Hola muchachos... alguno de uds tiene documentación sobre la descripción de cada uno de los estados que puedo tomar los IDOCS al ser procesados???.. agradeceré cualquier tipo de información
Nos vemos
te paso esta lista, espero y sea de tu ayuda...
Status Description.
0 Not used, only R/2
1 IDoc created
2 Error passing data to port
3 Data passed to port OK
4 Error within control information of EDI subsystem
5 Error during translation
6 Translation OK
7 Error during syntax check
8 Syntax check OK
9 Error during interchange handling
10 Interchange handling OK
11 Error during dispatch
12 Dispatch OK
13 Retransmission OK
14 Interchange Acknowledgement positive
15 Interchange Acknowledgement negative
16 Functional Acknowledgement positive
17 Functional Acknowledgement negative
18 Triggering EDI subsystem OK
19 Data transfer for test OK
20 Error triggering EDI subsystem
21 Error passing data for test
22 Dispatch OK, acknowledgement still due
23 Error during retransmission
24 Control information of EDI subsystem OK
25 Processing despite syntax error (outbound)
26 Error during syntax check of IDoc (outbound)
27 Error in dispatch level (ALE service)
28 Not used
29 Error in ALE service
30 IDoc ready for dispatch (ALE service)
31 Error - no further processing
32 IDoc was edited
33 Original of an IDoc which was edited
34 Error in control record of IDoc
35 IDoc reloaded from archive
36 Electronic signature not performed (timeout)
37 IDoc added incorrectly
38 IDoc archived
39 IDoc is in the receiving system (ALE service)
40 Application document not created in receiving system
41 Application document created in receiving system
42 IDoc was created by test transaction
50 IDoc added
51 Error: Application document not posted
52 Application document not fully posted
53 Application document posted
54 Error during formal application check
55 Formal application check OK
56 IDoc with errors added
57 Test IDoc: Error during application check
58 IDoc-Copy from an R/2 connection
59 Not used
60 Error during syntax check of IDoc (inbound)
61 Processing despite syntax error (inbound)
62 IDoc passed to application
63 Error passing IDoc to application
64 IDoc ready to be transferred to application
65 Error in ALE service
66 IDoc is waiting for predecessor IDoc (serialization)
67 Not used
68 Error - no further processing
69 IDoc was edited
70 Original of an IDoc which was edited
71 IDoc reloaded from archive
72 Not used, only R/2
73 IDoc archived
74 IDoc was created by test transaction
