 %
    | SPO | 0.333 | 0.067 | 0.033 |
    DpGetLoadAverage: la1[6] = 0.000000 / -1.000000 %
    DpGetLoadAverage: la5[6] = 0.000000 / -1.000000 %
    DpGetLoadAverage: la15[6] = 0.000000 / -1.000000 %
    | UP2 | 0.000 | 0.000 | 0.000 |
    Dump of tm_adm structure: Mon Feb 15 14:29:43 2016
    Term uid man user term lastop mod wp ta a/i (modes)
    Workprocess Comm. Area Blocks Mon Feb 15 14:29:43 2016
    Slots: 1000, Used: 1, Max: 2
    | id | owner | pid | eyecatcher |
    | 0 | DISPATCHER | -1 | 0xdeadbeef |
    NiWait: sleep (5000ms) ...
    NiISelect: timeout 5000ms
    Mon Feb 15 09:59:48 2016
    NiISelect: TIMEOUT occured (5000ms)
    DpHalt: shutdown server >PruebaSapPRB_PRB_00 < (normal)
    DpJ2eeDisableRestart
    DpMBufRead: read server list from MBUF (1 entries)
    DpMBufMod: name [PruebaSapPRB_PRB_00 ], types 187 state 3 (0x0 0x0 0x0 0x0)
    DpMBufMod: call hooks for event MBUF_DPEVT_DSTATE (5->3)
    AdGetSelfIdentRecord: > <
    AdCvtRecToExt: opcode 60 (AD_SELFIDENT), ser 0, ex 0, errno 0
    AdCallRegisteredCvtToExt: opcode 60
    AdCallRegisteredCvtToExt: opcode 60 call 000007F703ACCC70
    AdCallRegisteredCvtToExt: opcode 60 exit rc=SAP_O_K
    AdCvtRecToExt: opcode 40 (AD_MSBUF), ser 0, ex 0, errno 0
    AdCallRegisteredCvtToExt: opcode 40
    AdCallRegisteredCvtToExt: opcode 40 call 000007F704103CB0
    AdCallRegisteredCvtToExt: opcode 40 exit rc=SAP_O_K
    DpWpBlksLow: wp_blks_in_queue/threshold/max = 1/800/1000
    DpLockWpBlkEx: lock wp ca_blk 1
    make DISP owner of wp_ca_blk 1
    DpRqIPutIntoQ: put elem in queue DIA, elems=8
    DpRqPutIntoQueue: put request into queue (reqtype 1, prio LOW, rq_id 14)
    MBUF server state SHUTDOWN
    DpModState: change state STARTING -> SHUTDOWN
    NiBufSend starting
    NiIWrite: hdl 17 sent data (wrt=110,pac=1,MESG_IO)
    MsINiWrite: sent 110 bytes
    MsIModState: change state to SHUTDOWN
    DpModState: change server state from STARTING to SHUTDOWN
    DpHalt: switch off Shared memory profiling
    ShmProtect( 57, 3 )
    ShmProtect(SHM_PROFILE, SHM_PROT_RW
    ShmProtect( 57, 1 )
    ShmProtect(SHM_PROFILE, SHM_PROT_RD
    DpWakeUpWps: wake up all wp's
    DpHalt: stop work processes
    DpHalt: stop gateway
    killing process (3180) (SOFT_KILL)
    DpHalt: stop icman
    killing process (3188) (SOFT_KILL)
    DpHalt: terminate gui connections
    DpHalt: wait for end of work processes
    DpHalt: wait for end of gateway
    [DpProcDied] Process lives (PID:3180 HANDLE:844)
    DpHalt: waiting for termination of gateway ...
    NiWait: sleep (1000ms) ...
    NiISelect: timeout 1000ms
    Mon Feb 15 09:59:49 2016
    NiISelect: TIMEOUT occured (1000ms)
    *** ERROR => [DpProcDied] Process died (PID:3180 HANDLE:844 rc:0x0) [dpnttool2.c 147]
    DpHalt: wait for end of icman
    [DpProcDied] Process lives (PID:3188 HANDLE:868)
    DpHalt: waiting for termination of icman ...
    Mon Feb 15 09:59:50 2016
    Mon Feb 15 09:59:51 2016
    Mon Feb 15 09:59:52 2016
    *** ERROR => [DpProcDied] Process died (PID:3188 HANDLE:868 rc:0x0) [dpnttool2.c 147]
    DpStartStopMsg: send stop message (myname is >PruebaSapPRB_PRB_00 <)
    DpStartStopMsg: Write AD_STARTSTOP message with type= 0, name=PruebaSapPRB_PRB_00 , sapsysnr= 0, hostname=PruebaSapPRB
    AdCvtRecToExt: opcode 4 (AD_STARTSTOP), ser 0, ex 0, errno 0
    AdCallRegisteredCvtToExt: opcode 4 call 000007F703AEF6B0
    AdCallRegisteredCvtToExt: opcode 4 exit rc=SAP_O_K
    DpConvertRequest: net size = 189 bytes
    NiBufIAlloc: malloc MSLIB-BUF, to 32110 bytes
    NiBufSend starting
    NiIWrite: hdl 17 sent data (wrt=562,pac=1,MESG_IO)
    MsINiWrite: sent 562 bytes
    MsISndTypeOnce: send msg (ms hdr/msg 110/452 bytes) to MSG_SERVER, type 1
    DpStartStopMsg: stop msg sent to message server o.k.
    NiBufIAlloc: malloc NIBUF-IN, to 32110 bytes
    NiIRead: hdl 17 received data (rcd=274,pac=1,MESG_IO)
    NiBufIIn: NIBUF len=274
    NiBufIIn: packet complete for hdl 17
    NiBufReceive starting
    MsINiRead: received 274 bytes
    MsIReceive: received msg (ms hdr/msg 110/164 bytes), flag 1, from MSG_SERVER , typ 0, key -
    DpHalt: received 164 bytes from message server
    NiIRead: hdl 17 recv would block (errno=EAGAIN)
    NiIRead: read for hdl 17 timed out (0ms)
    DpHalt: more messages from the message server
    DpHalt: send keepalive to synchronize with the message server
    NiBufSend starting
    NiIWrite: hdl 17 sent data (wrt=114,pac=1,MESG_IO)
    MsINiWrite: sent 114 bytes
    MsISnd2: send msg (ms hdr/msg 110/4 bytes) to name MSG_SERVER, type 0, key -
    MsSndName: MS_NOOP ok
    Send 4 bytes to MSG_SERVER
    NiIPeek: peek successful for hdl 17 (r)
    NiIRead: hdl 17 received data (rcd=114,pac=1,MESG_IO)
    NiBufIIn: NIBUF len=114
    MsINiRead: received 114 bytes
    MsIReceive: received msg (ms hdr/msg 110/4 bytes), flag 3, from MSG_SERVER , typ 0, key -
    Received 4 bytes from MSG_SERVER
    Received opcode MS_NOOP from msg_server, reply MSOP_OK
    MsOpReceive: ok
    MsISendKeepalive : keepalive sent to message server
    Mon Feb 15 09:59:53 2016
    NiIPeek: peek for hdl 17 timed out (r; 1000ms)
    NiIRead: read for hdl 17 timed out (1000ms)
    DpHalt: no more messages from the message server
    DpHalt: sync with message server o.k.
    DpHalt: detach from message server
    ***LOG Q0M=> DpMsDetach, ms_detach () [dpxxdisp.c 13344]
    NiBufSend starting
    MsIDetach: send logout to msg_server (PruebaSapPRB / 3901)
    MsIDetach: call exit function
    DpMsShutdownHook called
    NiBufISelUpdate: new MODE -- (r-) for hdl 17 in set0
    SiSelNSet: set events of sock 864 to: ---
    NiBufISelRemove: remove hdl 17 from set0
    SiSelNRemove: removed sock 864 (pos=2)
    NiSelIRemove: removed hdl 17
    DpDelSocketInfo: del info for nihdl 17 (pos/type=2/4)
    MBUF state OFF
    DpWpBlksLow: wp_blks_in_queue/threshold/max = 2/800/1000
    DpLockWpBlkEx: lock wp ca_blk 2
    make DISP owner of wp_ca_blk 2
    DpRqIPutIntoQ: put elem in queue DIA, elems=9
    DpRqPutIntoQueue: put request into queue (reqtype 1, prio LOW, rq_id 17)
    MBUF component DOWN
    NiICloseHandle: shutdown and close hdl 17/sock 864
    NiBufIClose: clear extension for hdl 17
    MsIDetach: detach MS-system (PruebaSapPRB / 3901)
    DpHalt: cleanup EM
    EsCleanup( )
    EsCleanup ....
    EmCleanup() -> 0
    Es2Cleanup: Cleanup ES2
    ***LOG Q05=> DpHalt, DPStop ( 1388) [dpxxdisp.c 11819]
    DpHalt: Good Bye .....
