Estoy intentando liberar una orden y me da este erro, el problema es que parte de la orden está liberada. A alguien se le ocurre algo?. Este es el error que me sale:
Test call of transport control program (tp) ended with return code 0232
Message no. TK 094
Diagnosis
Your transport request could not be exported, since all requirements were not fulfilled.
Calling the transport control program tp
"tp EXPCHK SDSK925185 pf=\\madssapd\sapmnt\trans\bin\T P_DOMAIN_SDS.PFL -Dtransdir=\\"
which checks the export requirements, returned the following information:
Return code from tp: 0232
Error text from tp: ERROR: Connect to SDS failed (20060607174326).
System Response
Further processing is terminated.
Procedure
Check the following points:
Feasibility of the transport control program tp
Parameter settings in the transport profile
Availability of the transport directory and the subdirectories (cofiles, data, log, sapnames, bin)
Write authorization for the subdirectories
Write authorization for the files of the subdirectories cofiles, data, log, sapnames
Release the request again when the error has been removed
Message no. TK 094
Diagnosis
System Response
Procedure
