Buenos dias, he realizado una copia homogenea de uns sistema SAP R/3 Enterprise Edition en un Windows 2003 con SQL Server.
Una vez hecha la copia con los pasos posteriores, licencia,... me salen muchos short dumps en transacciones, como si no encontrara tablas o algo así.
Generalmente los errores son todos muy similares con "DBIF_RSQL_TABLE_UNKNOWN"
A continuación pongo un estracto de un short dump:
Error analysis
An SAP Open SQL statement contains a table that does not exist in the
database or is not listed in the ABAP Data Dictionary.
The table is "V_21S23L " or another table that is accessed in the statemen
How to correct the error
Probably the only way to eliminate the error is to correct the program.
Please check the entries in the system log (Transaction SM21).
Internal call code.........: "[RSQL/OPEN/V_21S23L ]"
You may able to find an interim solution to the problem
in the SAP note system. If you have access to the note system yourself,
use the following search criteria:
"DBIF_RSQL_TABLE_UNKNOWN" C
"SAPLSDNT" or "LSDNTU16"
"NTAB_GEN_TBHD"
Gracias y un saludo.
Error analysis
"NTAB_GEN_TBHD"
